What we need to see now, is the serial output when the "pause" errors are actually happening. The fact that you only get the errors in the car is troubling, and I'm now suspicious that the wiring might not be feeding the Empeg enough juice to keep both drives properly spun-up.
Remember that if you're trying to use the serial connector in the car, the default baudrate is only 4800 (to make it more compatible with other third-party in-car serial applications). There is an entry you can add to CONFIG.INI on the player that will let you put the in-car baud rate back up to 115200, and I recommend you do this if you're going to diagnose problems on the serial port while in the car.
Well, I bet you thought I forgot about this
I wasn't able to use the seriel port connector on the sled because BestBuy cut the connections. So what I did was attach a cable to the connection on the back of the unit and powered it up. This worked for a little while but eventually, the unit just wouldn't recognize a command from terminal. Here is what I was able to log at boot-up:
empeg-car bootstrap v1.00 20000601 (
[email protected])
On DC power, quick boot
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg42 (
[email protected]) (gcc versi
on 2.95.2 19991024 (release)) #186 Tue Jun 5 20:07:53 BST 2001
empeg-car player (hardware revision 7, serial number 90000784)
Command line: mem=12m temp=40 noinitrd
Memory: 11008k/12M available (960k code, 20k reserved, 292k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004a80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:1
0
Partition check:
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 8k init
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To CompěřStart
ing player
empeg-car 1.03-beta4.
3b21fdea DHCP Our mac is 00:02:d7:12:03:10
3b21fdea DHCP Our address is 255.255.255.255
3b21fdea DHCP Broadcast address is 255.255.255.255
3b21fdea DHCP Current IP address is 255.255.255.255
3b21fdea DHCP Sending DHCP discover
Switching to
At that point all connections would not work at any baud rate. If I force the connection through, I would only get output at 115200 and not 4800 which is the norm for the docking sled connection. I am thinking the above won't tell us much and that I will have to re-connect the seriel port on the docing sled to be able to run a cntr-T and get the data we need. I was also not able to get any information when the unti slowed down and stopped because output would not display to terminal.
So I am thinking my next step is the soddering table?
