#254606 - 18/04/2005 15:31 Can Anyone Help Me
MRB
#254607 - 18/04/2005 15:34 Re: Can Anyone Help Me [Re: MRB]
Are you looking for how to set up the drives to start with, or how to enable the larger FID counts? The FID counts only really matter on a very full player.
#254608 - 18/04/2005 15:38 Re: Can Anyone Help Me [Re: MRB]
MRB
Drives all done and dusted got 20,000 tracks at the moment uploading as we speak, would like to know how to do the FID if not now, maybe for the future thx
#254609 - 18/04/2005 15:48 Re: Can Anyone Help Me [Re: MRB]
Download the latest version of the software from the thread you linked to. Start from the bottom and work your way up the thread to get the latest (I think it is v7)...
Load hijack, if you have not already done so. This (at minimum) gives you an ftp daemon on the player.
Follow Mark's instructions, that I have quoted below.
site rw
cd /empeg/bin
chmod 755 set_empeg_max_fix.v7
site exec /empeg/bin/set_empeg_max_fix.v7
site ro
site reboot
This should work. If, for some reason you find that it does not, post your errors here for further checking. Worst case (if you do not have the network settings configured on your player), you can always upload it via serial and run it from the console of the player...
#254610 - 18/04/2005 15:57 Re: Can Anyone Help Me [Re: MRB]
MRB
v7 downloaded, Hijack loaded! - where do I type the commands? - sorry
#254611 - 18/04/2005 16:04 Re: Can Anyone Help Me [Re: MRB]
Is your player itself connected to the network? If so, from the (assuming windows) box you have the file on, do Start, Run, "ftp ip.address.of.player". It will ask you for a username - hit return. You should now be logged into the player via FTP. Type in the commands that Mark listed (and I copied in the thread above in italics). That should do it.
#254612 - 18/04/2005 16:26 Re: Can Anyone Help Me [Re: pgrzelak]
He also needs to get the max_fix program onto the player doesn't he?
#254613 - 18/04/2005 16:32 Re: Can Anyone Help Me [Re: pgrzelak]
MRB
Paul - logged on to the player via ftp 169.254.218.147 user name pressed return, site rw - Invalid command
#254614 - 18/04/2005 16:38 Re: Can Anyone Help Me [Re: MRB]
Ah, I think for the DOS FTP program it's something like LITERAL SITE RW or perhaps QUOTE SITE RW, I don't remember exactly.
#254615 - 18/04/2005 16:40 Re: Can Anyone Help Me [Re: tfabris]
But I think you really need to get the file onto the player first using one of these methods.
#254616 - 18/04/2005 16:42 Re: Can Anyone Help Me [Re: tfabris]
Yeah, and here is the instructions on how to use the Windows FTP.EXE with Hijack.
#254617 - 18/04/2005 16:44 Re: Can Anyone Help Me [Re: tfabris]
Good point about getting the file onto the player. Since FTP was involved, I thought it was sending the file to the player. Not the case. Still, this should be easy either through FTP itself or uploading.
If LITERAL does not work, try QUOTE.
