#294307 - 26/02/2007 18:56 Anyone using JEmplode with A LOT of music on the Empeg?
bodybag
Loc: Southern California
The reason I ask is that I simply cannot use JEmplode. It is slow to a point of being unuseable, and most of the time has to be closed through Windows Task Manager because it becomes unresponsive. Even when it does open, each click, or movement takes litterally minutes to complete. Just changing from one folder to another is about a 2 minute process.
I have currently somewhere around 28,000 songs and I suspect that's the problem. Has anyone else run into this, or is there a solution?
I like to use JEmplode to sync my Empeg (via JEmplodes download function) to my office PC.
Bodybag - So Cal
Not a Whiner any more!!!
#294308 - 26/02/2007 19:03 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: bodybag]
How much RAM on your PC? Which version of the Java runtime engine?
#294309 - 01/03/2007 15:50 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: tfabris]
bodybag
768 RAM - J2SE Runtime Environment 5.0
1.8 GHZ Pentium
Edited by bodybag (01/03/2007 16:51)
Bodybag - So Cal
#294310 - 01/03/2007 16:22 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: bodybag]
Paul G, anything to add here?
#294311 - 01/03/2007 16:41 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: tfabris]
bodybag
Today I opened JEmplode and attempted to use the download feature to extract some stuff to my HD. After about 8-10 minutes I finally got to the folder and was able to right click, select download and select a destination. As soon as it started downloading it stopped and just went back idle. No message about how many files were dL'd or skipped, nothing.
Bodybag - So Cal
#294312 - 01/03/2007 19:47 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: bodybag]
I'm currently sitting with about 24,000 and it is very smooth. It isn't quite as quick as emplode, but that is often the java way - easily faster than my MS Office, though, so I'm happy with it. I think my PC I have it hooked to is a dual core AMD 3.4GHz with 4Gb RAM or thereabouts...
#326840 - 20/10/2009 04:07 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: frog51]
jbauer
Loc: San Francisco, CA
Hi All,
Today, I screwed the pooch and LOST all my photos and music from my NAS device. I'm now done throwing up, and want to start downloading my music off of my empeg.
I'm having the same problem as bodybag had above. jemplode is slow as hell.
Any ideas of what I might be able to do to figure out why???
I can't download even one album it is taking so long!
- TIA
- Jon
#326844 - 20/10/2009 10:47 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: jbauer]
How many FIDs on your player, Jon?
The best suggestion I have, is to increase the amounts of stack and heap memory for java on the java command line.
#326845 - 20/10/2009 10:55 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: mlord]
Oh, and be sure to PAUSE THE PLAYER software while downloading -- 2X speedup (or better)!
I'm (right now) seeing about 14 seconds for a 4.4 Mbyte track download.
Edited by mlord (20/10/2009 10:56)
#326849 - 20/10/2009 12:55 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: mlord]
jbauer
Hi All,
I figured out the problem. I had MULTIPLE, like 6 or 7 installs of Java on my PC. I installed all of the old ones, and now the speed has returned to JEmplode! Dunno why or how the old versions were hosing me, but its good to have JEmplode back!
- Thanx
- Jon
#326851 - 20/10/2009 13:15 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: jbauer]
Yeah, the Java update system on PCs is atrocious.
#326888 - 20/10/2009 23:31 Re: Anyone using JEmplode with A LOT of music on the Empeg? [Re: jbauer]
Originally Posted By: jbauer
Hi All,
- Thanx
- Jon
Gee, I feel deprived. I only had four installs on my computer. Now there's just the one.
Thanks for the tip.
