#252924 - 30/03/2005 01:03 Really new guy here needs some help!!
PearlSC2
Hello everyone, just got my Rio not 1 hour ago and I need the software to upload music to it, however, I have pugged it in and upladed my new logo's (super cool feature) and it says that no hard disk is found contact support, I need help. Thanks for your help.
Jay
#252925 - 30/03/2005 01:12 Re: Really new guy here needs some help!! [Re: PearlSC2]
SE_Sport_Driver
Click the "Latest Software" link at the top of the page for the software to load music on the player. It's called "emplode" and you'll want the "2.00final" version of it. You'll also need the "2.00 developer version" of the player software. It is the most stable and up-to-date. Both emplode and the player software need to be the same version.
For the "hard disk not found" message, you may want to spend a little time reading the FAQ. It is probably the best FAQ I've come across on the internets. But, since you're in a pinch, the entry you're looking for is here.
Finally, since you've found Tony's Logo Editor (assuming that's what you used to change the boot logo), I suggest using its Kernal Flash utility (built in) to install the latest Hijack Kernal.
#252926 - 30/03/2005 01:15 Re: Really new guy here needs some help!! [Re: PearlSC2]
Assuming it wasn't broken before it was shipped, the most likely problem is that the hard drive cable came loose during shipping. Look at the drive upgrade guide to see how to open it up and check the cable. If that's not it, read the whole FAQ on "No Hard Drive Found".
#252927 - 30/03/2005 01:17 Re: Really new guy here needs some help!! [Re: wfaulk]
SE_Sport_Driver
Good point, the FAQ entry mentions a lot of posibilities, but the loose cable is the easiest to check. And when you check it, make sure you have a tight connection at the drive AND at the board. If you only have one drive, move it to the "2nd spot" and use the END of the cable rather than the middle connector. This will eliminate a 2nd posibility: a bad cable crimpt.
#252928 - 30/03/2005 01:25 Re: Really new guy here needs some help!! [Re: PearlSC2]
PearlSC2
It is probably right under my nose but I cannot find the 2.00 developer tool, but I think I have the other one right
emplode PC software for Windows 98SE, ME, 2000 and XP. USB drivers included (refer to release notes).
#252929 - 30/03/2005 01:38 Re: Really new guy here needs some help!! [Re: PearlSC2]
PearlSC2
THere is a very wide cable not hooked to anything, is that right?? It is an MK2 by the way bought off Ebay
J
#252930 - 30/03/2005 01:41 Re: Really new guy here needs some help!! [Re: PearlSC2]
PearlSC2
Actually it seems to be connected in the middle of a hard drive then it goes to nothing, perhaps for a second hard drive??
#252931 - 30/03/2005 01:47 Re: Really new guy here needs some help!! [Re: PearlSC2]
PearlSC2
Took it apart and re attached/tightened it as per the re crimping bulletin and now she is up and running, now I still have the software issue though, imagine I am 4 years old, then let me know what I need.
Jay
#252932 - 30/03/2005 02:26 Re: Really new guy here needs some help!! [Re: PearlSC2]
time
Loc: Southwest
jEmplode is what I would recommend to start loading tracks.
Congrats on your first repair. Do be careful on reassembly to get everything back properly/carefully. Welcome to the community!
#252933 - 30/03/2005 02:48 Re: Really new guy here needs some help!! [Re: time]
PearlSC2
Thank you very much, happy to be here, no stick men on my visuals though, do I need to upload that??
Jay
#252934 - 30/03/2005 02:57 Re: Really new guy here needs some help!! [Re: PearlSC2]
You need a matching version of the player firmware and the emplode loader software. Exact details on how to do this are here.
