#268142 - 26/10/2005 21:43 Java Handle Leaks
Azureus slows down my Windows machine. Way down. Other people seem to have similar complaints. I think I've found the cause. Despite limiting my peers to 150, there are 9740 open \Device\Afd\Endpoint handles. They seem to be handles for network connections. So it seems that either Azureus or Java itself is leaking handles. I thought I'd first ask our resident Java experts if they know of any such leak within Java before I go delving into Azureus code.
Anyone know anything?
#268143 - 26/10/2005 23:56 Re: Java Handle Leaks [Re: wfaulk]
mcomb
Loc: San Carlos, CA
I'm not even going to pretend to know what that is, but is it possible that some of these connections are in a FIN_WAIT/TIME_WAIT state? Due to the nature of bittorrent I would expect a lot of connections coming and going even if you've limited the number of actual accepted connections.
-Mike
#268144 - 27/10/2005 02:06 Re: Java Handle Leaks [Re: mcomb]
Yeah, but ten thousand?
#268145 - 27/10/2005 10:23 Re: Java Handle Leaks [Re: wfaulk]
I know that it doesn't effect all installs of Azureus. I use it 24/7 with dozens of torrents and have never seen any slow down (not the latest versions anyway, some of the early ones could get a bit chuggy).
#268146 - 27/10/2005 14:54 Re: Java Handle Leaks [Re: andy]
Can you do me a favor and run Process Explorer against it and see if the Java process has a whole load of handles? Maybe your OS install, for some reason, handles having that many open better than mine.
#268147 - 27/10/2005 16:24 Re: Java Handle Leaks [Re: wfaulk]
It does indeed have over 40,000 of those handles open. Clearly a leak of some sort.
As I say I don't have any performance problems with Azureus. This is on WinXP Pro, 2GB of RAM and a P4 2.8Ghz (with HyperThreading enabled).
Azureus is running under Java jre1.5.0_04 on my machine.
#268148 - 27/10/2005 21:08 Re: Java Handle Leaks [Re: andy]
schofiel
What I would suggest is a NETSTAT /A from a CMD command line to observe the state of any socket connects that might be open.
#268149 - 28/10/2005 06:35 Re: Java Handle Leaks [Re: schofiel]
Mine shows a few dozen BT connections as established, certainly not the 40,000 that Process Explorer shows.
