Getting the following exception with the subject Java version with both FireFox 1.0 and IE 6 under Windows XP. I first got a different exception having to do with icons using 0.1.4alpha6 so I thought I should move to the latest version, which now gives this exception instead. Let me know if you need more information about my configuration.
Bill
Exception in thread "AWT-EventQueue-12" java.lang.SecurityException: class "trio.TRioUnitIntegerSetting"'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(Unknown Source)
at java.lang.ClassLoader.preDefineClass(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at sun.rmi.server.LoaderHandler.loadClass(Unknown Source)
at java.rmi.server.RMIClassLoader$2.loadClass(Unknown Source)
at java.rmi.server.RMIClassLoader.loadClass(Unknown Source)
at sun.rmi.server.MarshalInputStream.resolveClass(Unknown Source)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at sun.rmi.server.UnicastRef.unmarshalValue(Unknown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at trio.TRioUnit_Stub.getSetting(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.updateSettings(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.getPlaybackButtonPanel(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.getPlaybackPanel(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.init(Unknown Source)
at trio.applet.TRioAppletPlayerPanel.<init>(Unknown Source)
at trio.applet.TRioApplet.getUnitApplicationPanel(Unknown Source)
at trio.applet.TRioApplet$2.stateChanged(Unknown Source)
at javax.swing.JTabbedPane.fireStateChanged(Unknown Source)
at javax.swing.JTabbedPane$ModelListener.stateChanged(Unknown Source)
at javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
at javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
at javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
at javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
at javax.swing.plaf.basic.BasicTabbedPaneUI$Handler.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
