#252537 - 23/03/2005 19:41 Filener lens pr0n
Mach
Loc: Texas, USA
Cyro came out with this last year. It's a color shifting plastic and it's very cool. How do I know?
#252538 - 23/03/2005 19:46 Re: Filener lens pr0n [Re: Mach]
Mach
Loc: Texas, USA
Now I need buttons to match
#252539 - 23/03/2005 20:18 Re: Filener lens pr0n [Re: Mach]
Oooooh! Very nice!
#252540 - 23/03/2005 22:42 Re: Filener lens pr0n [Re: pgrzelak]
Sweet! My wife would love one of those on her player.
#252541 - 24/03/2005 01:14 Re: Filener lens pr0n [Re: Mach]
FireFox31
Loc: East Coast, USA
Gahh, I literally choked when I saw that picture. That is just intense!
I don't see these lenses on the Filener site. Do these lenses exist yet?
Too bad I only look at my empeg from one angle. Maybe I should "install" my empeg to dangle from my rear view mirror.
FireFox31
#252542 - 24/03/2005 01:35 Re: Filener lens pr0n [Re: Mach]
newguy1
Loc: Massachusetts,USA
Cool .So depending on your viewing angle(left or right) that determines the color that you see?Does the color also change with the up or down angle?
MIKE 80Gb RIO
#252543 - 24/03/2005 04:06 Re: Filener lens pr0n [Re: Mach]
Qtqc
Very sweet.BTW, where did you get that fascia?
#252544 - 24/03/2005 05:11 Re: Filener lens pr0n [Re: pgrzelak]
Mach
Loc: Texas, USA
Thanks, exactly my reaction when I first installed it. The plastic has a mirrored coating that I'm sure will make it impossible to read in the sun but it does look nice in low light.
#252545 - 24/03/2005 05:26 Re: Filener lens pr0n [Re: FireFox31]
Mach
Loc: Texas, USA
Not sure if you'll ever see them on the site. Last time I tried to source the plastic, I found it was not in production yet and it was going to be very expensive. In addition, the only thickness available at the time was 1/8" which requires a two piece lens. Cyro was kind enough to send me a small sample which was promptly cut into two lenses, one to fit the NewFace lens and another for the old fascia.
#252546 - 24/03/2005 05:32 Re: Filener lens pr0n [Re: newguy1]
Mach
Loc: Texas, USA
The color shifts at any change in viewing angle. Up, down, left, right, and positions in between. At the most extreme viewing angles, it appears green and colrs shift through G - Y - V - B where blue is visible at a 90 degree viewing angle.
#252547 - 24/03/2005 05:49 Re: Filener lens pr0n [Re: Qtqc]
Mach
Loc: Texas, USA
http://www.by-photos.de/PolFace.html but they are no longer available. Do a search on NewFace for more info. FYI, Webroach is working on a new aluminum fascia.
#252548 - 24/03/2005 11:43 Re: Filener lens pr0n [Re: Mach]
And once again, Alvin's machine is voted "Best Dressed Player" of the year!
#252549 - 25/03/2005 03:26 Re: Filener lens pr0n [Re: Mach]
peakmop
Loc: 384400 km from the Moon
An eye candy indeed.
Only if your NewFace had the same effect...
I wonder if credit card logos use the same type material or work on the same principle.
#252550 - 25/03/2005 20:04 Re: Filener lens pr0n [Re: mlord]
Mach
Loc: Texas, USA
Thanks Mark. Just trying to make it look good enough for it's dock.
#252551 - 25/03/2005 20:28 Re: Filener lens pr0n [Re: peakmop]
Mach
Loc: Texas, USA
Color shifting fascia? A quick shot of paint could do it http://www.colorshift.com/index.php?s=galleries but I think I like the chrome on the NewFace better. I'm not sure how the plastic is done or if it's similar to the credit card holograms. I've got a small piece of the plastic that I'm going to cut up for button caps so I should be able to tell pretty quick if it's a film or embedded.
#252552 - 26/03/2005 09:23 Re: Filener lens pr0n [Re: Mach]
Pimp my empeg!
