#260949 - 20/07/2005 12:48
Really weird networking problem
We have two sites connected by a SDSL link, we run a mix of W2K, NT and Linux machines as well as some Thin Clients with no problems. I've just built a new PC with XP Pro (Full, SP2 etc) but it won't get it to see the other side of the network (i.e. the other location) the SDSL connection is via two Zyxel 782R routers, these have been totally tranparent to the network thus far although they do have addresses assigned.
This is our first XP machine this side of the network and I just can't understand where or what the problem could be.
We use static IPs.
#260950 - 20/07/2005 12:58
Re: Really weird networking problem
[Re: tahir]
I assume that you have tried moving the new machine onto an IP address that another working machine already uses (and of course disconnecting the other machine at the same time).
#260951 - 20/07/2005 13:18
[Re: tahir]
First you claim they're routers, then you claim they're transparent. Those are pretty much mutually exclusive statements, so I'm not quite sure what's going on.
If they're routers, they have to be configured in the host computer as routers, either as the default router or as a static route to another specfic set of networks. Not knowing how your network is set up otherwise I don't know exactly what to tell you other than to compare the routing tables between the new machine and the ones that are working. (Under Windows, this is "route print" from a command prompt.)
If they're transparent, that probably means that they're bridges. I can't think of anything obvious, but they might have some sort of MAC address filtering. Did you or the people your work with set up the currently working computers after the bridge was put in place? If not, can you find the person who did set them up or ther person who installed the bridges and ask if any special configuration was needed on them?
#260952 - 20/07/2005 13:23
[Re: tahir]
Have you tried pinging around? The XP sp2 firewall won't reply to pings by default.
Can everything on the XP side see the XP box? Can the XP box see everything on its side? Where do things seem to fail?
Can your xp box ping the router's local interface? The far side router?
#260953 - 20/07/2005 13:24
[Re: andy]
Quote: I assume that you have tried moving the new machine onto an IP address that another working machine already uses (and of course disconnecting the other machine at the same time).
I'll give that a go
#260954 - 20/07/2005 13:43
Quote: First you claim they're routers, then you claim they're transparent. Those are pretty much mutually exclusive statements, so I'm not quite sure what's going on.
My limited understanding of them is that they can be used as routers and/or bridges in our application they're used as a bridge.
#260955 - 20/07/2005 14:06
[Re: tahir]
Loc: Seattle, WA, U.S.A.
Quote: My limited understanding of them is that they can be used as routers and/or bridges in our application they're used as a bridge.
If they are configured as bridges then a computer at site A would typically use the same IP network and netmask ask computers at site B. Is that so?
Jim
#260956 - 20/07/2005 14:10
[Re: jmwking]
Quote: Have you tried pinging around? The XP sp2 firewall won't reply to pings by default.
Pings both ways on the local side, can ping the local router but not the remote one.
#260957 - 20/07/2005 14:17
[Re: jimhogan]
Quote: If they are configured as bridges then a computer at site A would typically use the same IP network and netmask ask computers at site B. Is that so?
Yes
#260958 - 20/07/2005 14:17
[Re: tahir]
Wait, let's rewind a bit... Quote: but it won't get it to see the other side of the network
Define "see". Precisely, what are you trying to do? What, exactly, are you getting as an error message, if any, when you try to do it?
#260959 - 20/07/2005 14:23
Quote: Define "see". Precisely, what are you trying to do?
Attach it to the network, the WINS server and PDC are at the remote site, it can't therefore join the domain.
Quote: What, exactly, are you getting as an error message, if any, when you try to do it?
The network connection wizard can't see the domain I'm trying to connect to, manually trying to join the domain brings up a very long winded DNS error.
#260960 - 20/07/2005 14:27
[Re: tahir]
Ah. Windows-specific stuff. Okay, first things first.
Make sure to disable all XP firewall features. Make sure that "NetBIOS over TCP/IP" is enabled.
#260961 - 20/07/2005 14:28
Quote: Ah. Windows-specific stuff. Okay, first things first.
It's not just windows stuff: pings are failing, too.
#260962 - 20/07/2005 14:32
Quote: Make sure to disable all XP firewall features. Make sure that "NetBIOS over TCP/IP" is enabled.
Done that
#260963 - 20/07/2005 14:33
[Re: jmwking]
Quote: It's not just windows stuff: pings are failing, too.
You're right, can't ping it from a linux machine at the remote end either
#260964 - 20/07/2005 14:40
[Re: tahir]
Have you rebooted your routers/bridges?
#260965 - 20/07/2005 14:58
[Re: jmwking]
Quote: Have you rebooted your routers/bridges?
I'll be doing that and rebooting the switches too, let you know in the morning if that resolved the issue.
#260966 - 20/07/2005 15:09
[Re: tahir]
Quote: I'll be doing that and rebooting the switches too, let you know in the morning if that resolved the issue.
Might you have an address conflict? If you take new XP machine off net, any chance you can ping that address still?
Was the address previously used elsewhere? If you can look on router/bridge console at ARP entries, does MAC address for that IP match XP machine's NIC?
Jim
#260967 - 20/07/2005 15:22
[Re: jimhogan]
Quote: Might you have an address conflict? If you take new XP machine off net, any chance you can ping that address still?
No addreses conflict, tried it with various IPs, I don't know that the router stores ARP entries in a viewable format, they're not implicitly set by us anyway. Hopefully rebooting them should get rid of that issue???
#260968 - 20/07/2005 15:57
[Re: tahir]
How about more basic stuff... Can the machine communicate with other PCs on its own side of the WAN? In other words, are we sure its NIC and driver and cable are all working?
And do you have another windows-based PC on this same side of the WAN that does work?
Let's also see an output of ipconfig /all for reference. Perhaps also an ipconfig /all for a computer that does work.
#260969 - 20/07/2005 16:04
Quote: How about more basic stuff... Can the machine communicate with other PCs on its own side of the WAN? In other words, are we sure its NIC and driver and cable are all working?
Yes
and
Yes
This is IPCONFIG /ALL from a working PC on the same side of the LAN:
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : flickpc Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : NETGEAR FA310TX Fast Ethernet Adapter r (NGRPCI) Physical Address. . . . . . . . . : 00-A0-CC-D0-0A-C0 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 121.1.0.90 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 121.1.0.30 DNS Servers . . . . . . . . . . . : 213.130.130.99 213.130.128.205 Primary WINS Server . . . . . . . : 121.1.0.254
#260970 - 20/07/2005 16:09
[Re: tahir]
Okay, so let's see an ipconfig /all from the non-working PC for comparison.
#260971 - 20/07/2005 16:09
[Re: tahir]
This si the one that doesn't work:
Windows IP Configuration
Host Name . . . . . . . . . . . . : FLKPC2
Primary Dns Suffix . . . . . . . :
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
on
Physical Address. . . . . . . . . : 00-0D-60-C3-D9-9F
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 121.1.0.40
#260972 - 20/07/2005 16:11
[Re: tahir]
heh. Notice the difference? No DNS on the non-working PC.
This totally reminds me of some of the questions on the Microsoft certification tests. ![](/ubbthreads/images/graemlins/smile.gif)
#260973 - 20/07/2005 16:15
Sorry removed the DNS settings whilst testing (just in case) they've been in there most of the day and I've just retested with them in, still no action.
#260974 - 20/07/2005 16:18
[Re: tahir]
I found the mac address of the remote router/bridge amd manually added an arp entry for it and one of the Linux servers at the remote end, it can ping the router but not the server, it couldn't ping either before.
#260975 - 20/07/2005 16:27
[Re: tahir]
Try forcibly changing the non-working PC's IP address to match the one that works. Either turn off or temporarily change the IP address on the working PC so that it doesn't conflict. See if that makes it work temporarily.
If so, then it's something in the routers that are configured to only accept the traffic from the working PC's IP address.
#260976 - 20/07/2005 17:12
[Re: tahir]
Quote: No addreses conflict, tried it with various IPs, I don't know that the router stores ARP entries in a viewable format, they're not implicitly set by us anyway. Hopefully rebooting them should get rid of that issue???
From what you say here and what you've posted in follow-ups, it does small like an ARP issue (masks look conventional/OK, no DNS dependency -- problem producible at IP level). If bridge is storing misassociated MAC for that IPin ARP table, then that would explain. If you can afford to power cycle bridge/s real soon, I would do that before pulling any more hair (yes, it should clear ARP entries/cache....I always count to 10 while powered off!)
Jim
#260977 - 21/07/2005 07:33
[Re: jimhogan]
Thanks very much guys, it was definitely something in an arp table somewhere, rebooted all switches, routers etc and now everythings OK.
#260978 - 21/07/2005 12:14
[Re: jimhogan]
Incidently, one of my users had a somewhat similar problem this morning (local switched network, one client can't ping the server, everything else OK). The same solution - rebooting the switch, in this case - worked. Sigh! It is not only Windows any more that get tired and require reboot here and there... ![](/ubbthreads/images/graemlins/crazy.gif)
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
