#281363 - 12/05/2006 03:22 What commands are needed to rebuild database ???
bodybag
Loc: Southern California
I can't get to the FAQ right now for some reason. can some one give me the proper hyperterminal commands to make the player rebuild it's own databases manually? I know it's something like:
rw
rwm
rm /drive0/var/database
rm /drive0/var/database3
rm /drive0/var/playlists
rm /drive0/tags
then same for drive 1
them exit
let player restart
q
ro
exit
I think that's it, but could someone verify before I screw my player up.
Bodybag - So Cal
Not a Whiner any more!!!
#281364 - 12/05/2006 05:28 Re: What commands are needed to rebuild database ??? [Re: bodybag]
You got the location of the tags file wrong, and there's nothing on /drive1 that needs deleting but, otherwise, you were spot on. Here's the correct commands:
rw
rwm
rm /drive0/var/tags
exit
(let player restart)
q
ro
exit
#281365 - 12/05/2006 11:41 Re: What commands are needed to rebuild database ??? [Re: bodybag]
Also, a lot of times, when you are in a position that the databases need to be rebuilt by hand, you are probably in need of a manual FSCK, too. Search the BBS for E2FSCK and see if you can find the thread that originated the FAQ entry.
