#276078 - 14/02/2006 19:56 No leaks (memory or otherwise) here
So this is what I've done with some of my spare time in the last little while.
Started as a Christmas gift for my girlfriend - but it's something I have to keep giving because I seem to be responsible for maintenance, development and population: http://www.pricenetwork.ca/gallery/index.php?cat=22060
#276079 - 16/02/2006 03:26 Re: No leaks (memory or otherwise) here [Re: hybrid8]
RobotCaleb
So... you're growing plants in a jar?
Sweet.
#276080 - 16/02/2006 08:26 Re: No leaks (memory or otherwise) here [Re: RobotCaleb]
Yeah, but no leeks.
#276081 - 16/02/2006 09:21 Re: No leaks (memory or otherwise) here [Re: peter]
Yeah, but no leeks.
It's the right time of year to be planting 'em
EDIT: Fixed formatting error
Edited by robricc (16/02/2006 11:34)
#276082 - 16/02/2006 13:06 Re: No leaks (memory or otherwise) here [Re: RobotCaleb]
[pirate]Aye, it be an Aquarium.[/pirate]
Empeg-style of course. CO2 being injected from a 10lbs cylinder and now being controlled by an electronic pH controller. The filter has built-in heater with digital temperature readout.
I just wish I had all this stuff connected to ethernet. Yes, I suppose you might be able to find some ultra expensive controllers that will give you all this monitoring as an ip device. Maybe for a bigger tank when I nest move. This one was a Christmas gift for my girlfriend.
#276083 - 16/02/2006 15:57 Re: No leaks (memory or otherwise) here [Re: hybrid8]
Try this. A friend of mine bought a couple of this sort of thing which had ADC/DAC/digital I/O lines for controlling something not entirely dissimilar to your project.
#276084 - 16/02/2006 16:32 Re: No leaks (memory or otherwise) here [Re: pca]
Would this be of use? Simple to set up.
EDIT: Found better site
Edited by andym (16/02/2006 16:34)
#276085 - 16/02/2006 16:39 Re: No leaks (memory or otherwise) here [Re: andym]
Both those solutions would be great.... If I had monitors that could be connected to them and if I knew how to develop any of this myself. I was thinking more along the lines of something I would just plug in and use. As far as developing stuff, I've already got my plate full and it's already racking my nerves.
#276086 - 16/02/2006 17:21 Re: No leaks (memory or otherwise) here [Re: andym]
Now that's a pretty cute one, I'll admit. I've not seen those before.
#276087 - 16/02/2006 17:49 Re: No leaks (memory or otherwise) here [Re: hybrid8]
The site player at it's simplest is just simple embedded commands in HTML, it takes very little setup I'm told.
#276088 - 16/02/2006 17:57 Re: No leaks (memory or otherwise) here [Re: andym]
Yeah. It is very basic in terms of what it can do. You need another uC to actually do any useful work with it unless you're happy with it just showing you the on/off status of it's I/O lines.
#276089 - 16/02/2006 19:49 Re: No leaks (memory or otherwise) here [Re: tman]
