#254787 - 22/04/2005 13:49 trio applet only working on server (localhost)
dforsythnet
I'm able to run the trio applet on the same box the server is running on. but not able to run it from any other machine. I get a title "tRio Web Font-End" with subtext "finding tRio Server".
Is there some location I have to list what IPs can connect?
for the recond, I'm able to get the applet running on the server using either java 1.4.2 or 1.5.0, using firefox on a linux box FC3.
Here is the log entry from Explorer's Java console.
 Apr 22, 2005 10:46:11 AM trio.applet.TRioApplet init
INFO: Parameters. trio-server: music.dforsyth.net, rmi-port: 1099
Apr 22, 2005 10:46:11 AM trio.applet.TRioAppletConnectionThread run
INFO: Start of TRioAppletConnectionThread
Apr 22, 2005 10:46:12 AM trio.applet.TRioApplet setServer
INFO: Exporting Remote
Apr 22, 2005 10:46:14 AM trio.applet.TRioApplet setServer
INFO: Remote exception while setting server - server gone down?
java.rmi.ConnectException: Connection refused to host: 127.0.0.1; nested exception is:
java.net.ConnectException: Connection refused: connect
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.createConnection(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.newConnection(Unknown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at trio.TRioServer_Stub.listApplications(Unknown Source)
at trio.applet.TRioApplet.getApplications(Unknown Source)
at trio.applet.TRioApplet.setServer(Unknown Source)
at trio.applet.TRioAppletConnectionThread.establishConnection(Unknown Source)
at trio.applet.TRioAppletConnectionThread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(Unknown Source)
at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(Unknown Source)
... 9 more
Exception in thread "Thread-17" java.lang.NullPointerException
at trio.applet.TRioApplet.disposeNavigationPanel(Unknown Source)
at trio.applet.TRioAppletConnectionThread.checkConnection(Unknown Source)
#254788 - 24/04/2005 15:36 Re: trio applet only working on server (localhost) [Re: dforsythnet]
pauln
Try editing trio.xml and change:
<rmi create-registry="true"/>
to:
<rmi create-registry="true" host-name="xxxx"/>
Where xxxx is the ip address of the box that tRio is running on.
Paul
#254789 - 26/04/2005 13:47 Re: trio applet only working on server (localhost) [Re: pauln]
dforsythnet
Thanks, adding the host part solved my problem.
Also running the applit on java 1.5.0 the tabs do not work, I have noticed some other postings reporting this problem.
#254790 - 10/04/2007 13:54 Re: trio applet only working on server (localhost) [Re: pauln]
BaBa
Loc: Ventura, CA USA
This is an awesome app!!! I have 6 units and would love to be able to control them using my PSP.
I have this problem as well, and tried this suggestion
and substituted xxxx with 192.168.0.3, the static ip of my server. - but it didn't work for me. I can only view the front-end on the local machine using the following URL http://localhost:8090/trio-html
I cannot even use the local machine's ip address on the local machine (http://192.168.0.3:8090/trio-htm)
I'm running WinXP SP2, tRio 0.1.6, Java 1.42. I've got no software firewall running.
Any suggestions?
Thank You!!!
