#265263 - 16/09/2005 00:02 Automatically dial a network connection without logging on to Windows
I have an XP Pro machine that I want to automatically connect to our company VPN from an offsite location.
It will be connected to a remote LAN behind a firewall so internet access will already be there. I just want it to automatically connect to the VPN so it's visible on the company LAN.
So I think I want something to run as a service and start the VPN connection.
Currently, my only solution is a use TweakUI to automatically log on and then have a shortcut to the VPN connection in the Startup folder. The VPN connection is set to automatically connect and not ask for a username and password.
Any ideas guys? Things like Firedaemon only seem to run programs. I can't work out how to start/stop network connections via command line or any other program.
#265264 - 16/09/2005 00:09 Re: Automatically dial a network connection without logging on to Wind [Re: Shonky]
robricc
Could you make a batch file that says "start link_to_shortcut.lnk" and have Firedaemon run the batch file?
#265265 - 16/09/2005 00:16 Re: Automatically dial a network connection without logging on to Wind [Re: robricc]
I thought that would work for sure (kicked myself for forgetting about 'start' since I have used it a bit). I created a shortcut to the VPN connection. Then to test I just ran "start VPN.lnk" from a command shell. It just opened a new command shell . Double clicking VPN.lnk correctly starts the connection though.
Thanks for the idea though.
#265266 - 16/09/2005 00:16 Re: Automatically dial a network connection without logging on to Wind [Re: robricc]
robricc
cmd /k "link to shortcut.lnk"
also seems it may work in a batch file.
#265267 - 16/09/2005 00:17 Re: Automatically dial a network connection without logging on to Wind [Re: Shonky]
It would appear that "start xxxx.lnk" is the same as "start" i.e. start doesn't support .lnk shortcuts.
#265268 - 16/09/2005 00:20 Re: Automatically dial a network connection without logging on to Wind [Re: robricc]
No dice there either
#265269 - 16/09/2005 00:22 Re: Automatically dial a network connection without logging on to Wind [Re: Shonky]
robricc
hmm, the cmd /k thing seems to work for me (from the command line at least). I recall 'start' being able to execute shortcuts in the past. Has this changed in XP (not working for me in XP either). Well, that's all I got...
#265270 - 16/09/2005 00:26 Re: Automatically dial a network connection without logging on to Wind [Re: robricc]
Yeah cmd /k works on an .exe shortcut, but not on a network connection shortcut. "start" is not working on any .lnk files as you are also seeing.
Thanks for your time Rob. Hopefully someone else will pop in with an idea.
#265271 - 16/09/2005 00:38 Re: Automatically dial a network connection without logging on to Wind [Re: Shonky]
robricc
Can rasdial dial a VPN?
Sorry, I don't have a VPN to dial into, so I'm just pulling at strings.
#265272 - 16/09/2005 01:03 Re: Automatically dial a network connection without logging on to Windows [Re: Shonky]
I'll bet it can be done with a rundll call..
Edit: Yeah, what Rob said.
#265273 - 16/09/2005 02:48 Re: Automatically dial a network connection without logging on to Wind [Re: robricc]
It would appear so Thanks Rob. It's connecting to the VPN fine from the command line (although I still need to supply a username and password which I don't think I should). I just need to get that to run as a service and I'm set.
Thanks for the help. My googling did't even come close to those articles I don't think. My search-fu wasn't working well today. I didn't even think to use "RAS" anywhere.
