#290838 - 26/11/2006 22:43 Boring C question
My google-fu is weak.....
I've got two arrays of floats, I need to add them together. Currently I'm doing it like so:
for (j = 0 ; j < numFrames ; j++)
tempVal[j] += buffer[j];
It works, but is there a quicker way?
#290839 - 26/11/2006 22:50 Re: Boring C question [Re: andym]
Unroll the loop (some compilers may partially do this already for you), and reverse the loop index to count down to zero (saves 1-2 instructions, usually).
So, something like:Code:
// Assumes numFrames is multiple of 4
for ( j = numFrames - 4; j != 0; j -= 4) {
tempVal[j] = buffer[j];
tempVal[j+1] = buffer[j+1];
tempVal[j+2] = buffer[j+2];
tempVal[j+3] = buffer[j+3];
Switching to pointers rather than table indexes might save another couple of instructions per iteration.
But for *real* speed, one could use MMX/SSE(2) etc.. instructions. Any experts here?
#290840 - 26/11/2006 23:20 Re: Boring C question [Re: mlord]
I now remember reading about this ages ago. I think the article it was in was about early computer graphics or something. I did also consider using pointers too. Will give them both a try.
Thanks Mark!
#290841 - 27/11/2006 07:36 Re: Boring C question [Re: mlord]
I'm no expert, but I do recall that modern GCC will use SSE instructions automatically in this sort of situation, especially if you've unrolled the loop in that way. It can't do that, though, unless it can prove that the two arrays don't overlap (consider "float buffer[101]; tempVal=&buffer[1]"). If one or more of buffer and tempVal is a local array variable, it can work out that they don't overlap; if this code is in a function where tempVal and buffer are both passed-in as float pointers, mark them "restrict" if you're sure they'll never overlap.
#290842 - 27/11/2006 12:14 Re: Boring C question [Re: peter]
Ahh.. good information there.
Also, gcc might not use MMX/SSE(2) instructions unless you explicitly tell it that it's okay to do so. On my Pentium-M notebook, I generally provide these flags: "-march=pentium-m -mfpmath=sse -msse2 -malign-double"
#290843 - 28/11/2006 06:42 Re: Boring C question [Re: mlord]
julf
By the way, have you come across a tool that would test your CPU and find out it's capabilities (and tell what optimisations make sense)?
#290844 - 28/11/2006 12:43 Re: Boring C question [Re: julf]
Under Linux: cat /proc/cpuinfo
#290845 - 28/11/2006 14:01 Re: Boring C question [Re: mlord]
Under Windows: http://www.cpuid.com/cpuz.php
#290846 - 28/11/2006 18:21 Re: Boring C question [Re: mlord]
julf
Duhh! Indeed, the first sign of Alzheimer's is... Hold on... It will come to me...
