#261603 - 27/07/2005 14:27 Motorcycle Advice
We've got a Harley Davidson Sportster 883. It's the 2002 model.
It was bought brand new. It was driven twice, then garaged for two years. It's still in the garage. We are selling it.
My question:
What is the correct procedure to safely start up this motorcycle for its new owner or potential owner? Do we have to do anything special to the fluids or doodads or doohickeys to prevent damage to it?
#261604 - 27/07/2005 14:41 Re: Motorcycle Advice [Re: tfabris]
jbauer
Loc: San Francisco, CA
My question:
If it has been sitting for 2 years, it is probably fine. Check the rubber bits and make sure they don't look cracked or anything - all rubber: hoses, tires, rubber that's part of the engine, etc. I don't think 2 years would be enough time for the carbs to gunk up from the gas... I'd just check to make sure stuff looks ok, fill the tires with air, and fire it up.
Of course, the battery is probably dead. You can use a car and jumper cables on the original battery safely. I'd done that a dozen times. You may need a new battery if the current one doesn't hold a charge...
- Jon
#261605 - 27/07/2005 15:32 Re: Motorcycle Advice [Re: tfabris]
If you could easily drain the gas I would. I park my bike every winter and drain all the gas. If not, it does not run very well come spring. And, a "missing” motor to a potential buy would not be good.
If it has carburetors drain the fuel from them as well, if not too hard. That will make the first startup a lot easier. Hopefully you’ve kept the battery charged..
#261606 - 27/07/2005 15:48 Re: Motorcycle Advice [Re: tfabris]
Do a basic check-out for fluid levels, tire pressure, and functionality.
Oil and brake fluid shouldn't need any special attention, but the old gas might not be optimal (as suggested above).
If the tank is already low, then just add a full tank of premium and run it a while. With this strategy you'll be able to avoid fiddling with draining fuel at the carbs. I agree that fresh gas would help out with the first start, though. A can of ether is helpful in that department, too.
If you've just let the bike sit with no attention at all, you might need to keep the charger on the battery while attempting to start.
If it's possible to ride it a few hours, do that.
T. Fabris- a Hog owner? Never would I have suspected. Good luck!
#261607 - 27/07/2005 17:46 Re: Motorcycle Advice [Re: tfabris]
TigerJimmy
It will be fine. If it gets cold where you live, you might need to replace the battery. You should definitley charge the battery so it has the best chance of starting for the prospective buyer (it IS a Harley, after all, so nothing is guaranteed).
Seals and rubber parts, etc are all much better nowadays. Same with gas and oil. I think a Harley will burn kerosene, anyhow.
Congratulations.
Jim
#261608 - 27/07/2005 19:43 Re: Motorcycle Advice [Re: tfabris]
matthew_k
Sounds nice, how much are you selling it for?
#261609 - 27/07/2005 21:11 Re: Motorcycle Advice [Re: matthew_k]
Best offer, whatever that turns out to be.
There are some on Ebay for $6400 buy-it-now, but they have a few thousand miles on them. I figure since this one only has 51 miles on it, we can ask $7000.00 or best offer.
You in the Nor Cal area?
#261610 - 28/07/2005 03:01 Re: Motorcycle Advice [Re: tfabris]
Did some googleing and ran across this web page.
