#260254 - 12/07/2005 18:41 61: failed to open tags...
Ladmo
Loc: Oklahoma
anyone know what THAT means, and how to fix?
#260255 - 12/07/2005 18:42 Re: 61: failed to open tags... [Re: Ladmo]
At a guess it's probably the tags file which is part of the database kept on the empeg.
#260256 - 12/07/2005 19:23 Re: 61: failed to open tags... [Re: tman]
philb
I upgraded my v2 empeg to alpha10 last night, now it rebuilds the database every time it boots, and I get the 61: failed to open tags message on the console. Neither emplode/jemplode will connect to it now :-(
Are there some files I need to delete to get the database to rebuild correctly?
#260257 - 12/07/2005 20:47 Re: 61: failed to open tags... [Re: philb]
Yes. The procedure for doing this is in the FAQ, which is down at the moment (server trouble).
You could simply try synching once with emplode (2.0 final please), and see if that fixes it. If not, we need the FAQ procedure, which I do not have memorized.
#260258 - 12/07/2005 22:59 Re: 61: failed to open tags... [Re: tfabris]
Ladmo
Loc: Oklahoma
I have an old copy of the faq...hard copy. Cannot find anything about tags. Found someother stuff which has not worked yet...If I just reload the player software and hijack, will that wipe out the music on the player, and I have to start from scratch?
I cannot get emplode or jEmplode to see the player in this state, can only use hyperterm to get to it. Well I can try the usb connnection to try to get to the player, but doubtful. Just hangs on that rebuilding the music databases...should I post the serial log stuff from the hyperterm startup session?
#260259 - 12/07/2005 23:05 Re: 61: failed to open tags... [Re: Ladmo]
SonicSnoop
Loc: Triangle, VA
The section I believe Tony is refering to in the faq is the part about connecting to the player with hyperterminal and issuing the ro command and then the various e2fsck commands on the differnt partitions *again the faq is down so I cant be more specific*
#260260 - 12/07/2005 23:09 Re: 61: failed to open tags... [Re: SonicSnoop]
Ladmo
Loc: Oklahoma
Yeah, I got that part, but I only have two different sets of commands and neither of them worked, but I may not have done them correctly. Does it take an increadabley long time for the last part of those commands?
#260261 - 12/07/2005 23:18 Re: 61: failed to open tags... [Re: Ladmo]
SonicSnoop
Loc: Triangle, VA
I wouldnt try this until one of the experts on here comment on it but once I had an issue with database building and had to delete the 3 files in /drive0/var/ think they were database3 playlists and tags, but my problem may not have been the same issue your having so may not be needed...
#260262 - 13/07/2005 00:41 Re: 61: failed to open tags... [Re: SonicSnoop]
Ladmo
Loc: Oklahoma
Here is my serial log, if anyone has any idea/suggesion...
If there is anyone present who wants to upgrade the flash, let them speak now,JSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
or forever hold their peace...it seems not. Let fly the Penguins of Linux!=38760/16/63
e000 v1.04h driver i
Copying kernel...
Calling linux kernel...on 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000
l.Q:
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #11 Tue Apr 1 18:49:59 BST 2003
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel C
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP0001106 ([email protected])
TCP: Hash tables configured (ehash 16384 bhash 16384)re is anyone present who wants to upgrade the flash,
Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 )s of Linux!
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )lling linux kernel...
Starting kswapd v 1.5 done, booting the ke
l.
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART:49:59 BST 2003
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTn 11
empeg dsp audio initialisedrial number 10101787)
empeg dsp mixer initialised
empeg dsp initialisedm
Memory: 15
empeg remote control/panel button initialised.2k data, 4k init)
empeg state support initialised 0089/88c1 (save to d0004f80).er cache hash table entries: 16384 (order 4, 64k)
empeg RDS driver initialised
Page cache hash
POSIX con
empeg single channel IDEersit
smc chip id/revision 0x3349
Starting
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])ersion 4.27 with no seria
b
Partition check:
hdb: [PTBL] [2432/255/63] hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...change_root: old root has d_count=1
Mounting proc
Starting player
! tags.cpp : 61:Failed to open tags (0xc0041002).
#260263 - 13/07/2005 01:07 Re: 61: failed to open tags... [Re: Ladmo]
Delete /empeg/var/database*, /empeg/var/tags, and /empeg/var/playlists, and then do a sync from Emplode.
#260264 - 13/07/2005 02:36 Re: 61: failed to open tags... [Re: mlord]
Ladmo
Loc: Oklahoma
I typed in rm /empeg/var/database*
and the others, and it said that file did not exist...
What am I doing wrong?
#260265 - 13/07/2005 03:40 Re: 61: failed to open tags... [Re: Ladmo]
Mataglap
are you remounting the filesystem rw? see if you have a 'rwm' command. don't forget to remount it read-only when it's all done.
go to the shell
'rwm'
remove the files (DO NOT delete config.ini)
'exit' & watch player rebuild the db.
when it's done go back to the shell
'rom'
'exit'
--Nathan
#260266 - 13/07/2005 10:42 Re: 61: failed to open tags... [Re: Ladmo]
You are doing nothing wrong.
Just do those commands and then tell Emplode to "sync". Wait (and wait..) for it.
Then sync it again.
#260267 - 13/07/2005 11:15 Re: 61: failed to open tags... [Re: mlord]
Ladmo
Loc: Oklahoma
Mark, it tells me that those files dont exist.
I'm ready to start over from scratch, if I can find that darn disk builder software...didn't notice it on the empeg.com site, unless they are just calling it something different...
#260268 - 13/07/2005 11:18 Re: 61: failed to open tags... [Re: Ladmo]
If they do not exist, that is not an issue. Continue following the steps. The commands merely deleted the probably defective database. If the files are not there, that is one less step you need to do. Just continue the exit and rebuild as before.
#260269 - 13/07/2005 11:35 Re: 61: failed to open tags... [Re: pgrzelak]
Ladmo
Loc: Oklahoma
Too late...I only had about 25 gig of music on the player. I have done so much crap it is trashed pretty well...now I need to just start over...
#260270 - 13/07/2005 14:44 Re: 61: failed to open tags... [Re: SonicSnoop]
No. I was talking about the section that describes how to manually rebuild the database files.
#260271 - 14/07/2005 00:37 Re: 61: failed to open tags... [Re: tfabris]
SonicSnoop
Loc: Triangle, VA
my bad..
#260272 - 14/07/2005 06:42 Re: 61: failed to open tags... [Re: tfabris]
AndrewT
Loc: Oxford, UK
Perhaps it might be helpful to include a note in the FAQ on error number 0xc0041002? After loading v3 aplha 10, my player started giving this error in Emplode and searching the FAQ for this number didn't produce any hits.
#260273 - 14/07/2005 09:43 Re: 61: failed to open tags... [Re: AndrewT]
Well, the 0x means it's in hex. The c means it came from the player. The 004 is reserved (it's actually Win32's FACILITY_ITF). The 1 is the player component (in this case, the main player code -- the audio path has a different ID, some of the libraries use different IDs again). The 002 is ENOENT.
File not found, in other words.
#260274 - 19/08/2005 21:49 Re: 61: failed to open tags... [Re: Roger]
jbauer
Loc: San Francisco, CA
I'm getting this error also... Failed to open tags (0xc0041002).
I think I may have caused the problem by copying more mp3 files than I could fit on the player. Now, when I boot the player, it has to rebuild the database, and when I try to load emplode, it does a disk check and then emplode fails without an error code. I get this message when it starts the integrity check:
Adding Swap: 16028k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
So 2 questions:
1) Do I need to delete my databases as outlined above in this thread?
2) Does this happen if I overfill my empeg every time? This isn't very graceful...
- Thanx
- Jon
P.S. I'm using 2.0 release version.
#260275 - 20/08/2005 13:20 Re: 61: failed to open tags... [Re: jbauer]
Delete and manually rebuild the databases, and then try to apply the max_fid patch that Mark wrote. This has done wonders for when I overfill my player...
#260276 - 20/08/2005 23:09 Re: 61: failed to open tags... [Re: pgrzelak]
jbauer
Ok, I think I got the original problem fixed, but now I'm getting...
Vcb: 0x408d7000
serial_notify_thread.cpp: 116:@@ N7
serial_notify_thread.cpp: 117:@@ F0x53da0
serial_notify_thread.cpp: 118:@@ TThere's No Home For You Here
serial_notify_thread.cpp: 119:@@ AWhite Stripes
serial_notify_thread.cpp: 120:@@ GRock
serial_notify_thread.cpp: 180:@@ #53da0 0:00:00
serial_notify_thread.cpp: 170:@@ S0
The weird thing is that I've deleted the album that contains the track that this is referencing. Could it be that I have a track that's dangling with no reference in the FID's or somethin'?
- Jon
#260277 - 21/08/2005 10:48 Re: 61: failed to open tags... [Re: jbauer]
It is happening all the time? I would recommend the following possible tests / fixes...
a) start the player with a -i and see if you can select another playlist
b) search for the deleted file with refs=0
c) look at the playlist you are currently running to see if it has the reference
d) fsck
#260278 - 22/08/2005 21:45 Re: 61: failed to open tags... [Re: pgrzelak]
jbauer
Grrr. I'm back to the empeg re-building the database every time it boots up...
When I look in the /drive0/var directories, I only find one file, in the /drive0/var directory. Nothing else in any of these (from the faq)...
rm /drive0/var/database
rm /drive0/var/database3
rm /drive0/var/tags
rm /drive0/var/playlists
rm /drive1/var/database
rm /drive1/var/database3
rm /drive1/var/tags
rm /drive1/var/playlists
So does this mean that it's not able to successfully build the databases? Could I be completely out of space?
I also get:
Starting player
What's that "tried to mount" message???
- Jon
#260279 - 23/08/2005 03:20 Re: 61: failed to open tags... [Re: jbauer]
mtempsch
Perfectly normal - the software first tries to mount the partition as a reiserfilessystem, but as it isn't a reiserfs (it's ext2) it fails and then goes on to mount it as an ext2 filesystem.
Have you tried clearing and rebuilding? A manual fsck might be an idea as well, just to be sure the filesystems are OK.
#260280 - 23/08/2005 07:57 Re: 61: failed to open tags... [Re: mtempsch]
Agreed. The manual clearing and rebuilding should help. If rebuilding by hand does not work, there are a few shortcuts you can take that might help. This is the command structure I used when I ran into trouble with big databases and problems building them. Try the following sequence:
swapon /swapfile
rw
rwm
cd /drive0/var
rm database
rm tags
rm playlists
player
(let player rebuild databases)
(quit player)
cd /drive0/var
ls (you should see database files here)
rom
ro
swapoff
exit
(reboot)
