#258298 - 15/06/2005 20:03 802.11 in the car, need help
lamer
Loc: Texas
I want put a Linksys WAP11 in my car so I can d/l songs without removing the unit. I am having a hard time finding a 5V 2.5A car adapter for the WAP11. Any ideas? I am positive I have read about an install including this, but a BBS search came up dry.
MK2a 160GB
11 Years later, these Mk2a units still rock...
#258299 - 16/06/2005 20:55 Re: 802.11 in the car, need help [Re: lamer]
matthew_k
Tonyc's been working on this down in the technical forum:
http://empegbbs.com/ubbthreads/showflat.php/Cat/0/Number/257297/an/0/page/0#257297
#258300 - 17/06/2005 02:41 Re: 802.11 in the car, need help [Re: lamer]
mtempsch
i
A high-current version of a 7805 regulator should do it (or adding a shunt transistor to handle part of the current to a standard 7805. Circuit is i the appl. notes of the 7805, IIRC).
Thatl'l waste a lot though - roughly 20W in heat, so you'd need a fairsized lump of metal to cool it... A switching power supply would be much more efficient, but I have no design handy... lot more complex to build tho...
Another brute force approach would be a 12VDC->110/220VAC switcher and then plug the stock power 110/220VAC->5VDC adapter into that... Also somewhat wasteful, but probably less so than than a 7805...
#258301 - 03/07/2005 11:10 Re: 802.11 in the car, need help [Re: mtempsch]
Derek
Loc: NRW, Germany
a bit more elegant might be to look out a DC/DC converter to do the job. There's quite a range out there these days, and you should find one to handle that current OK
