#294266 - 26/02/2007 01:04 HD Upgrade Problems
thirdeyevision
Loc: Petaluma, CA (Bay Area)
i recently decided to upgrade the HD in one of my mk2a players and the only builder i could d/l was the one from the empeg support website. marks builder link didn't work and neither did the other one.
i am adding an 80 gig travelstar to a fujitsu 30 gig and tried the regular builder but i get an error message "cannot find pump"
i was wondering if the builder is the problem because of the large drive? also wondering if someone could fix the link or would be able to send me the builder for larger drives?
thanks.
#294267 - 26/02/2007 12:17 Re: HD Upgrade Problems [Re: thirdeyevision]
I believe the links are now in the drive upgrade guide.
It looks like Mark's web server may not be up at the moment though.
lemme dig around and see if I can find it.
EDIT: Nope...looks like I haven't downloaded it on this computer yet. If someone has it and would like me to host it at riocar.net, just pm me.
#294268 - 26/02/2007 13:48 Re: HD Upgrade Problems [Re: JBjorgen]
Due to some confusion with the local telco, our xDSL line disappeared last Friday. It should hopefully be reactivated later this week, though.
Meanwhile, I believe I have the 2.3MByte builder_bigdisk.upgrade file here with me, if anyone has a server for me to upload it to.
#294269 - 26/02/2007 14:08 Re: HD Upgrade Problems [Re: mlord]
robricc
I PM'd meatballman with a location that I have the files hosted if he wanted to grab them for riocar.net. They're here if anyone needs them while Mark gets his DSL sorted-out.
#294270 - 26/02/2007 16:37 Re: HD Upgrade Problems [Re: robricc]
Also available at riocar.net/files.
I got the domain long ago so that I could redirect it to riocar.org. Maybe it'll actually be useful now.
#294271 - 26/02/2007 16:41 Re: HD Upgrade Problems [Re: JBjorgen]
robricc
Everything but the disk builder points to the same file (2.01 final).
#294272 - 26/02/2007 18:37 Re: HD Upgrade Problems [Re: thirdeyevision]
tried the regular builder but i get an error message "cannot find pump" i was wondering if the builder is the problem because of the large drive?
You definitely need the bigdisk builder. Sorry that Mark's web site was down when you needed it the most. It's critical you use a builder that will handle large drives, in order to prevent problems with the big disk.
HOWEVER... I'm not convinced that the reason you're getting "cannot find pump" has anything to do with the disk size or which image you're using. I'm pretty sure if you had a size issue, it would get past that stage of the builder and only show you errors later. (Someone correct me if I'm wrong?)
So I think that you may have another problem to solve while you try to scare up a bigdisk builder image. Click here for information on the pump error.
#294273 - 26/02/2007 19:32 Re: HD Upgrade Problems [Re: robricc]
Oops. Too much copying and pasting and not enough thinking. Fixed.
#294274 - 26/02/2007 22:47 Re: HD Upgrade Problems [Re: robricc]
AndrewT
Loc: Oxford, UK
Top man! I just wish I'd checked this part of the forum a few hours ago, d'oh.
Although I've just partitioned my new drive using Roger's guide, I'm not 100% certain that I didn't miss something while flitting from the instruction on my Windows PC, to the job in-hand on the Kubuntu PC that has the new empeg drive attached. To cover my arse (so to speak) I think I should run Mark's builder.
#294275 - 26/02/2007 22:56 Re: HD Upgrade Problems [Re: JBjorgen]
AndrewT
Loc: Oxford, UK
Crap! I *thought* they were supposed to be mirrored somewhere else, I looked on riocar.org, I didn't know to look on riocar.net. I'm mindful that this drive upgrading affair is a bit of a moving target ATM, relatively speaking. Do we need to speak kindly to the FAQ robot about adding riocar.net to the excellent Drive Upgrade Guide?
#294276 - 26/02/2007 23:39 Re: HD Upgrade Problems [Re: AndrewT]
Mostly I think somebody should put them on RioCar.Org, as I've suggested in the past.
#294277 - 27/02/2007 06:20 Re: HD Upgrade Problems [Re: mlord]
thirdeyevision
thanks for all the help!
i'm going to re-attempt the upgrade tomorrow afternoon!
#294278 - 28/02/2007 01:55 Re: HD Upgrade Problems [Re: tfabris]
thirdeyevision
Success!!!
now i have a new problem. when i went to load hijack on the player via logoedit i get an error 53 message. this also happens when i tried to put a boot logo on the player.
what am i doing wrong?
#294279 - 28/02/2007 04:38 Re: HD Upgrade Problems [Re: thirdeyevision]
I think Error 53 means that you didn't fully unzip the entire logoedit package. You must unzip all the files, not just the main logoedit.EXE. It's looking for the separate EXE that it calls out to in order to actually perform the upload.
If I recall correctly. It's been a while.
#294280 - 28/02/2007 21:48 Re: HD Upgrade Problems [Re: thirdeyevision]
Success!!!
If you used the bigdisk upgrader, then your player already has Hijack on it, which might save some trouble here..
#294281 - 02/03/2007 00:12 Re: HD Upgrade Problems [Re: mlord]
thirdeyevision
that was the problem!
i used the 2.01 from the empeg software page because in the upgrade guide it said to use the 2.01 for large disks if you had over 160gb (mine is 110).
just a rookie mistake. on to the next empeg!
thanks for all the help.
Jim
