#261894 - 30/07/2005 20:22 Moving full drives from mk 2 to mk 2a
ithoughti
Loc: Boston, MA USA
Hi all,
I tried searching the faq but...
I want to move my 2 drives (10 and 20gb) from my mark 2 and put them in my mark 2a because the mark 2 is stuck in ac mode and I think I need to ship it off to be repaired.
I tried this last year figuring it would be a simple swap (not!) and I got the ol' 'Drive not found' thing. My question is: do I just have to do the normal 'drive upgrade' or is there any way to avoid that hassle?
thanks,
//matt
#261895 - 30/07/2005 21:06 Re: Moving full drives from mk 2 to mk 2a [Re: ithoughti]
It really should be as simple as unplugging from one empeg and plugging into the other since Mk2 and Mk2A firmware/player etc are all the same.
About the only thing I could see messing up is if you swap master/slave on the drives and the second drive doesn't have player software installed.
As long as you don't change anything it should just work (tm).
#261896 - 30/07/2005 21:07 Re: Moving full drives from mk 2 to mk 2a [Re: Shonky]
Posting a boot log would be the first thing to do I'd say.
#261897 - 01/08/2005 03:54 Re: Moving full drives from mk 2 to mk 2a [Re: ithoughti]
A possibility is that on the primary drive you may have inserted the cable off by one pin. That is surprisingly easy to do.
