#285157 - 05/08/2006 01:53
Sigh.. One More Time
Loc: Dallas Texas USA
its been a few years since this happened to me last time but my player is on the fritz again. Something failed during a sync. Here is a boot log..
empeg-car bootstrap v1.00 20000601 ([email protected]) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v355 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Sat Jan 17 08:49:36 EST 2004 Processor: Intel StrongARM-1100 revision 11 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 7, serial number 80000506) Command line: mem=12m Calibrating delay loop... 207.67 BogoMIPS Memory: 10960k/12M available (976k code, 20k reserved, 328k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x99380 Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004a00). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IBM-DARA-212000, ATA DISK drive hdb: TOSHIBA MK3017GAP, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63 hdb: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:fa Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count Trying to unmount old root ... empeg-preinit starting... no /etc/preinit.d empeg-preinit complete empeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting player Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection" hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. ! tags.cpp : 61:Failed to open tags (0xc0041002).
If I remember correctly, the system pauses here and then I get a screen full of the following meseges before it stops and locks up at the "Building Music Databases" messege.
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 536320 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 1584896 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 536336 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 536320 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1378968022, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1049598623, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3587859799, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3746542519, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2324098151, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3156579785, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3259374302, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3076771428, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1444106692, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3061143961, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2465988487, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 75562868, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3957023990, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 619864585, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1100831618, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 492120582, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2779541917, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 125487147, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 351565038, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 238260640, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 279308760, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3869135572, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3346116401, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1064822859, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3728119687, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1639482798, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3042814818, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4233031597, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4183690202, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3078601839, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3690847854, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2563492389, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1157990582, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2745284141, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1025401609, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2339073800, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3325476899, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1335623240, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4170219998, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 604570739, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4053224064, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 609528984, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1461005887, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2586530566, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2108970447, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1264076136, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1950238578, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3667703301, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4208335225, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1635327410, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2185416059, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1635543418, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 667199156, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2008740226, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1810286253, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2538383181, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4177517526, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4180568365, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1427211816, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3398025780, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 917440477, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 700560994, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3911591617, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3838395593, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1375150516, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 519104084, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2868257193, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3285810408, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1194998933, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1765137158, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1834255825, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1188697700, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1953661715, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3945497316, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2102805712, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 483089735, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3655364268, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1298296514, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3684099110, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1082245153, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3328758555, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3154077009, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1914778200, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2958899770, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3796992230, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 160441473, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2449534542, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1276086797, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3397421653, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 674369179, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4138061379, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 649135069, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1279028067, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 678921823, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1756205524, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 185405736, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1788570916, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3534674744, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1476566370, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1285162031, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 231392237, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3075295799, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 665287191, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1089172210, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 347165015, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 687410535, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3501942116, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 107303660, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2834322369, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 647041162, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1196537677, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2367638283, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3935045293, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 440648086, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4282469019, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4185166587, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1697252608, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1644817372, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1264655858, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 384184765, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1973491987, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3358270892, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3022981491, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 883493059, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1822715258, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 925476221, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1079461986, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1230629842, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2191305908, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3433225336, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2546576359, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3005403588, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2162168100, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3592722212, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 535874010, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 89589549, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 800975942, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 923826783, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2240902978, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 501566510, count = 1 Remounting filesystem read-only EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 4821573 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1558900372, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1444262663, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1526561256, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2650132691, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1895219550, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2512604308, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 461546474, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3012232678, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 672411049, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1419927513, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2875756850, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1142229558, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2930806953, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 163958888, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3414736238, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1444042394, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2230421671, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2300175769, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3592357114, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3580073004, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2781632646, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1644708157, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 513251392, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1709074340, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2353956246, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3844274042, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2655459985, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 435595732, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 206383414, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1433428630, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2784213741, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2487880161, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1766841816, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4209678181, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4009506264, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 308717235, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3593104091, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1196454098, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 479223889, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 393079698, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 571240997, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 83132435, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3388059605, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3916396062, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 238447645, count = 1 Remounting filesystem read-only EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 8681147 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1150505550, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4266789264, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1194045489, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3995446420, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2394854524, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3047498811, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3776633621, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 693834233, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2880227362, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1054549766, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3205333991, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1859544879, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3597773540, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 721279898, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2384791253, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3292087712, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2961885346, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 611443076, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3531983442, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 652442470, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1671511762, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 338638965, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4236505524, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 609635612, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1546954384, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1952610921, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3377721740, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 695476638, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 594234956, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2577639017, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 594918941, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2707904780, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2465988458, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 75561844, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1792895192, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 502417990, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 816708481, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2303928514, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 632058267, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 159498283, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 150353006, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1497473193, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 699935925, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2085328614, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1479634211, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3371119687, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1677683295, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1887663065, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1226983444, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3871913517, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3901926981, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 642152160, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2807729912, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1514125121, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 553005512, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2436016868, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4238152224, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1404436745, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3172208362, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1401934093, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 364453188, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 852756374, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 580342912, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3852870437, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 359155090, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2147634300, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3685052131, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2467107392, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1225168915, count = 1 Remounting filesystem read-only EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 12032 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2662642220, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 11827496, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2518583872, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1424770347, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1493772348, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2764183345, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3704009345, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1835541945, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2546428967, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2661181108, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1226846346, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3364365936, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4193751482, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2440163071, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2585754380, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1985838189, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1714681560, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2013193876, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3883475249, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2993084876, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3942954307, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3792103900, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 684771261, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 40009092, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 289777626, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2647389965, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1743616326, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1990696602, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3657006205, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2537370331, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3114274933, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1386087680, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 65116692, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 441991306, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2306939975, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1238023989, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 226184473, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 350153511, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1316917025, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1090728932, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 823550486, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1481153587, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2496128052, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3684082372, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3566251804, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3712200379, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 494033948, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 953250755, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3551578882, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3794651820, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 644603576, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2408731108, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4214226601, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2118580442, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1267902672, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3352316227, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 262191912, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1233259129, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2356209794, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2688930377, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2271044324, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1339663885, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 946600266, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4288675734, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2019956963, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4086990716, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4029104774, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1131511112, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3399529909, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2589344905, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 901191173, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3947355821, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2522972078, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 684479387, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3740061334, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 150778176, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2751877248, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 566978566, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3416467915, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2031873580, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3126889375, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3067643950, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1366037687, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3389622339, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 67240389, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2316540688, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 66151940, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1794018450, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2542543894, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3679927449, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1898387110, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3456509440, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 979773586, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3029245248, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1776840193, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 711454001, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1795453456, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3117931694, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2288552530, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1327668222, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3546645536, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1137117761, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 958518419, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 659501848, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 327319924, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 358818838, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4004976773, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2850523638, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 982076837, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3295464073, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1052216353, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1474608446, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 13618430, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1699562096, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1144062789, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2739818553, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1483995531, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 637750996, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3117748166, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1662294836, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2279120405, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2077901576, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1850606508, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 460845038, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2428567557, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2686610872, count = 1 Remounting fi
Edited by avatarTX (05/08/2006 03:16)
Carl Aydelotte
Dallas Texas USA
empeg MKII 080000506 40gb-green
#285158 - 05/08/2006 02:56
Re: Sigh.. One More Time
[Re: avatarTX]
Loc: Dallas Texas USA
I found this in the FAQ and am running it now..
ro umount /dev/hda4 umount /dev/hdc4 swapon /swapfile fsck -fay / fsck -fay /dev/hda4 fsck -fay /dev/hdc4 swapoff /swapfile sync
The first hard drive (hda4) performed as expected.. but the second drive (hdc4) is making some strange noises. I am also getting these messeges, I dont remember if the first drive did this or not?
ide0: reset timed-out, status=0x80 hdb: status timeout: status=0x80 hdb: drive not ready for command ide0: reset timed-out, status=0x80 hdb: status timeout: status=0x80 end_request: I/O error, dev 03:44 (hdb), sector 6353269 hdb: drive not ready for command hda: status timeout: status=0x80 hda: drive not ready for command ide0: reset: success Error reading block 3176634 (Attempt to read block from filesystem resulted in s hort read) while reading indirect blocks of inode 1433. Ignore error? yes
Inode 1433, i_blocks is 7850, should be 7338. Fix? yes
hdb: irq timeout: status=0xff ide0: reset: success hda: lost interrupt hdb: irq timeout: status=0xff ide0: reset: success hdb: irq timeout: status=0x80 ide0: reset: success hdb: irq timeout: status=0xff ide0: reset: success
I am going to let it continue until I get a prompt .. the second drive is bigger so I expect this to take some time. I am keeping my fingers crossed too. Someone please tell me I am on the right track?
Edited by avatarTX (05/08/2006 03:18)
Carl Aydelotte
Dallas Texas USA
#285159 - 05/08/2006 03:14
[Re: avatarTX]
Well it moved on..
hdb: irq timeout: status=0xff ide0: reset: success Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Unattached inode 3756 Connect to /lost+found? yes
Inode 3756 ref count is 2, should be 1. Fix? yes
Pass 5: Checking group summary information
But now I seem to be stuck at this new problem. Some sort of memory violation, and it appears to be stuck in a never ending loop..
ontrol: D03A117D Table: D03A117D DAC: 00000015 init(1): memory violation at pc=0x00000000, lr=0x02007140 (bad address=0x0000000 0, code 2) pc : [<00000000>] lr : [<02007140>] sp : 00000000 ip : bffffd88 fp : 00000000 r10: bffffe98 r9 : 00000000 r8 : 0203d938 r7 : bffffdac r6 : 00000000 r5 : 00000009 r4 : 00000000 r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000009 Flags: nzcv IRQs on FIQs on Mode USER_32 Segment user Control: D03A117D Table: D03A117D DAC: 00000015 init(1): memory violation at pc=0x00000000, lr=0x02007140 (bad address=0x0000000 0, code 2) pc : [<00000000>] lr : [<02007140>] sp : 00000000 ip : bffffd88 fp : 00000000 r10: bffffe98 r9 : 00000000 r8 : 0203d938 r7 : bffffdac r6 : 00000000 r5 : 00000009 r4 : 00000000 r3 : 00000000 r2 : 00000000 r1 : 0000
and its doing that over and over and over. I dont know if I shoud stop it, or even how to stop it if I wanted to. Cntrl-C maybe?
Edited by avatarTX (05/08/2006 03:19)
Carl Aydelotte
Dallas Texas USA
#285160 - 05/08/2006 04:02
[Re: avatarTX]
Well I give up. Nothing I have tried has worked so far. I had to power off the unit to stop the memory violation loop it was in and cannot get the system to boot normally yet. I have searched the FAQs for help and have not been able to find what I need.
I had this same problem a few years ago and managed to fix it then but I dont remember how I did it. My databases are corrupt and I need to rebuild them, I think.. and cannot figure out how.
Anyone have any ideas?
Carl Aydelotte
Dallas Texas USA
#285161 - 05/08/2006 05:10
[Re: avatarTX]
The fact that the second hard disk made funny noises points (i think) to some kind of physical failure. Either the disk is bad, or you have one of the usual cable-or-IDE-header problems.
All the FSCKs and database rebuilds in the world won't help you if you're having hardware trouble.
#285162 - 05/08/2006 11:03
Well now.. go figure. In an effort to find out whats going on I opened up my player to see if I could tell what is actually happening. As soon as I take the cover off I fire it up and it comes up like a champ. I think my player is either haunted or just needed its screws loosened once.
Emplodes sees it and everything. I cant tell you what a relief that is!
Carl Aydelotte
Dallas Texas USA
#285163 - 05/08/2006 12:14
[Re: avatarTX]
Loc: Louisiana, USA
Quote: I opened up my player to see if I could tell what is actually happening. As soon as I take the cover off I fire it up and it comes up like a champ.
Those are classic signs of a bad cable or IDE header problem.
Stu
#285164 - 05/08/2006 14:54
[Re: maczrool]
More specifically, even if it seems to have magically fixed itself for now, the problem is going to come back. You need to locate and repair whatever is causing the intermittent fault.
