#255892 - 10/05/2005 19:07 Upgrading to 100GB Fujitsu drive
Happy Birthday Taym
I finally received my new 100GB Fujitzu drive
I am now trying to copy fids from one ol drive to another.
From Tony's famous super upgrading guide:
Read-write mount the disk drives. Type:
rw (Enter)
rwm (Enter)
There will probably be a pause before the shell prompt appears again
How long can the pause be? I've been waiting for few minutes, then tried again and again. What am I doing wrong?
#255893 - 10/05/2005 19:08 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
Happy Birthday Taym
Ok, I wasn't patient enough. According to Murphy's Law, I got the prompt immediately after posting. Sorry...
#255894 - 10/05/2005 19:17 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
No worries. I would strongly recommend that you immediately modify your /bin/rwm to include the nocheck option!
#255895 - 10/05/2005 19:21 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
Happy Birthday Taym
While I was copying fids, I got this
/drive1/fids/_00000/891 -> /drive0/fids/_00000/891
/drive1/fids/_00000/8a0 -> /drive0/fids/_00000/8a0
/drive1/fids/_00000/8a1 -> /drive0/fids/_00000/8a1
/drive1/fids/_00000/8c0 -> /drive0/fids/_00000/8c0
/drive1/fids/_00000/8c1 -> /drive0/fids/_00000/8c1
/drive1/fids/_00000/8d0 -> /drive0/fids/_00000/8d0
/drive1/fids/_00000/8d1 -> /drive0/fids/_00000/8d1
/drive1/fids/_00000/8e0 -> /drive0/fids/_00000/8e0
/drive1/fids/_00000/8e1 -> /drive0/fids/_00000/8e1
/drive1/fids/_00000/8f0 -> /drive0/fids/_00000/8f0
hda: irq timeout: status=0xd0 { Busy }
ide0: reset timed-out, status=0xd0
hda: status timeout: status=0xd0 { Busy }
hda: drive not ready for command
end_request: I/O error, dev 03:04 (hda), sector 99066
EXT2-fs error (device ide0(3,4)): ext2_write_inode: unable to read inode block - inode=420, block=49533
ide0: reset: success
end_request: I/O error, dev 03:04 (hda), sector 398331
Does anybody know what it means? It is not stopping, and I don't kknow if it is wise to unplug the player....
#255896 - 10/05/2005 19:23 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
Um, not good. Those timeouts look like a hardware issue (cable, drive or header) that are causing you trouble. It seems that all of them are associated with hda, so it might be a cable crimp issue.
As for stopping, try ctrl-c first. You do not really want to unplug (and get dirty filesystems) if you can avoidit.
#255897 - 10/05/2005 19:26 Re: Upgrading to 100GB Fujitsu drive [Re: pgrzelak]
Happy Birthday Taym
Paul, I just noticed the cable is daaged! It was cratching agains the video board, as mentioned in a faq somewhere. I did check it, but when I did it was looking fine.
So, fortunately I have another one, but not here where I am. I will have to wait until the weekend to update.
Thank youf ro your help. Now, I really hope it is the cable, at least... I can see the wire underneat through the scratched surface of the cable, so there are good chances that that's where the problem is.
#255898 - 10/05/2005 19:29 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
If you can see metal through the cable, that is likely the problem. I hope it works for you. Meanwhile, get the drives stable if possible. You might be able to get a little more life out of it and continue your testing if you can wrap the hopefully unbroken but exposed wire with electrical tape to prevent shorting.
#255899 - 10/05/2005 20:00 Re: Upgrading to 100GB Fujitsu drive [Re: pgrzelak]
Happy Birthday Taym
Paul, thanks again.
Yes, I see metal through the cable. The two wires on the left are exposed. One of them seems to be damaged, while the other just exposed. I can't seem to make it work at all now: while before I could at least evetually boot, now I only get the "No Hard Disk Found - Contact Support" message.
Do you have an recommendation on how to prevent this? I had just replaced the original cable with one from Eutronix. Fortunately, I had bought three, a year ago. Clearly, while the original was not scratching against the display board, these ones are, so I guess I will have to find a solution as soon as I replace the cable with one of the remaining two...
#255900 - 10/05/2005 20:03 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
SonicSnoop
Loc: Triangle, VA
I believe there was supposidly a specific way the cable needed to be folded in order for it to work right. maybe somebody more knowledgable in their installation could respond. I cant for the life of me remember where I read it when I installed mine.
#255901 - 10/05/2005 20:26 Re: Upgrading to 100GB Fujitsu drive [Re: SonicSnoop]
Happy Birthday Taym
Well, Eutronix cables are pre-folded and look very very good. I can't imagine how else I could fold it, but maybe there's some trick I don't know/remember. I can't find any suggestion in the FAQ. Maybe some insulating tape and plastic protection of some sort could work...
#255902 - 10/05/2005 20:32 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
The tape and plastic will work short term, but the longer cables from Eutronix are the best answer.
#255903 - 11/05/2005 07:27 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
From the drive upgrade guide...
Inspect the IDE cable and make sure it's OK. On some early Mark 1 models, a messy solder on a jumper on the motherboard might have scarred the cable. Repair this as necessary. In my case I had to file down the jumper, resolder it, and protect the damaged cable with electrical tape. If you have to do this, use extreme caution and don't let any filings stay inside the case.
I know, not exactly the same situation, but the same concept.
#255904 - 11/05/2005 10:37 Re: Upgrading to 100GB Fujitsu drive [Re: tfabris]
Happy Birthday Taym
Thanks Tony. Yes, the guide included also this aspect. There really is nothing I could find in the upgrade process that is not mentioned in the guide
As a matter of fact, I did not notice the damage immediately because I did not look, and the drives were initially working; they actually did until I started to copy fids. Well, as I said I have two more Eutronix cables, which I will replace in the weekend, as I am now out of town.
Now, my concern is that if this Eutronix cable was damaged scratching against the display card, maybe the others will have the same problem. I need to find something to protect the new ide cable, as this one is really badly damaged. I can't think of anything else than a plastic surface to be put between the display board and the ide cable. Tape would only resist temporarily...
#255905 - 11/05/2005 13:18 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
You keep missing the part where I said I had to file down the thing that was damaging the cable.
#255906 - 11/05/2005 14:16 Re: Upgrading to 100GB Fujitsu drive [Re: tfabris]
Happy Birthday Taym
Oops, I'm sorry! I thought you were referring somehow to the HDD jumper! In my case, there's a protruding soldering point on the display board that is right against the ide cable. I am really not experienced enough in soldering to do anything like that. If that is the case, I'll have to ask expert friends...
#255907 - 14/05/2005 15:28 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
Happy Birthday Taym
It was in fact the cable. New cable, all has worked so far. I am currently copying fids from old-drive-1 (30GB) to new-drive (100GB), via the
cp -auvfx /drive1/fids /drive0/ command.
I have the impression it is faster that it would be via ethernet (is it supposed to? What is the theoretical transfer speed via ide channel?), which is really good. In an hour I should be done and move on to old-drive-2 (still 30GB) -> new-drive. I've upgraded a few times in the past, but for some reason I had always used ethernet. Again, thanks Tony for another good suggestion on The Guide
I just realized that since I will be using ONE drive only, the part of the cable scratching the display card is not going to be "used" (the scratch was very close to the ide connector for the slave drive), and therefore I should be able to fold it in a way that it is preserved intact, far from the display card.
#255908 - 15/05/2005 03:30 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
I just did the exact same copy between drives to get all the stuff off my old 30GB onto my new 80GB. It is faster than ethernet but only marginally (twice to be precise) since the empeg can't DMA to the drives.
I see about 700kB/sec over ethernet and I timed my drive to drive copy a few times and it worked out be exactly 1.4MB/sec every time.
#255909 - 15/05/2005 13:19 Re: Upgrading to 100GB Fujitsu drive [Re: Shonky]
Doing it with a PC is much faster as it uses DMA unlike the empeg as Shonky points out. Laptop IDE adapters are cheap and you can do it using just a Knoppix/whatever Linux CD if you have two adapters.
#255910 - 15/05/2005 17:20 Re: Upgrading to 100GB Fujitsu drive [Re: tman]
Happy Birthday Taym
Shonky, I confirm, 1/2 of ethernet time, that was true in my case as well. Well, still an improvement.
I also copied the dynamic data partition, successfully!! Have I already thanked Tony for the upgrade guide?
#255911 - 16/05/2005 20:39 Re: Upgrading to 100GB Fujitsu drive [Re: tfabris]
Happy Birthday Taym
I'ts not over yet...
I am adding all MP3s I had to keep on my PC when waiting for the new drive.
I starterd the sync form emplode, and as it started to actually transfer the first MP3, the sync process froze. After a long wait, I decided to kill emplode and restart. As usual, the empeg rebuilt the database at reboot.
I then started emplode for the second time. As it connected to the empeg, it started to check media, as I expected. It took very long, according to the FAQ. First time with 100GB, for me. However, after waiting long, and before both reading the FAQ and the completion of the media check, I decided something was wrong. So, while emplode was still checking media, I disabled the periodic disk check from hijack (yes, I did access hijack and change the option while emplode was checking. Was I silly and naive, besides impatient?). Then, I killed emplode, unplugged the empeg, hoping that it would not check the disk again.
The empeg reboots, rebuilds the database, I restard emplode, and... checking media again. So I decide I have to let it go till the end of the process. I finally get back to emplode. All refs are at least 1, so it seems nothing had been transferred. I proceed and upload just one CD, to make sure it works. Hit "Sync", and again, checking disk integrity during sync. It took less then before, and finally the MP3s are uploaded. No errors. after that.
Happy, and believing the media check would be done for 20 more resyncs, I proceeded to uploading more MP3s. I eventually clicked on Sync, and... Checking media again!
I am now hoping I don't have a faulty drive, and my assumption is that I shouldn't have disabled the disk check from HiJack WHILE it was checking. So I re-enabled the disk check from HiJack, and I am now waiting that this sync process completes; and I am crossing my fingers.
Now, I guess my question is: am I making any sense, or is my drive faulty?
#255912 - 16/05/2005 20:49 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
I think the option in Hijack only disables periodic checking. The ext2 filesystem can remember how long it was since it was last checked. There is a setting to disable this (or at least make it super long) in the file system.
Probably most of your file system checking is due to unclean mounting of the drive (resetting while in read/write mode). I don't think Hijack can stop this.
However, that said, I rarely do reboots while in read/write mode and I still get disk checking happening most times I add new tunes. This is generally spaced by weeks, so in my case it's possible the Hijack function isn't working properly for me. I haven't really bothered to check since I usually sync at work or overnight, where I can walk away and it can take basically as long as it wants.
As for the speed, I notice it Roger's drive guide, one of the options specifies "sparse superblock" to help speed up fscks. I can differentiate betweent the two drives fscking in jemplode, and one of them is significantly faster than the other possibly due to it being set up manually whereas the other was done by the disk builder. I've been meaning to format the other drive similarly in hopes of speeding up the fsck.
Not really sure how that helps you though with it freezing during a sync. Put a serial cable on it during the sync to see if there are any drive errors appearing.
#255913 - 16/05/2005 20:58 Re: Upgrading to 100GB Fujitsu drive [Re: Shonky]
Happy Birthday Taym
Thank you Shonky. Well, now it does not seem to freeze any more. My only problem is that last two mp3 upload sessions required media check, and that really is time consuming... Not to mention that I still don't know why...
#255914 - 16/05/2005 23:42 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
It is very likely that this page from the FAQ has the solution to your problem.
#255915 - 17/05/2005 04:25 Re: Upgrading to 100GB Fujitsu drive [Re: tanstaafl.]
Happy Birthday Taym
Thank you transaafl. I had actually checked that FAQ. Well, I have this error:
which seems very similar to this one mentioned in the faq:
"EXT2-fs warning: maximal mount count reached, running e2fsck is recommended"
Unfortunately, it does not seem to go away after next resync. Every resync it needs a drive check.
Should I proceed with
ro
umount /dev/hda4
umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
all the same?
#255916 - 17/05/2005 04:40 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
Yep well one is due to rebooting without unmounting and the other is the one Hijack gets around.
Doing the...
ro
umount /dev/hda4
umount /dev/hdc4
swapon /swapfile
fsck -fay /
fsck -fay /dev/hda4
fsck -fay /dev/hdc4
swapoff /swapfile
sync
...certainly won't break anything and is worth a try in my opinion.
#255917 - 17/05/2005 07:54 Re: Upgrading to 100GB Fujitsu drive [Re: Shonky]
Agreed. The manual fsck of all drives should clear that flag. Just make sure that it does not return any errors.
#255918 - 17/05/2005 08:54 Re: Upgrading to 100GB Fujitsu drive [Re: pgrzelak]
Happy Birthday Taym
Ok, I am then proceeding
Here's the boot info BEFORE the manual fsck
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v429 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue May 10 20:39:19 EDT 2005
Added temporary pagedir entry for flash memory access
Checking for extra DRAM:
c1000000: wrote ffffffff, read e2811004
empeg-car player (hardware revision 9, serial number 40103216) 16MB DRAM
Command line: mem=16m
Memory: 15012k/16M available (984k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x98b7c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005500).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHU2100AT, ATA DISK drive
hda: FUJITSU MHU2100AT, 95396MB w/8192kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:90
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
qMounting second music partition
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Comply.Starting player
Timezone: MET
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 90 (adjustment 10)
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
q
q
q
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x40693000
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin#
Sorry for the "q" here and there
I am not at the command prompt and I am sending the commands in a moment.
#255919 - 17/05/2005 09:45 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
Happy Birthday Taym
Ok. All done:
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
umount: /dev/hdc4: not found
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1512/4096 files (0.5% non-contiguous), 9996/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
/dev/hda4: 18364/762368 files (13.2% non-contiguous), 58979168/97578810 blocks
empeg:/empeg/bin# fsck -fay /dev/hdc4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
fsck.ext2: Device not configured while trying to open /dev/hdc4
Possibly non-existent or swap device?
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
Then, unplugged and plugged:
_______________
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0005580).
Partition check:
Mounting proc
Starting player
Timezone: MET
Vcb: 0x40693000
_________________
So, look at the bold lines. Still needs to check the disks, and I got those errors. Does anybody know what that means?
Thank you!
Edited by taym (17/05/2005 09:47)
#255920 - 17/05/2005 10:18 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
This one is harmless. It just means that it wants you to do a check on the filesystem because the time since the last one exceeded the set limit. Hijack disables this for you.
It will always give this error because we don't use ReiserFS. I think the Central does however which is why it attempts to mount the music partition as ReiserFS.
Just means it's trying to mount the second HD but couldn't as you don't have one.
#255921 - 17/05/2005 10:21 Re: Upgrading to 100GB Fujitsu drive [Re: Taym]
In this case it's talking about the filesystem on the initrd. As this never changes, it's not a problem. Whatever's causing your excessive-media-checks problem, it's not one of those three lines.
