Well, all, I regret to say that after attempting the mem upgrade, I have failed and also killed my empeg in the proces. I've been soldering for more than half my life, so I thought I would be up to the task - but I suppose that I wasn't. Here is my taile of woe and horror.
I followed the instructions to dissaemble the empeg and smoothed down the extra solder on the test pads where the memory board would go. I also ground down the tip of my soldering iron so that I would fit nicely into the holes.
After adding some matching everything up, I taped the board into place and began filling the wholes. Then I added the two leads onto the capacitors. I decided to test it on just the 48MB before doing the challengin 64 MB line and after flipping the dip switchs 1 and 4 to off, I plugged it in and booted.
It booted fine, but no extra DRAM:
empeg-car bootstrap v1.02 20001106 ([email protected])
If there is anyone present who wants to upgrade the flash, let them
speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux..................................... done, booting
the ker.Linux version 2.2.17-rmk5-np17-empeg52-hijack-v444
([email protected]) (gcc versio5
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 10101307) 16MB DRAM
Command line: mem=16m
etc...
So I rechecked the connections - made sure that I had continuity and heated up the poads under the cpu again.
This time:
c1000000: wrote ffffffff, read efffffff
the wrote/read was changing which lead me to believe that I just had a bad connection some where.
So I when through the connections again. to no avail.
I went through this scenario several times without success and began doing one contact at a time between reboots.
It go to the point that after one resoldering of a contact, the empeg would not boot up. The red LED would not light up either, but the blue led in the ethernet connection would light up.
So I believed that I had bridged something under the board, so I used the braid to clean out the holes and lifted the board. To my horror, the test pads came up with it. I disconnected everything and still the empeg will not even post.
I have included the horrific pictures of the aftermath and on one is an arrow to the last contact that I attempted to solder. It was after this one that the empeg stopped working.
Is there anyway I can get this fixed? maybe a jumper wire?
Here is the last full boot message I got out of it:
speak now,
e000 v1.04
Copying kernel...
([email protected]) (gcc versio5Processor: Intel StrongARM-1100 revision 11
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9bb84
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface.
edit : Fixed title
--l0ser
