#292389 - 14/01/2007 12:57 Need new harddrive
newguy1
Loc: Massachusetts,USA
Ive been having some errors and timeouts recently and I think I need a new drive.
I looked at the drive upgrade FAQ and it looks too involved for me
If I purchase a drive would some kind soul set it up for me,
or even maybe purchase the drive themselves ,format it and send it too me.
I'll paypal or however to pay you.
MIKE 80Gb RIO
#292390 - 14/01/2007 19:58 Re: Need new harddrive [Re: newguy1]
CrackersMcCheese
Like you, I was a bit scared of the drive upgrade but I went ahead and found it really easy. It helps if you print the guide and have a read before you start and just follow the steps with guidance here if you get stuck.
If you still feel unsure I'm sure someone here will help you. (I'm a bit far away )
#292391 - 14/01/2007 21:45 Re: Need new harddrive [Re: CrackersMcCheese]
newguy1
Ok thanks,The reason I think its the drive is when I add new songs I get an error on the display that says disc error read_intr. I havent changed anything just trying to add new songs.
MIKE 80Gb RIO
#292392 - 15/01/2007 02:03 Re: Need new harddrive [Re: newguy1]
It's probably *not* the drive that's bad. More likely the IDE header or cable (know problems with both of those).
Ship it to Stu at Eutronix, assuming you're in the USA.
#292393 - 15/01/2007 18:05 Re: Need new harddrive [Re: newguy1]
What Mark said. You might not need a new disk.
More specifically, you might be having this problem or this problem.
If the diagnostic procedures from those links seem too involved, then definitely send it in for repairs. If you are in the US, Stu at Eutronix should be able to help you. If it turns out you really do need a new disk, he can help with that, too.
#292394 - 16/01/2007 01:22 Re: Need new harddrive [Re: tfabris]
newguy1
The header and cable were repaired by support a couple years ago(maybe 3 or 4)They also replaced the hardrdive.
I'll try some of the diagnostic tests and see if that helps.Thanks
MIKE 80Gb RIO
#292395 - 16/01/2007 10:50 Re: Need new harddrive [Re: newguy1]
maczrool
Loc: Louisiana, USA
It's still possible one or both of these has gone bad again.
Stu
#292396 - 16/01/2007 15:45 Re: Need new harddrive [Re: maczrool]
And it's also possible the cable has just worked loose. Definitely check for that, since it's so easy to fix.
There's also the chance hard disk has genuinely gone bad. That happens, too, especially if the player has been exposed to extreme temperatures or if its install doesn't allow it to ventilate into the dash cavity.
#292397 - 17/01/2007 01:46 Re: Need new harddrive [Re: tfabris]
newguy1
Well I took the cover off and inspected things.The cable to the hardrive connection is glued in place.I didn't disconnect the cable to the header just pressed to make sure it was connected.
The player is located where it could be subject to excessive heat when I have the heater running.During the day the player is subject to whatever the outside temperature is,currently winter here so anywhere from 0F to 30F.
MIKE 80Gb RIO
#292398 - 17/01/2007 02:17 Re: Need new harddrive [Re: newguy1]
newguy1
Another thing I noticed is if I try and load more than 1 song at a time I get errors but 1 song and it works fine.
MIKE 80Gb RIO
#292399 - 18/01/2007 01:49 Re: Need new harddrive [Re: newguy1]
newguy1
Here is the log from fsck.
Looks like there were problems that were fixed?
293267-test.TXT (246 downloads)
MIKE 80Gb RIO
#292400 - 18/01/2007 02:45 Re: Need new harddrive [Re: newguy1]
The drive looks as if it has a bad track -- several sectors reported as bad. But things like this can be tricky -- the only real way to tell is to put the smartctl command onto the player and run it to read the drive error logs directly from the IDE drive.
But a rough approximation is also possible: connect over serial, hit control^C to kill off the player software, and do cat /dev/hda > /dev/null. When it finishes the next day, do cat /proc/kmsg to see the kernel error messages. Then repeat it all again.
If the kernel reports failures both times on exactly the same sectors, then we know the drive has bad sectors. But if the reported sectors differ each time, then it's more like to be a cable/connection issue.
But smartctl is a better method, if you know how to use it.
#292401 - 19/01/2007 01:05 Re: Need new harddrive [Re: mlord]
newguy1
By bad track do you mean a bad song track or a physical track on the drive?
I don't know how to use smarctl(but can learn) so i'll try the other method for now.
MIKE 80Gb RIO
#292402 - 19/01/2007 01:33 Re: Need new harddrive [Re: newguy1]
newguy1
I tried the cat /dev/hda > /dev/null method and this is what I got.(i did it 3 times it only took about 3 minutes)
Starting bash.
empeg:/empeg/bin# cat /dev/hda > /dev/null
hda: read_intr: status=0x59
hda: read_intr: error=0x40
end_request: I/O error, dev 03:00 (hda), sector 133080
cat: /dev/hda: Input/output error
empeg:/empeg/bin#
So what do you think?
MIKE 80Gb RIO
#292403 - 19/01/2007 12:36 Re: Need new harddrive [Re: newguy1]
Starting bash.
Unplug the empeg completely, plug it back in, and do the test again.
If the same sector 133080 comes up again, then that sector on the drive is bad.
#292404 - 20/01/2007 20:53 Re: Need new hard drive [Re: mlord]
newguy1
Re-did the test and got the same sector error came up.
Is there a way to bypass that sector so I can add my songs or fix it?
MIKE 80Gb RIO
#292405 - 21/01/2007 02:20 Re: Need new hard drive [Re: newguy1]
Nothing practical, anyway.
#292406 - 21/01/2007 12:46 Re: Need new hard drive [Re: mlord]
newguy1
I tried smartctl. I followed these instructions http://www.riocar.org/modules.php?op=mod...;faqent=275#275
When I try the ./smartctl -s on /dev/hda
I get No such file or directory.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v466 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 12 12:10:26 EST 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xd0d0
ide_data_test: wrote 0xffff read 0xd0d0
ide_data_test: wrote 0xaaaa read 0xd0d0
ide_data_test: wrote 0x5555 read 0xd0d0
ide_data_test: wrote 0x0000 read 0x3bc6
ide_data_test: wrote 0xffff read 0x3bc6
ide_data_test: wrote 0xaaaa read 0x3bc6
ide_data_test: wrote 0x5555 read 0x3bc6
hda: FUJITSU MHR2030AT, ATA DISK drive
hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2e
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplůStarting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 124 (adjustment 10)
Vcb: 0x407cd000
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# cd /drive0/var/smartctl
empeg:/drive0/var/smartctl# ./smartctl -s on /dev/hda
bash: ./smartctl: No such file or directory
empeg:/drive0/var/smartctl# exit
logout
Shell exit
Starting playTimezone: Atlantic/South_Georgia
er
Vcb: 0x407cd000
Do you see something I did wrong?
MIKE 80Gb RIO
#292407 - 21/01/2007 13:29 Re: Need new hard drive [Re: newguy1]
The directions you are following are probably over-complicated for this.
Just FTP the smartctl.bin file to the top-level (root) directory of your player:
ftp my.player.ip.address
cd /
site rw
put smartctl.bin
chmod 755 smartctl.bin
site ro
quit
Then connect via serial to the player, hit control^C to kill off the music app, and enter these commands:
/smartctl.bin -s on /dev/hda
/smartctl.bin -a /dev/hda
Then you can proceed to try out the various test options for smartctl.bin
Edited by mlord (21/01/2007 13:30)
#292408 - 21/01/2007 21:41 Re: Need new hard drive [Re: mlord]
newguy1
Ok that worked.Thanks.
It came up with the same sector error 133080.
Looks like its time for a new drive.
Anyone got one they want to get rid of?
I only need a 30gig.
So is there a way to fix this?
If I have to get a new drive i'll have to put my music back on anyway so maybe I can practice on this one.
MIKE 80Gb RIO
#292409 - 22/01/2007 16:12 Re: Need new hard drive [Re: newguy1]
If smartctl showed *only* a (very) few number of bad sectors, then you can probably repair the drive yourself, at the expense of having to reload everything back onto it afterwards.
This command will wipe the drive, causing the drive firmware to auto-repair the bad sectors (as long as there aren't too many of them):
cat /dev/zero > /dev/hda
It will take about 10 hours to complete (unless my math is wrong, definitely possible), and should finish with an error message like this one: no space left on device.
You'll then have to install the drive builder image using a null-modem serial cable, and then reinstall the player software and Hijack.
#292410 - 22/01/2007 21:29 Re: Need new hard drive [Re: mlord]
TigerJimmy
That's cool. Why does that work? What is it actually doing?
#292411 - 22/01/2007 21:37 Re: Need new hard drive [Re: TigerJimmy]
The hard drive knows (or will know) that a sector is bad when you try to write to it, so it will remap that sector to an area reserved for that sort of remapping. When you "cat /dev/null", you're just writing a bunch of zeros to every bit on the drive, so that when it gets to that sector it will remap it. The reason it doesn't do it until you write there is in case the data on the sector is still recoverable.
Hmm. Mark, is there any reason you couldn't just write zeros to that one sector? I mean, it would still corrupt the filesystem, but it would take less time to do it. Or maybe there's not a good way to find where the offset to that sector is.
#292412 - 22/01/2007 22:19 Re: Need new hard drive [Re: wfaulk]
Modern drives don't write individual sectors -- generally, they only write entire tracks. So if we don't overwrite the entire track, then the drive will try to do a Read-Modify-Write instead, which of course will fail, since the track has a bad sector..
Catch-22, kind of. Often one *can* rewrite a single sector, or a single track (group of sectors), but it' much simpler to just overwrite the entire drive.
After all, we don't know which important file that sector was part of.. (undoubtedly an .mp3 file, but..).
#292413 - 22/01/2007 22:41 Re: Need new hard drive [Re: mlord]
In my admittedly very limited experience, a formerly good drive that suddenly develops bad sectors is usually telling you that there are more to come, that the number of bad sectors is going to increase asymptotically in a pretty short timeframe until the drive self-destructs and no information is recoverable. Most times a newly bad sector is caused by a head that touched a platter during some sort of impact, causing a microscopic gouge in the disk and a similarly microscopic accumulation of material on the head which makes it much more likely that the head will touch the platter again, even with a less severe impact. It's a positive feedback situation where a little bit of trouble causes a lot more trouble.
There may be less common reasons for a bad sector with less catastrophic end results, but the above scenario is by far the most likely.
#292414 - 23/01/2007 00:52 Re: Need new hard drive [Re: tanstaafl.]
newguy1
Ok here is the text from the smartctl log.
Any opinions on the errors?
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 90% 1854 474790
# 2 Short offline Completed: read failure 90% 1853 474534
# 3 Short offline Completed: read failure 90% 1853 474534
empeg:/empeg/bin# /smartctl.bin -l error /dev/hda
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 2
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in a reserved state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
a6 00 ca 11 e0 59 00
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
01 a6 ca 11 e0 c4 14 02 05:01:28.230 [RESERVED]
Error -1 occurred at disk power-on lifetime: 1850 hours (77 days + 2 hours)
When the command that caused the error occurred, the device was active or idle.
40 59 04 a6 ca 11 e0 Error: UNC at LBA = 0x0011caa6 = 1165990
c4 00 04 a6 ca 11 e0 00 38d+05:31:15.127 READ MULTIPLE
Error -2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
00 00 03 11 00 00 00
a4 d9 25 01 00 40 06 4b 31d+20:24:21.194 [RESERVED]
a4 00 00 00 00 00 06 00 31d+20:24:21.194 [RESERVED]
Error -3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
59 00 00 00 03 11 00 at LBA = 0x00110300 = 1114880
40 c4 df c5 25 01 00 e0 12d+10:16:23.304 READ VERIFY SECTOR(S)
00 00 00 00 00 00 00 00 00:00:41.480 NOP [Abort queued commands]
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
MIKE 80Gb RIO
#292415 - 23/01/2007 01:15 Re: Need new hard drive [Re: newguy1]
Doesn't look too bad (yet). Try zeroing the drive and run with it.
It could get worse, it could behave. I've had drives that went either way.
#292416 - 23/01/2007 10:26 Re: Need new hard drive [Re: mlord]
newguy1
Thank you,i'll give it a shot.
After I do this i'll put smartctl back on and test again.
MIKE 80Gb RIO
#292417 - 30/01/2007 01:38 Re: Need new hard drive [Re: newguy1]
newguy1
Well I wiped the drive,installed the drive builder image,reinstalled the player software and hijack.
Added about 15gigs of music and things seem to be OK.No errors or warnings when syching.
Thank you Mark for taking the time to help.
Thanks to everyone else that responded also.
MIKE 80Gb RIO
#292418 - 30/01/2007 03:17 Re: Need new hard drive [Re: newguy1]
Well, thanks to you also, for being the (far more than) perfect n00b here. Very well done! (not that your post count even remotely matches your moniker, I suppose).
Edited by mlord (30/01/2007 03:18)
