#288208 - 17/10/2006 00:02 ISO Connector
Mach
Loc: Texas, USA
Anyone have any idea if this is the correct part for the sled wiring harness? This would be the plug that fits into the Riocar harness recepticle.
http://www.installer.com/item/display_item.php?it=71-1784
Although doubled, it looks correct.
And the recepticle portion,
http://www.installer.com/item/display_item.php?it=70-1784
Edited by Mach (17/10/2006 00:05)
#288209 - 17/10/2006 00:05 Re: ISO Connector [Re: Mach]
robricc
The top half of that looks like the right thing.
They thought I was crazy for taking one of those from Hugo's shed. They're really not common at all in the US.
#288210 - 17/10/2006 00:08 Re: ISO Connector [Re: robricc]
Mach
Loc: Texas, USA
Thanks Rob, I just went to installer.com store in Houston and they couldn't get their head around what it was that I wanted.
I pulled a Metra Kit part number from an old post - Metra 71-1784 and a web xref to BestKits BHO-1784 VW 87-up OEM Radio plug.
Edited by Mach (17/10/2006 00:09)
#288211 - 17/10/2006 00:11 Re: ISO Connector [Re: Mach]
That looks like *two* of them.
Here's one of them (from the original RioCar kit):
Edited by mlord (17/10/2006 00:12)
#288212 - 17/10/2006 01:28 Re: ISO Connector [Re: mlord]
Mach
Loc: Texas, USA
I agree, I'll check if it is one piece or two and post back.
#288213 - 17/10/2006 03:35 Re: ISO Connector [Re: mlord]
It isn't two of them. If you look carefully you will see the other side is keyed differently. The other half is the ISO connector with all the speaker outputs.
#288214 - 11/11/2006 11:12 Re: ISO Connector [Re: Mach]
Mach
Loc: Texas, USA
Confirmed. Metra 71-1784 or BHO-1784 can be used as a replacement or addition to the car harness (not the empeg harness). As Andy pointed out, there are 2 plugs in the the kit but they are keyed differently and only the black one is needed for the empeg. I was able to find the kit by searching on Ebay for BHO1784.
Edited by Mach (11/11/2006 11:13)
