#253178 - 01/04/2005 18:46 Pump Response Error, Installing 2x20 gigs
michael_corleone
So my harddrive died, and i decided to replace it with 2 20 gig hdd's. I downloaded the car2-builder-20011022.upgrade and
i'm getting this error when i run the wizard
Error "Bad Pump response" Occured during stage 0x25
I changed the ide cable just in case. I don't know what else it could be, i'm also refering to the Rio Car Disk Upgrade Guide
on riocar.org same thing happens
any ideas?
Edited by michael_corleone (01/04/2005 18:50)
#253179 - 01/04/2005 18:52 Re: Pump Response Error, Installing 2x20 gigs [Re: michael_corleone]
SonicSnoop
Loc: Triangle, VA
You may want to check out this FAQ entry and see if that helps any
#253180 - 01/04/2005 19:31 Re: Pump Response Error, Installing 2x20 gigs [Re: SonicSnoop]
michael_corleone
from that site I did all that, tried downloading the car2-builder-20011022.upgrade file again, cable works. The Hdd's are brand new right out of the box and out of a laptop..... oh and i tried a new ac adapter from my other empeg. any other ideas
#253181 - 01/04/2005 20:21 Re: Pump Response Error, Installing 2x20 gigs [Re: michael_corleone]
any other ideas
Yes. Read the FAQ entry again. There's one possibility there, that you didn't list in your post. Sounds like you're ignoring it the way one would ignore the elephant in the middle of the living room.
#253182 - 01/04/2005 23:27 Re: Pump Response Error, Installing 2x20 gigs [Re: tfabris]
michael_corleone
Got it it's this problem
http://kharendaen.dyndns.org:8000/~henke/public/mk1214gap/
doesn't like the hdd's, gonna go back to hitachi
#253183 - 02/04/2005 00:02 Re: Pump Response Error, Installing 2x20 gigs [Re: michael_corleone]
I don't think the empeg does CSEL, I don't think it's that problem. The elephant I'm talking about is this one.
#253184 - 02/04/2005 00:58 Re: Pump Response Error, Installing 2x20 gigs [Re: tfabris]
michael_corleone
No go Tony, I put it into my other empeg that works and still getting the same error. It's the hdd's doesn't like the toshiba hdd's
#253185 - 02/04/2005 07:28 Re: Pump Response Error, Installing 2x20 gigs [Re: michael_corleone]
Are you trying to build each of the two new 20 gig drives individually? (i.e, with only one plugged in)
#253186 - 02/04/2005 10:58 Re: Pump Response Error, Installing 2x20 gigs [Re: michael_corleone]
SE_Sport_Driver
When you swapped players, did you also swap hard drives?
