#29161 - 05/04/2001 18:59 car vs. home problem
intensegravity
Loc: Cabot, Ar
Ok fellas, I've got this little problem with my 'info' display. I like to keep it on "line" (you know the one with all the cool visuals), and it stays on "line" if it's in the house everytime it powers up, it's there. In the car however, whenever you power up it's automatically back to "track" with no visuals. Any suggestions?
Eric Reed
Intense Gravity Minis
MkII Blue 090000731
Eric Reed Intense Gravity Minis MkII Blue 090000731
#29162 - 05/04/2001 19:33 Re: car vs. home problem [Re: intensegravity]
BillB
Loc: Orlando, FL USA
This is actually by design. Check out the FAQ page here.
There was at one point however, a kernel hack floating around that would allow what you want. Info is located here .
Bill B.
Mk.2 SN 080000183 - 38 GB /
Green
[orange]Bill B.
Mk.2 SN 080000183 - 38 GB /[/orange] [green] Green [/green]
#29163 - 06/04/2001 04:29 Re: car vs. home problem [Re: BillB]
teemcbee
The point with the kernel is that it has to be rebuild for every new version (eg. 1.1 - if it ever comes
TeeMcBee
Got my Mk2! # 080000143
TeeMcBee
#29164 - 06/04/2001 04:50 Re: car vs. home problem [Re: intensegravity]
jstrain
Loc: philadelphia pa
please for our sanity and your safety, don't ask anymore about this issue:) if you want to switch to the visual mode, just hold the bottom button in for about 3 seconds after the player starts playing music and it will switch itself to the last used display mode (which in your case would be line mode). the kernel hack is an option, but after a few times, it really just becomes habit to push the button after you start the car. i don't even realize that i am doing it now.
jeremy
12 gig, green...
12 gig, green...
#29165 - 06/04/2001 05:08 Re: car vs. home problem [Re: jstrain]
teemcbee
...playing music and it will switch itself to the last used display mode (which in your case would be line mode)
This is only in the 1-02 version. In older versions the last selected visual is displayed and info is off.
TeeMcBee
TeeMcBee
#29166 - 06/04/2001 06:43 Re: car vs. home problem [Re: teemcbee]
BillB
True, but it's not really worse than having to recompile with the vol-adj patch (or waiting until someone else does).
Bill B.
Green
[orange]Bill B.
#29167 - 06/04/2001 13:04 Re: car vs. home problem [Re: teemcbee]
jstrain
ahhhh, that is what i meant. it switches to the last visual mode. thanks for the correction tee.
jeremy
12 gig, green...
12 gig, green...
