#266421 - 29/09/2005 20:27 Cannot Install Logo Editor or HiJack
faceless041974
Loc: Chicago, IL
Whenever I try and install Logoeditor I get a manufacturers code not found message. Any idea what this means?
#266422 - 29/09/2005 22:07 Re: Cannot Install Logo Editor or HiJack [Re: faceless041974]
Please be more specific.
Do you get the error message when you try to install Logoedit? If so, please describe exactly how you're installing logoedit.
Do you get the error message when you try to install Hijack USING logoedit? If so, please paste all text from the screen into a message here.
In the meantime, I will assume the latter and will look for that text in the upload.exe code.
#266423 - 29/09/2005 22:11 Re: Cannot Install Logo Editor or HiJack [Re: tfabris]
Okay, if the text is...
found empeg unit: entering program mode
Error: Couldn't find manufacturer ID!
Then the problem is with the serial connection.
I'd say a bad serial cable, or something wrong with the serial port on the computer in question. Try installing it from a friend's computer, and troubleshoot the serial connection by trying this.
#266424 - 29/09/2005 22:56 Re: Cannot Install Logo Editor or HiJack [Re: tfabris]
faceless041974
Loc: Chicago, IL
I checked the serial cable using the directions in your post and everything came up like I had the developer software but Im unsure what to do after this considering I cannot seem to get a connection anywhere else.
#266425 - 29/09/2005 23:05 Re: Cannot Install Logo Editor or HiJack [Re: tfabris]
faceless041974
Loc: Chicago, IL
When I run Logoedit, after selecting the port and choosing the kernal flash utility is when Im receiving the cannot find manufacturer id message. I do not have hijack installed. I am getting the message when I click on the .zimage file. I have also tried to reinstall the firmware and it cannot locate my player. I get the following message when trying to upgrade the firmware: Error "Car player not found. Check your serial connection and ensure that hyperterminal (or similar) is closed" occurred during stage 0x00
When I checked the serial port in Hyperterminal this is what I got on my screen
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
(release)) #12 Tue Apr 1 18:51:41 BST 2003
empeg-car player (hardware revision 9, serial number 10102047)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005300).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHT2080AT, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: FUJITSU MHT2080AT, 76319MB w/8192kB Cache, CHS=9729/255/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:f
f
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init player.cpp
03/04/01.
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0005380).
f
Partition check:
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00 20
03/04/01.
Vcb: 0x4086d000
Edited by faceless041974 (29/09/2005 23:14)
#266426 - 30/09/2005 06:42 Re: Cannot Install Logo Editor or HiJack [Re: faceless041974]
Very odd.
So in hyperterminal, can you control the player by typing commands? For instance, can you press N <enter> and it will go to the next track?
If you can do that, but logoedit doesn't communicate properly with the player at such an early stage in the kernel image process, then I'm rather stumped. It should Just Work.
I believe that I and others have suggested as many as three times now, in two different threads, to try doing the work on a friend's PC, i.e., a computer with a different serial port. Did you ever get around to trying that?
#266427 - 05/10/2005 15:28 Re: Cannot Install Logo Editor or HiJack [Re: tfabris]
faceless041974
Loc: Chicago, IL
OK I installed HiJack but I cannot control the player in Hyperterminal. Im also getting the error message described in my last other posts. I also tried installing emphatic and jemplode and cannot get either one to work and there are no instructions on using them on their sites. I cannot type commands in hyperterminal. When I connect this is what Im getting:
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v440 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Sep 23 15:03:11 EDT 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 10102047) 16MB DRAM
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Tuner: loopback=0, ID=-1
empeg state support initialised 0089/88c1 (save to d0004b80).
f
Partition check:
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
It says that hijack uninstalled serials is this why they arent working on my computer?
#266428 - 05/10/2005 16:48 Re: Cannot Install Logo Editor or HiJack [Re: faceless041974]
Sometimes you can't send commands to the player unless you've power cycled after starting hyperterminal. Try this.
1. Unplug the power to the player.
2. Start Hypterterminal and connect to the player via the serial port.
3. Plug in the power to the player.
4. Use the front panel to select a playlist on the player. If any error messages appear, make sure to clear them.
5. From hypterterminal, press N <enter> and see if it switches to the next track.
No. That is a normal message and it refers only to an onscreen menu.
#266429 - 06/10/2005 08:33 Re: Cannot Install Logo Editor or HiJack [Re: tfabris]
schofiel
That's because you have your terminal settings wrong: you should have it set with No Handshaking.
#266430 - 06/10/2005 13:48 Re: Cannot Install Logo Editor or HiJack [Re: schofiel]
Yeah, what Rob said. It's critical that you set the terminal settings correctly, exactly according to the screen shots here.
