#285665 - 18/08/2006 11:32 MS Access... calculating someone's age?
CrackersMcCheese
In table design view, I have my list of 'things', one of which is date of birth. I want another field to return the age of the individual automatically in years but I can't seem to do it (its probably so simple and obvious and I'm thinking about it too much). Anyone able to assist?
#285666 - 18/08/2006 11:40 Re: MS Access... calculating someone's age? [Re: CrackersMcCheese]
Mach
Loc: Texas, USA
Table data is typically static; age is not. It would be better to handle the age calculaton in a query, or create an update query to update the age in the table on demand, or you just calculate it in your form or report.
#285667 - 18/08/2006 11:55 Re: MS Access... calculating someone's age? [Re: Mach]
The query is definitely the way to go.
If I have a table with the fields id and dob in then the query needed is:
SELECT id, dob, DateDiff('yyyy',[dob],Now()) AS Age
FROM people;
Because of the way Access treats Queries almost the same as Tables you can then create Forms based on the query you have created and the Age field in the query (and the form) will get calculated as soon as you fill in the date of birth.
#285668 - 18/08/2006 12:18 Re: MS Access... calculating someone's age? [Re: andy]
CrackersMcCheese
Cheers guys! Sorted!
