#257223 - 02/06/2005 21:12
Re: A sample installation.. with photos
[Re: frog51]
Loc: Louisiana, USA
What I find works in addition to large amounts of flux is to apply a very small amount of solder to the tip of the iron, then some of the solder onto the RAS line. This intermediary step helps to further diminish the amount of solder at the eventual joint at the Strong Arm pin. Then hold the end of the wire to the proper pin and briefly touch the iron to the end of the wire where the solder is.
I just think it's easier to transfer a small amount of solder from the tip of the iron onto the RAS wire then to take it directly to the wire and pin.
Stu
#257224 - 02/06/2005 22:44
Update:
My modded player developed stability issues -- random crashes and the like.
My theory is mechanical issues -- the memory expansion card adds a lot of stiffness to the main board, and when the main board is subsequently screwed back into the stainless steel enclosure, it wants to bend to match the enclosure screw posts (flat?). This puts stress on the connections between the two boards, and I think something just "gave" in the end.
So, I've put enough hours into this for now, and tonight I disassembled the player and removed the memory card again. Not quite as clean a removal this time around -- destroyed several of the test pads, but they're not really important or needed for anything other than the (removed) memory card, so no big deal.
Back to 16MB for now, but I do still have a couple of pairs of chips to do the stacking method with eventually.
#257226 - 06/06/2005 13:34
Re: memory board progress
[Re: pca]
The first 10-15 boards should ship by the end of the week. Most of the rest will go out next week, with a bit of luck. I'm waiting for some antistatic bags to turn up, and finishing the manual.
#257227 - 06/06/2005 20:31
[Re: pca]
I can't wait!
#257228 - 09/06/2005 00:05
Any more updates Mark?
#257229 - 09/06/2005 01:39
[Re: SE_Sport_Driver]
Quote: Any more updates Mark?
Err. not since I removed the memory board in the end (post above).
Of course, now I suppose I should find a new home for the memory board I have here (with chips).
#257230 - 16/06/2005 01:19
[Re: pca]
Were these sent out? I was very early in the queue...
#257231 - 20/06/2005 14:49
By the end of tomorrow, the first 25 boards will have shipped. There will be a slight delay for the next twenty-five.
#257232 - 20/06/2005 18:10
[Re: pca]
Thank you, thank you! I hope I didn't come off as complaining about any delays or doubtful about any progress. Just curious.
#257234 - 23/06/2005 12:39
Quote: My modded player developed stability issues -- random crashes and the like.
Patrick has since emailed me about this, and he said that the culprit may be insufficient current flow from the power/ground test pads. To remedy this, he is recommending additional short jumper wires from another location of the main board to the memory board. Apparently Hugo's Mk2 player needed those, and works well now with 64MB + Mk2a_bootloader + latest Hijack.
I'm not redoing mine until I hear how others make out with their upgrades. Also, Patrick said something about finishing up the installation manual soon (if not already), which ought to help.
Edited by mlord (23/06/2005 18:26)
#257237 - 23/06/2005 15:26
[Re: mtempsch]
The manual with revised wiring description are being written at this very moment.
#257239 - 23/06/2005 16:31
[Re: mtempsch]
Yup - I would suggest someone start a thread with a list of "parts wanted" for Amersfoort, and I'll make sure I have the bits ready. Gotta go!
#257241 - 25/06/2005 18:35
#257243 - 25/06/2005 23:40
[Re: mtempsch]
In addition to the RAS line, you'll also need to run extra (SHORT!) power and ground signals from the capacitors on the main board just above the main board memory chips over to the capacitors on the memory board. One set of power and ground should do it, I'd think.
Failure to do this may result in all sorts of weird memory errors, or having things appear to work, and then fail when operating at a different temperature.
#257244 - 26/06/2005 23:34
[Re: caseyse]
Loc: East Coast, USA
I just found the postal notice saying they tried to deliver my memory board on Saturday. Now I can go pick it up when I ship out buttons in the morning!
But then my only lit player goes to Eutronix for the upgrade. I will be back in the dark ages.
#257245 - 28/06/2005 13:15
[Re: schofiel]
Loc: Switzerland
Any news on the manual for the memory board? Am I right that it is not yet available? (At least I have not found it) I've got the board yesterday and can't wait to upgrade the player. I don't need a full featured, colored manual. I'm happy with a simple step by step installation guide.
#257246 - 28/06/2005 15:06
[Re: alex25]
Only a little while before it's ready.
#257247 - 28/06/2005 16:13
[Re: schofiel]
Rockin'. Picked up my two boards from the post office today.
#257248 - 18/07/2005 13:02
[Re: pca]
Loc: Elk Grove, CA
Patrick,
Any update on when the next batch might be ready?
No longer a stranger, finally a full-fledged member!
#257249 - 23/08/2005 14:26
[Re: pca]
Loc: Elk Grove, CA
Bump...is the second batch still on hold? I've held off ordering a larger hard drive and installing 3.0a11 until I have the memory board installed. I believe I was #32 in the queue.
Edited by Glen_L (23/08/2005 14:29)
#257250 - 23/08/2005 14:35
[Re: Glen_L]
Loc: Hamburg, Germany
i guess we'll just have to wait... i have order #2 - pca's last reply in july was they'll go out soon. too bad there's a great deal of flexibility in the word 'soon'...  well i don't complain as i have no idea yet how i get those boards into my empegs...i really don't think i should do that myself...
