Page 2 of 2 < 1 2
#257223 - 02/06/2005 21:12 Re: A sample installation.. with photos [Re: frog51]
maczrool
Loc: Louisiana, USA
What I find works in addition to large amounts of flux is to apply a very small amount of solder to the tip of the iron, then some of the solder onto the RAS line. This intermediary step helps to further diminish the amount of solder at the eventual joint at the Strong Arm pin. Then hold the end of the wire to the proper pin and briefly touch the iron to the end of the wire where the solder is.
I just think it's easier to transfer a small amount of solder from the tip of the iron onto the RAS wire then to take it directly to the wire and pin.
Stu
#257224 - 02/06/2005 22:44 Re: A sample installation.. with photos [Re: mlord]
Update:
My modded player developed stability issues -- random crashes and the like.
My theory is mechanical issues -- the memory expansion card adds a lot of stiffness to the main board, and when the main board is subsequently screwed back into the stainless steel enclosure, it wants to bend to match the enclosure screw posts (flat?). This puts stress on the connections between the two boards, and I think something just "gave" in the end.
So, I've put enough hours into this for now, and tonight I disassembled the player and removed the memory card again. Not quite as clean a removal this time around -- destroyed several of the test pads, but they're not really important or needed for anything other than the (removed) memory card, so no big deal.
Back to 16MB for now, but I do still have a couple of pairs of chips to do the stacking method with eventually.
#257225 - 04/06/2005 20:31 Re: A sample installation.. with photos [Re: frog51]
Happy Birthday schofiel
steady hand
and
Amersfoort
Doh!
#257226 - 06/06/2005 13:34 Re: memory board progress [Re: pca]
The first 10-15 boards should ship by the end of the week. Most of the rest will go out next week, with a bit of luck. I'm waiting for some antistatic bags to turn up, and finishing the manual.
#257227 - 06/06/2005 20:31 Re: memory board progress [Re: pca]
SE_Sport_Driver
I can't wait!
#257228 - 09/06/2005 00:05 Re: A sample installation.. with photos [Re: mlord]
SE_Sport_Driver
Any more updates Mark?
#257229 - 09/06/2005 01:39 Re: A sample installation.. with photos [Re: SE_Sport_Driver]
Err. not since I removed the memory board in the end (post above).
Of course, now I suppose I should find a new home for the memory board I have here (with chips).
#257230 - 16/06/2005 01:19 Re: memory board progress [Re: pca]
SE_Sport_Driver
Were these sent out? I was very early in the queue...
#257231 - 20/06/2005 14:49 Re: memory board progress [Re: SE_Sport_Driver]
By the end of tomorrow, the first 25 boards will have shipped. There will be a slight delay for the next twenty-five.
#257232 - 20/06/2005 18:10 Re: memory board progress [Re: pca]
SE_Sport_Driver
Thank you, thank you! I hope I didn't come off as complaining about any delays or doubtful about any progress. Just curious.
#257233 - 23/06/2005 09:11 Re: memory board progress [Re: pca]
mtempsch
Just picked mine up at the post office Will start disassembling the player tonight...
#257234 - 23/06/2005 12:39 Re: A sample installation.. with photos [Re: mlord]
Patrick has since emailed me about this, and he said that the culprit may be insufficient current flow from the power/ground test pads. To remedy this, he is recommending additional short jumper wires from another location of the main board to the memory board. Apparently Hugo's Mk2 player needed those, and works well now with 64MB + Mk2a_bootloader + latest Hijack.
I'm not redoing mine until I hear how others make out with their upgrades. Also, Patrick said something about finishing up the installation manual soon (if not already), which ought to help.
Edited by mlord (23/06/2005 18:26)
#257235 - 23/06/2005 14:44 Re: memory board progress [Re: mtempsch]
Carefully...
#257236 - 23/06/2005 15:15 Re: memory board progress [Re: schofiel]
mtempsch
Carefully... : smirk:
lyou mean no blowtorch, 5-pound hammer and chisel? Awww.... spoilsport!
Got to say that helping to rip out the kitchen - everything, down to raw floor/walls/roof - at a friends house last summer was serious fun . Not everyday you get to really live out your destructive urges. Better yet was that the old cabinets were fairly sturdy, none of the pressboard crap of today...
Since there appears to be a need for some extra wiring for power anyway, I'll take it very slow (and carefully ) until Patrick says something 'official'.
#257237 - 23/06/2005 15:26 Re: memory board progress [Re: mtempsch]
The manual with revised wiring description are being written at this very moment.
#257238 - 23/06/2005 16:03 Re: memory board progress [Re: schofiel]
mtempsch
Great!
BTW, any chance to pick up a new rotary encoder at the meet? The current one occasionally glitches and jumps the wrong way - often envigorating , but sometimes slightly embarrasing
#257239 - 23/06/2005 16:31 Re: memory board progress [Re: mtempsch]
Yup - I would suggest someone start a thread with a list of "parts wanted" for Amersfoort, and I'll make sure I have the bits ready. Gotta go!
#257240 - 25/06/2005 17:42 Re: memory board progress [Re: mtempsch]
SE_Sport_Driver
Mine must be caught up in Customs... I was order #3 and it's not here. Let's hope I'm not on a terrorist watch list!
#257241 - 25/06/2005 18:35 Re: memory board progress [Re: SE_Sport_Driver]
mtempsch
You bet you are Odd electronics, association with the Hijack guy, obvious suspect Then again, Mark has previously expressed some negativity towards the USPS, so if that's what Patrick used, it might just be normal incompetence and not malice
My progress so far: I got he mainboard out - eventually, that center screw just wouldn't budge! Ended up doing stuff that Rob shouldn't know about Had to reassemble and check that everyhing still worked; all OK. All the pads that'll be under the board are cleaned off with desoldering braid and the boards are completely flat against each other. Now just waiting for the commandments to be handed down before proceeding... Only thing that concerns me is getting that last RAS line in place...
#257242 - 25/06/2005 21:52 Re: memory board progress [Re: mtempsch]
caseyse
Loc: CA, USA
Rec'd 2 of my 3 boards today. I'm going to upgrade one of my mk2 units first, once instructions are available. These are very nice looking boards. Thank you for your time and effort on these Patrick Also, thank you Mark for the expanded memory kernel
Edited by caseyse (26/06/2005 00:08)
#257243 - 25/06/2005 23:40 Re: memory board progress [Re: mtempsch]
In addition to the RAS line, you'll also need to run extra (SHORT!) power and ground signals from the capacitors on the main board just above the main board memory chips over to the capacitors on the memory board. One set of power and ground should do it, I'd think.
Failure to do this may result in all sorts of weird memory errors, or having things appear to work, and then fail when operating at a different temperature.
#257244 - 26/06/2005 23:34 Re: memory board progress [Re: caseyse]
FireFox31
Loc: East Coast, USA
I just found the postal notice saying they tried to deliver my memory board on Saturday. Now I can go pick it up when I ship out buttons in the morning!
But then my only lit player goes to Eutronix for the upgrade. I will be back in the dark ages.
FireFox31
#257245 - 28/06/2005 13:15 Re: memory board progress [Re: schofiel]
alex25
Loc: Switzerland
Any news on the manual for the memory board? Am I right that it is not yet available? (At least I have not found it)
I've got the board yesterday and can't wait to upgrade the player. I don't need a full featured, colored manual. I'm happy with a simple step by step installation guide.
#257246 - 28/06/2005 15:06 Re: memory board progress [Re: alex25]
Only a little while before it's ready.
#257247 - 28/06/2005 16:13 Re: memory board progress [Re: schofiel]
Defiler
Rockin'. Picked up my two boards from the post office today.
#257248 - 18/07/2005 13:02 Re: memory board progress [Re: pca]
Glen_L
Loc: Elk Grove, CA
Patrick,
Any update on when the next batch might be ready?
No longer a stranger, finally a full-fledged member! \:D
#257249 - 23/08/2005 14:26 Re: memory board progress [Re: pca]
Glen_L
Loc: Elk Grove, CA
Bump...is the second batch still on hold? I've held off ordering a larger hard drive and installing 3.0a11 until I have the memory board installed. I believe I was #32 in the queue.
Edited by Glen_L (23/08/2005 14:29)
#257250 - 23/08/2005 14:35 Re: memory board progress [Re: Glen_L]
pupvogel
Loc: Hamburg, Germany
i guess we'll just have to wait...
i have order #2 - pca's last reply in july was they'll go out soon.
too bad there's a great deal of flexibility in the word 'soon'...
well i don't complain as i have no idea yet how i get those boards into my empegs...i really don't think i should do that myself...
Page 2 of 2 < 1 2
