#277879 - 18/03/2006 18:10 Ski and Snowboard Goggles
I left the slopes early yesterday, because a sudden wet snow flurry reduced my visibility to near zero. I was unable to keep my goggles de-fogged.
This isn't the first time that's happened. Over the years, I've tried various forms of stuff applied to the goggles, to no avail.
I know there's nothing that can stop snow from sticking to the outside of the goggles, but is there a such thing as a high tech pair of goggles that is fog-proof on the inside?
#277880 - 18/03/2006 18:22 Re: Ski and Snowboard Goggles [Re: tfabris]
How about the usual double-layer lens, in combo with foam covered top/bottom vents? Works for (sweaty) me! But it's probably warmer where you ski/board.
#277881 - 19/03/2006 00:10 Re: Ski and Snowboard Goggles [Re: tfabris]
cushman
Loc: Erie, CO
Are you wearing your goggles with a helmet that blocks the top vent? Some goggles are helmet-compatible and others aren't. If you are just wearing a pair of goggles over a hat, they should mostly be fog-resistant. What kind are they? Do you have an extra $180 to drop?
Mark Cushman
#277882 - 19/03/2006 01:14 Re: Ski and Snowboard Goggles [Re: tfabris]
n2toh
Loc: New Jersey, United States
I've seen several people who are into playing with paintball guns mount CPU fans in their masks to prevent them from fogging.
The only difference between science fiction and reality is about 60 years.
100GB MK2 Green 080000171 + OEM tuner
v3.00a11 hijack v450 jEmpload v70
#277883 - 19/03/2006 02:30 Re: Ski and Snowboard Goggles [Re: tfabris]
No.
#277884 - 19/03/2006 05:14 Re: Ski and Snowboard Goggles [Re: tfabris]
So, spit is something you've tried?
Cheapest stuff I know of- and available darn near everywhere.
#277885 - 19/03/2006 07:41 Re: Ski and Snowboard Goggles [Re: n2toh]
For some reason when I read that I thought of fans like this.....
You'd look a real tit with a pair of those attached to your goggles.
#277886 - 19/03/2006 09:19 Re: Ski and Snowboard Goggles [Re: cushman]
No. In fact, sometimes the problem is that snow piles up on the top "roof" edge of the goggles where there's air-permeable foam, and that's when its worst because the melting snow up there gets even more humidity into the goggles.
If it really works and isn't a complete pain to use? Yes.
#277887 - 19/03/2006 15:44 Re: Ski and Snowboard Goggles [Re: andym]
n2toh
wonders will never cease, and I thought the Honda ricer crowd was bad.
#277888 - 19/03/2006 19:02 Re: Ski and Snowboard Goggles [Re: tfabris]
Yep, As you may have gathered it's all about ventilation. If the air trapped behind the lenses can't be exchanged frequently enough, fog happens. I've worn glasses, seem like all my life. Frames that are wrap around or fit tightly to the face have problems with fog.
Basically any design that prevents the free exchange of air, thus letting the opposite sides of the lens attain different temps is a recipe for fog.
#277889 - 19/03/2006 19:19 Re: Ski and Snowboard Goggles [Re: gbeer]
n2toh
electric defroster for your Goggles anyone?
#277890 - 20/03/2006 16:12 Re: Ski and Snowboard Goggles [Re: tfabris]
When it is exceptionally cold (colder than -10 degress F) I wear ski goggles when I'm mountain biking, and I have found a trick to keep them from fogging.
They will remain absolutely clear until I exhale. Then, I'm riding blind.
So as long as you don't breathe, your goggles will be OK. The downside to this, of course, is that the duration of your outings may become somewhat restricted.
#277891 - 20/03/2006 16:28 Re: Ski and Snowboard Goggles [Re: tanstaafl.]
matthew_k
You could always get yourself a snorkel. You'd have to breath through your mouth, but that's a small price to pay for sight.
#277892 - 20/03/2006 17:30 Re: Ski and Snowboard Goggles [Re: matthew_k]
I have seen goggles on the slope which have a small fan for air circulation mounted on them. Can't remember who made them though.
Edit: these are the ones
http://www.untracked.com/highlight-176522.html
The main thing seems to be to keep the vents clear. My Oakleys only generally mist up if I'm not moving - when I'm bombing down the hill they will clear very quickly. Mine has front vents as well as the top/bottom ones, which might be helping.
Edited by altman (20/03/2006 17:36)
#277893 - 20/03/2006 20:35 Re: Ski and Snowboard Goggles [Re: altman]
Dunno if you noticed, but Fish had some goggles like that when we were in Tignes. He said that they were marginally better than normal goggles, but probably not worth the bother.
#277894 - 20/03/2006 20:49 Re: Ski and Snowboard Goggles [Re: altman]
Those are the exact same goggles as the $180 ones linked above.
#277895 - 20/03/2006 22:14 Re: Ski and Snowboard Goggles [Re: wfaulk]
Ah, I didn't click the link, assuming that you could easily spend $180 on non-fan-assisted goggles
Sorry!
