#291896 - 03/01/2007 12:02 Mouse of inconvenience
My PC mouse has started generating fake button ups, so if I'm dragging something it'll drop in the wrong place. This really screws up Photoshop and email organisation in Outlook. I replaced the mouse and the new one does the same thing. Has anyone come across this annoying behaviour before?
Mice: Microsoft IntelliMouse Optical USB
OS: Windows XP SP2
#291897 - 03/01/2007 12:39 Re: Mouse of inconvenience [Re: rob]
Just a shot in the dark here, but accessibility features sometimes result in strange behaviours like that.
#291898 - 03/01/2007 13:26 Re: Mouse of inconvenience [Re: rob]
Maybe poor optical qualities of the surface you're moving the mouse on?
Wood grain makes my mouse skip and start, but not drop things.
#291899 - 03/01/2007 14:26 Re: Mouse of inconvenience [Re: rob]
The problem is clearly that it's a -1 mouse of inconvenience and you can't drop it until you get the curse dispelled.
#291900 - 03/01/2007 16:05 Re: Mouse of inconvenience [Re: wfaulk]
I'm so lucky that peanut butter doesn't spray out of the mouth the way coke does.
#291901 - 03/01/2007 16:54 Re: Mouse of inconvenience [Re: rob]
I had a very similar problem on a Logitech mouse when I wore the left click button clean out. I had just used it so much that the contacts had worn down I guess. A new mouse fixed the problem. I'm guessing this is not your problem since a second mouse isn't working though. If both mice are well worn, it could be an issue though.
#291902 - 05/01/2007 00:59 Re: Mouse of inconvenience [Re: Robotic]
FireFox31
Loc: East Coast, USA
I second the mousing surface notion. Optical mice hate surfaces with depressions or other imperfections. I've had 100% error rate with optical mice on those semi-hard plastic mouse pads because of this. Try a new mouse pad or a retro ball mouse.
FireFox31
#291903 - 05/01/2007 22:40 Re: Mouse of inconvenience [Re: FireFox31]
Hmm, well it is on one of those semi hard mouse mats.. I'll try using it on the desk surface for a while.
I noticed today it also sends button down clicks of its own accord on occassions. It feels like software to me.
#291904 - 05/01/2007 23:52 Re: Mouse of inconvenience [Re: rob]
Ezekiel
Loc: NH USA
Of course it could always be a simple demonic posession.
-Zeke
WWFSMD?
#291905 - 06/01/2007 13:11 Re: Mouse of inconvenience [Re: rob]
oliver
Have you tried to use one of those USB > PS2 converters, or if you already are have you tried removing it. Just to double check if the problem is still present?
Also, Have you tried to use the IntelliMouse drivers and the standard windows drivers?
I've always used PS2 adapters till I got this Razor Copperhead mouse and I figured it's about time to use the USB port.
