#28297 - 17/03/2001 13:50 Beeping from within kernel/
Any of you more experience empeg kernel hackers care to share how I can generate a DSP beep from within a kernel driver? I took a look at the example "beep" user program, but somehow I don't think it's that simple when you're trying to do it from within the kernel itself.
-Tony
MkII #554
#28298 - 18/03/2001 17:40 Re: Beeping from within kernel/ [Re: tonyc]
borislav
Loc: Sunnyvale, CA, USA
It's actually easier from within the kernel, since you can call the beeping function directly, e.g.
audio_beep(&audio[0], pitch, duration, volume);
audio_beep() and audio[] are defined in empeg/arch/special/empeg_audio2.c, if you want to use them in a different source file you'll have to put the definitions in a header file. The pitch and duration arguments are as described on the developer's site, the volume is a percentage.
BTW, audio_beep() is normally only called from a process context (in the ioctl handler), not sure whether it's completely safe in an interrupt context but it appears to work there too.
Borislav
#28299 - 18/03/2001 20:00 Re: Beeping from within kernel/ [Re: borislav]
It looks like it's not that easy. It beeps, but immediately panics with the first call. I'm guessing there's something unsafe about calling beep in this way..
audio-empeg: BEEP 200, 60
Internal error: branch through zero: 0
CPU: 0
pc : [<00000004>] lr : [<0209e6bc>]
sp : be3ffce8 ip : 00000000 fp : c0111f24
r10: c0112f60 r9 : c0113cc4 r8 : c01140c4
r7 : c0113cc0 r6 : c0113cc4 r5 : c0113cc0 r4 : 00000000
r3 : 60000013 r2 : c0136654 r1 : c0113d48 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 0, stackpage=c0111000)
Code: pc not in code space
Aiee, killing interrupt handler
Kernel panic: Attempted to kill the idle task!
In swapper task - not syncing
I guess there's no safe way to call it from inside a driver. The whole reason I'm trying to do this is to provide an audio beep whenever a specific remote key is pressed. I'm building on top of Frank Van Gestel's IR trans patch, and have it so that I can get another 10 functions out of the remote if I use one of the buttons as a "switch functions" button. I wanted a beep when this button is pressed. Since it's not a normal Empeg function, the player doesn't generate beeps for that button. I just wanted to generate a beep inside the IR driver, as in this snippet:
add_timer(&irtrans_timer);
if(data == 0x0000AD0C) {
audio_beep(&audio[0], 60, 200, 100);
irtransmodify=1;
For whatever reason, this causes a massive kernel crash. Guess I should have picked an easier first kernel project :)
-Tony
MkII #554
#28300 - 19/03/2001 03:02 Re: Beeping from within kernel/ [Re: tonyc]
borislav
Hmm. Works for me...(tm)
Here is what I did to test it:
--- linux-1.02/arch/arm/special/empeg_audio2.c  Sun Jan 28 00:58:34 2001
+++ linux-1.02-beep/arch/arm/special/empeg_audio2.c Mon Mar 19 01:57:41 2001
@@ -1167,6 +1167,11 @@
return(0);
+void beep(void)
+ audio_beep(&audio[0], 60, 500, 50);
void audio_beep(audio_dev *dev, int pitch, int length, int volume)
/* Section 9.8 */
diff -Nur linux-1.02/drivers/char/empeg_ir.c linux-1.02-beep/drivers/char/empeg_ir.c
--- linux-1.02/drivers/char/empeg_ir.c Sun Jan 28 00:58:44 2001
+++ linux-1.02-beep/drivers/char/empeg_ir.c Sun Mar 18 15:50:58 2001
@@ -178,6 +178,8 @@
#define IR_STATE_DATA1 0x0a
#define IR_STATE_DATA2 0x0c
+extern void beep(void);
static void ir_append_data(struct ir_dev *dev, ir_code data)
/* Now this is called from the bottom half we need to make
@@ -186,6 +188,11 @@
ir_code *new_wp;
unsigned long flags;
save_flags_cli(flags);
+ if (data == 0xb91c) {
+ beep();
+ return;
new_wp = dev->buf_wp + 1;
if (new_wp == dev->buf_end)
The "tuner" button on the remote triggers it.
Can you do a similar patch of your mods? Send them over and I'll try to figure out why it's bombing out.
Borislav
#28301 - 19/03/2001 10:28 Re: Beeping from within kernel/ [Re: borislav]
D'oh. I'll have to check it out after work tonight.. Not sure what was causing it, but it was quite repeatable.
-Tony
MkII #554
#28302 - 19/03/2001 18:37 Re: Beeping from within kernel/ [Re: borislav]
Well, I guess my problems were caused by the kludgy way I had defined all the device structures (audio_buffer, audio_dev, etc.) in a header file. Using a void beep function with no device parameter (as you did) makes that step unnecessary, and fixes my problem. Now I just have a void beep with 3 int parameters for pitch, duration, and volume, and it seems to work great. Thanks much for the assistance!
-Tony
MkII #554
