#264403 - 05/09/2005 12:58
Scripted telnet access from Windows
So, we've got a managed switch in our lab that I'd like to reconfigure as part of our automated build process. It's got telnet access, so it should be fairly easy.
What I want are pointers to programs like 'chat' (the one that used to be used with pppd), but that run on Windows and talk telnet.
Suggestions?
#264404 - 05/09/2005 13:09
Re: Scripted telnet access from Windows
[Re: Roger]
puTTY ?
EDIT: Oh wait, are you specifically after scriptable clients? I suppose so, from the subject line.
Edited by mlord (05/09/2005 13:10)
#264406 - 05/09/2005 14:04
[Re: Roger]
Quote: Suggestions?
Expect?
#264407 - 05/09/2005 14:05
Quote: EDIT: Oh wait, are you specifically after scriptable clients? I suppose so, from the subject line.
Yeah. The switch has a telnet-accessible command-prompt configuration interface. I want to connect to it, wait for 'Username', send the username, wait for 'Password', send the password, wait for '#', send the command sequence, wait for 'OK', send another command, and so on...
Kinda like I used to have to do with 'chat' with dial-up PPP connections on Linux.
This should all be scriptable from the Windows command line. I don't need any kind of GUI, since it'll all be unattended (when I've finished).
I found a copy of 'expect' in Cygwin, but I don't know if it'll do what I want, and I don't know how to use it, anyway.
I'll take a closer look at your list later, thanks.
#264408 - 05/09/2005 14:22
[Re: peter]
Quote: Suggestions?
Expect?
Yes, expect is ideal for this task. I've used it before to do exactly this. Basically you give it a string to send, then a range of strings to 'expect' that can trigger different responses. You can set a timeout clause that will trigger if none of the other responses get triggered first etc.
I also used expect to modify my hijack Makefile - I modified the 'install' target to call an expect script that would ftp hijack to my player and reboot it if successful.
#264409 - 05/09/2005 15:22
[Re: genixia]
My install script does something similar, but without expect. It actually performs a full readback of the kernel from flash and compares with the original to ensure correct flash contents before rebooting:
echo "Sending kernel.." ftp -n >/dev/null <<-EOF open $IP
#passive site popup 99 Downloading kernel.. put $ZIMAGE /proc/empeg_kernel site popup 99 Waiting for readback.. get /proc/empeg_kernel /tmp/junk site popup 0 Done. quit EOF bytes=`ls -l $ZIMAGE|awk '{print $5}'` dd if=/tmp/junk bs=$bytes count=1 2>/dev/null | diff $ZIMAGE - if [ "$?" = "0" ]; then echo "Success!" else echo "FAILED -- try again!" exit 1 fi rm -f /tmp/junk 2>/dev/null echo "Rebooting.." ftp >/dev/null <<-EOF open $IP
site reboot EOF
#264410 - 05/09/2005 18:56
[Re: Roger]
Loc: Florida, USA
You need:
ActivePerl (Since this is on Winders)
Net::Telnet (from Perl CPAN)
Net::Telnet::Cisco automates my whole Cisco switch/router subnet, its a joke how easy it is.
Edited by shadow45 (05/09/2005 18:58)
::: shadow45
#264411 - 05/09/2005 20:19
[Re: shadow45]
Quote: Net::Telnet::Cisco automates my whole Cisco switch/router subnet, its a joke how easy it is.
Looks good. Unfortunately, this is a D-Link .
#264412 - 06/09/2005 03:36
[Re: Roger]
Loc: New Orleans, LA
Sounds like just about any mud client I've used. Portal was my favorite, tinyfugue is also nice.
#264413 - 06/09/2005 17:07
[Re: Roger]
Loc: Florida, USA
Net::Telnet will let you automate any telnet session. I've used it for tons of things Net::Telnet::Cisco is for IOS.. makes it *even* easier
::: shadow45
