#270510 - 23/11/2005 23:27 Hard Drive Update
jaytothez20
Loc: Nebraska
My Hard drive needs upgraded to hold all my music, anyone recommend a good hard drive i can add to my player??
Thanks,
Jason
#270511 - 25/11/2005 06:00 Re: Hard Drive Update [Re: jaytothez20]
pedrohoon
Hi,
Firstly try searching the forums for 'hard drive/disk'.
You may want to post a question like this in the General section of the forums instead.
Also be sure to read the FAQ linked at the top of the page.
Good luck!
Peter.
#270512 - 25/11/2005 08:15 Re: Hard Drive Update [Re: jaytothez20]
CrackersMcCheese
Any laptop harddrive (9.5mm). Hitachi Travelstar doesn't seem to be too bad. I've used them for years in my empeg. Remember that the player can't make use of a high rpm drive and it just generates heat and will be more power hungry. Lower rpm ones will be fine.
#270513 - 25/11/2005 10:00 Re: Hard Drive Update [Re: CrackersMcCheese]
Just to clarify, you can put a 7200RPM drive in if you really want but there is no point since the empeg doesn't need it.
#270514 - 25/11/2005 11:53 Re: Hard Drive Update [Re: tman]
And for that matter, even 11-12mm drives are usually fine .
