#263448 - 24/08/2005 17:50 Hard Drive Replacement
faceless041974
Loc: Chicago, IL
Anyone know what the largest hard drive you can put in the player is? So far the biggest Ive found is 120 gig.
#263449 - 24/08/2005 17:55 Re: Hard Drive Replacement [Re: faceless041974]
The only real limit is physical size, and I think all new drives are small enough to fit in. Also, higher capacity drives require a special procedure for installation, but that's a one-time deal per drive. 120GB seems to be as big as they get these days.
#263450 - 24/08/2005 18:08 Re: Hard Drive Replacement [Re: wfaulk]
One thing is that if you have an incredibly huge DB then you might need more RAM. You'll probably want to do the set max FID for the dynamic data partition hack on the player binary as well.
#263451 - 24/08/2005 19:39 Re: Hard Drive Replacement [Re: tman]
Greetings!
There should be no trouble at all with the 120GB. There are a few small things to be aware of, as mentioned above, but there is nothing that should stop you. I am personally holding off for perpendicular storage at the moment, but the theoretical maximum is 2x120GB.
#263452 - 24/08/2005 19:42 Re: Hard Drive Replacement [Re: pgrzelak]
Just to clarify, thats with the largest laptop HDs out currently. The empeg will support much larger drives than that because Mark Lord added LBA48 support.
#263453 - 24/08/2005 19:55 Re: Hard Drive Replacement [Re: tman]
Seagate 160GB drives will be out later this year, with a promise of larger drives soon after. Perpendicular is the next major step forward for drive makers, so you will see a lot of vendors leapfrogging capacities in the near term.
As long as you are IDE, you should be okay.
#263454 - 24/08/2005 20:02 Re: Hard Drive Replacement [Re: pgrzelak]
Argh. I keep getting reminded of that crazy flash animation every time somebody mentions perpendicular HD technology!
At the moment, all the drives that have been announced that use perpendicular tech appear to be 1.8" drives like the one used in iPods. Once they get it into desktop drives then we'll be getting 1TB sizes which will be good
#263455 - 25/08/2005 07:52 Re: Hard Drive Replacement [Re: tman]
Actually, Seagate has announced a 160GB 2.5 inch drive for the November timeframe. The other players are soon to follow in early 2006 with 180, 200 and beyond. They are talking about getting even higher densities into 2007, upwards of 300GB.
As for the flash animation, it really reminded me of the old Schoolhouse Rock episodes...
#263456 - 05/01/2006 14:54 An old thread... Perpendicular Drives [Re: pgrzelak]
Greetings!
Thanks to all the people who pointed out to me that the new Seagate Momentus 5400.3 160GB laptop hard drive using perpendicular storage will become available in February. Still, their list price of $375 per drive is a bit extreme at the moment, especially when I still have a few GB free with dual 100s... Tempting...
#263457 - 05/01/2006 15:06 Re: An old thread... Perpendicular Drives [Re: pgrzelak]
Waterman981
Loc: Salt Lake City, UT
Looking at that release statement, it appears they are selling it as an external USB 2.0 drive. Hopefully they will realize people will want it in their notebooks, and sell it without the markup for the enclosure. If not you could always ebay the enclosures.
-Michael
#040103696 on a shelf
#263458 - 05/01/2006 15:18 Re: An old thread... Perpendicular Drives [Re: Waterman981]
Well, the enclosure variation (S-ATA also) are a few months later, if I read it correctly. The bare drives should ship sooner (I hope).
#263459 - 05/01/2006 19:59 Re: An old thread... Perpendicular Drives [Re: pgrzelak]
schofiel
OK guys, form an orderly queue here.
#263460 - 10/01/2006 17:20 Here they come! [Re: schofiel]
Resistance is futile.
Must... resist... 320GB empeg...
#263461 - 30/01/2006 21:02 Re: Hard Drive Replacement [Re: pgrzelak]
Snowshoe
Loc: Midwest
On that same page is a laptop drive I'm looking forward to put in the Empeg when available. The Endurastar's are suppose to operate in ranges of -20°C to +85°C and supposedly more suited for automotive uses e.g. navigation & the like.
#263462 - 30/01/2006 21:32 Re: Hard Drive Replacement [Re: Snowshoe]
Ah, but the capacity!!! Wasn't there a tread where Hugo or Rob had a few of these drives as "samples"???
#316960 - 04/12/2008 16:29 Re: Hard Drive Replacement [Re: pgrzelak]
thenominous
Well, I've just got a Seagate Momentus 160Gb drive and tried it out.
With mlords big disk builder.
No dice.
The serial output shows it trying todetect it, fails then kernel panics.
It aint power. The seagate label suggests 0.487A, I tried an old travelstar with a 1.1A requirement and it works fine. Spinup surely wont take that much more, besides, it does spin up ok.
From various testing at work with hard drives in our products (this one was a sample. perks) I've been finding issues with spin up times (was causing us problems) and drives not actually being ready before the OS starts looking for them.
Has anyone had a similar problem with dries in the empeg?
Is anyone running a Seagate momentus 160Gb drive?
I can grab an 80Gb tomorrow and try that out. Surely it wont be a capacity issue with mlords big disk upgrade?
Edited by thenominous (04/12/2008 16:33)
Edit Reason: clarification
#316961 - 04/12/2008 16:31 Re: Hard Drive Replacement [Re: thenominous]
thenominous
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30103019) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffc0
ide_data_test: wrote 0xffff read 0xffc0
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x57c0
ide_data_test: wrote 0x0000 read 0xff00
ide_data_test: wrote 0xffff read 0xff00
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9160821A, ATA DISK drive
ide_data_test: wrote 0x0000 read 0xffa5
ide_data_test: wrote 0xffff read 0xffa5
ide_data_test: wrote 0xaaaa read 0xaaa5
ide_data_test: wrote 0x5555 read 0x55a5
hda: ST9160821A, 152627MB w/8192kB Cache, CHS=19457/255/63, LBA48
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:cb
Partition check:
hda: unknown partition table
VFS: Mounted root (ext2 filesystem). ½Õ¹ÑõÅ)5ÿEXT2-fs: unable to read superblockv0.03 (19980601) ѽÉõÉÍ¥éõÅÁÉÑ
Kernel panic: VFS: Unable to mount root fs on 03:05)5?¦&'¦ÝõÁ±Ý
¹Ñõɱ±¥µ¥ÑõÁ)5VÓª±­Í¥éõÅÁÉѱ½ )kk«kÍå½¹¹½Ù¥
#316963 - 04/12/2008 16:48 Re: Hard Drive Replacement [Re: thenominous]
Nothing wrong in that boot log -- the drive is working perfectly normally, as is the kernel.
But what *is* wrong, is that the builder has not successfully built the drive prior to this boot attempt.
#316972 - 04/12/2008 20:02 Re: Hard Drive Replacement [Re: mlord]
Yeah, a 160 should work with the bigdisk builder, right? I'd say, try running the builder again. Did you already try it more than once?
#317062 - 08/12/2008 14:18 Re: Hard Drive Replacement [Re: tfabris]
thenominous
Yeah I tried it a couple of times and it sort of hung part way through I forget exactly where now, but was during the windows process.
I know the 20Gb one just sailed through after I removed the 160GB one. I didn't have to re-run the windows app I think ?
I'll blank the disk totally and try it again.
Then try the 120 if I'm unsuccesful.
#317070 - 08/12/2008 16:46 Re: Hard Drive Replacement [Re: thenominous]
thenominous
OK back at home now.
Trying the 160Gb I get this:
It sits at that for ages, then I get this:
Then I hook up PuTTy and power cycle the empeg and I get this:
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0005800).
ide_data_test: wrote 0x0000 read 0xffc2
ide_data_test: wrote 0xffff read 0xffc2
ide_data_test: wrote 0xaaaa read 0xaa82
ide_data_test: wrote 0x0000 read 0xff42
ide_data_test: wrote 0xffff read 0xff42
ide_data_test: wrote 0xaaaa read 0xaa02
ide_data_test: wrote 0x5555 read 0x5740
ide_data_test: wrote 0x5555 read 0xff42
ide_data_test: wrote 0x0000 read 0xff40
empeg-pump v0.03 (19980601)
Press Ctrl-A
So no dice then.
With the 120Gb and just the power cycle, I first get this:
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0x5555 read 0x5580
hda: ST9120822A, ATA DISK drive
Then this after a very check power cycle (hard power hardly removed):
ide_data_test: wrote 0x5555 read 0xffa5
Now, for the empeg this is possibly a shot in the dark on my part, but it tallies with some of the problems I mentioned earlier with newer hard drives requiring much longer spin up times.
The second attempt at detecting the 120Gb seems to have found it much faster.
I assume that is what the above info refers to ?
I can get the 160Gb to appear in the serial output in the same manner, quickly recycling the power to the empeg.
So, is it possible to have some sort of wait cycle placed into the kernel before an attempt is made to detect the hard drive?
This is what I've had to do at work to make hard drives work correctly.
e.g. Spin up till drive ready times are running at 16 seconds !!! on newer Seagate SV35.4 drives.
P.S: 120Gb installs ok, but really want to use the 160Gb :o)
Is there a reset header on the PCB which I can trip to reset the empeg without having to lose the power? I wondered about tripping the 3.3V jumpers but that doesn't sound like a hugely fantastic idea.
That way I can keep drive power but restart the kernel over.
#317071 - 08/12/2008 17:03 Re: Hard Drive Replacement [Re: thenominous]
You are getting the pump error when running the builder upgrade file? Or just when you try to install fresh player software after the builder failed?
Remember that the builder must run to completion and reach the stress test before you can even think about installing fresh player software. Make sure you're following all the steps in the drive upgrade guide to the letter.
Check this FAQ entry regarding the pump error:
I get a 'pump' error when I try to upgrade my player firmware.
#317072 - 08/12/2008 17:05 Re: Hard Drive Replacement [Re: thenominous]
If there's an active Hijack kernel in flash, I think it's got a "Reboot Machine" option on its main menu somewhere.
#317073 - 08/12/2008 17:06 Re: Hard Drive Replacement [Re: thenominous]
thenominous
OK, now I've done the 160Gb and here is how...
When the instructions say to leave the empeg off I've ignored them and left it turned on in a state of kernel panic.
When the builder says it's looking for the empeg I have very rapidly switched the power to the empeg on and off.
This seemingly doesn't give the drive enough time to spin down and allows the disk builder to see it.
If I repeat the process following the builder instructions and leave the emepg turned off before detection, the pump fails everytime.
I can only assume this is because the system didn't have enough time to find the disk.
mlord; could Hijack possibly hold up the kernel from detecting the hard drive for a configurable period? Or would that have to be done elsewhere, ie: a custom build of the main kernel?
So, now I have a built drive. I cannot fail to get the system to see it. Maybe now it's warmed up the system is able to detect it better?!?!
I know I've had problems detecting a disk in the past which has been out in the car all night in winter.
No have the player software installed. Will leave it off till tomorrow and see if it has trouble detecting the disk then after a long cool down.
#317076 - 08/12/2008 17:19 Re: Hard Drive Replacement [Re: thenominous]
Is that what you've got? Sixteen seconds is probably long enough to defeat the caching algorithms, which pre-load about the first ten seconds of upcoming tracks in the hope that that's easily long enough to spin the drive up (the worst ones we could then find were about five seconds).
#317077 - 08/12/2008 17:21 Re: Hard Drive Replacement [Re: thenominous]
That's good sleuthing. I'll update the FAQ entry about "Bad Pump".
#317078 - 08/12/2008 17:24 Re: Hard Drive Replacement [Re: peter]
thenominous
Peter:
No, but to give those as an example. Perhaps poorly. They are 3.5" drives designed for the DVR and set top box markets.
Shocking isn't it.
I'm running a Seagate Momentus 5400.3 drive, the specs annoyingly don't say for this drive:
http://www.seagate.com/docs/pdf/datasheet/disc/ds_momentus_5400.pdf
I'll see about asking our contact tomorrow for the figure.
Tony:
The player software seems to detect the drivee a lot better. It certainly takes longerfrom watching the debug before it goes looking for it!
Edited by thenominous (08/12/2008 17:27)
#317083 - 08/12/2008 18:42 Re: Hard Drive Replacement [Re: thenominous]
I'm not touching it for now (too easy to break it). You can rebuild the kernel from source, and change the detection logic as needed for your setup.
The file is linux/drivers/block/ide-probe.c .
Look for the line "timeout = (HZ/4);".
Make that a bigger number (say, (HZ) instead of (HZ/4) and give it a try.
HZ means "one second".
Edited by mlord (08/12/2008 18:43)
#317111 - 09/12/2008 04:33 Re: Hard Drive Replacement [Re: mlord]
Ross Wellington
Hi,
I have used the Western Digital WD2500BEVE 250 GB Drives and have never had a problem with spin-up time. They seem to spin up within a few seconds (both drives) in empegs.
Is the Seagate that much slower?
I haven't had any trouble installing drives in my empegs.
#317120 - 09/12/2008 12:22 Re: Hard Drive Replacement [Re: Ross Wellington]
He's using a slow 3.5" desktop drive, rather than the usual snappy notebook drive.
