#277573 - 13/03/2006 23:07 config.ini question
n2toh
Loc: New Jersey, United States
my current setup is MK2 with the v3.00a11 developer code. hijack v445 installed.
seeing as I've never edited the config.ini on my empeg before I found it odd that the visuals have multiple entries is this normal?
The reason I ask is when Hijack v445 boots I get error messages.
For anyone willing to look the config it is attached.
Edited by n2toh (14/03/2006 09:09)
#277574 - 14/03/2006 03:01 Re: config.ini question [Re: n2toh]
matthew_k
I'm pretty sure that's a old bug from well back in the 2.0 betas. You are using recent emplode, right?
Of course, the faq knows all.
#277575 - 14/03/2006 03:03 Re: config.ini question [Re: matthew_k]
n2toh
Sorry I forgot to include I'm using jEmplode v70 via ethernet.
I just deleted the config file and made a new one, the problem seems to be solved.
there is no error message on the empeg screen, but there is some straingness via the serial console.
"VM: do_try_to_free_pages failed for kswapd..."
Thanks Matt
Edited by n2toh (14/03/2006 03:28)
The only difference between science fiction and reality is about 60 years.
100GB MK2 Green 080000171 + OEM tuner
v3.00a11 hijack v450 jEmpload v70
#277576 - 14/03/2006 03:13 Re: config.ini question [Re: n2toh]
matthew_k
Good, just clear out your config.ini and you should be fine. The lines are left over from a bug years ago.
#277577 - 14/03/2006 08:53 Re: config.ini question [Re: n2toh]
schofiel
Can I suggest you edit your config listing to remove your personal details?
#277578 - 14/03/2006 09:10 Re: config.ini question [Re: schofiel]
n2toh
yes you may
