#296246 - 02/04/2007 12:05 Whole house media
I'll be building a new house shortly, no idea on where to start with media/cabling.
I've always used cat5 previously but not sure what I can and can't do in terms of media serving, my likely sources will be:
DVDs (ripped to server)
Radio (Digital terrestrial???)
Music (MP3s, I currently use Squeezeboxes)
TV (Digital terrestrial + Sky)
I'm guessing that my needs would be best served by having a server room for my sources and silent PCs as the front ends, is this correct? Also one of the reasons I like Squeezeboxes is the fact that you can synch them, is this possible if using PCs as the front end? Obviously I'd like everything to be HDTV ready.
At the moment I'm just thinking of structure rather than specifics of platform etc (e.g. Win/Mac/Linux)
I'd appreciate any thoughts.
#296247 - 02/04/2007 12:39 Re: Whole house media [Re: tahir]
There's a ton of places to get an assortment of cables bundled together as one cable like these residential composite cables. Fiber, coax, and Cat5 in one bundle.
EDIT: I'm in no way endorsing or recommending that site. It was one of the first google results I had.
#296248 - 02/04/2007 12:41 Re: Whole house media [Re: tahir]
Lucky sod!! How did you find land in the UK?
Anyhow, first suggestion: lots of plastic ducting.
Second suggestion : build a bungalow (or have suspended floors with a 3' crawl gap - all your problems go away and you can run services and all kinds under there.
Third suggestion: I suggest designing it
Seriously.
And that means essentially knowing what you're getting and where it's going. The ducting helps with "oh sh!t, I needed a DVI->HDMI cable going from A to B" but you really need to get most of it right at once (unless you like your lounge looking like a patch cabinet!)
You'll want a place to keep servers - usually called a "node zero" by HA types.
Then think about:
* where are the speakers going? In ceiling? On walls? On the floor?
* where are the amps going? You don't really want speaker wire running around the house - bad for the signal. And going from the node0-(cat5)->room-(line level)->node0-(speaker level)->room is horrible.
* where are the screens going? Walls, under the kitchen units?
* how do you get media from servers to device to amp/display?
If you have a cinema room are you projecting or plasma'ing? Projectors can be built into vented cabs. Screens can be built into the ceilings *if* your joists go the right way (mine don't but coving is great!) Plasmas need strong walls.
Are you going client/server?
Also, think very hard about room layout - a huge problem is having windows and doors on every wall.
Ideally you want a room that has blank end walls, the door in the middle of one long wall and the windows in the other long wall. Then you sit backing the short wall and project onto or hang the plasma on the other short wall.
Don't neglect other wiring: especially security systems. Wireless is great in a listed building but having the batteries go flat in my security system sounds a bit dodgy
You may have guessed I run a server room (study) with MythTV on diskless PCs in the bedroom and cinema room and squeezeboxes in the bathroom and other lounge. I have cat5 to the kitchen just in case...
I've done lots of remodelling so re-running the cable wasn't too bad.
I've done the alarm but still need to wire up security cameras (just IP webcams).
Have you seen the UK selfBuild group?
FAQ here: http://www.sbfaq.borpin.co.uk/dokuwiki/doku.php?id=start
Seriously essential info
There is also a UKHA group - which is fine it you like spending money on X10 and bow down to the church of Redmond
See the community links from: http://www.automatedhome.co.uk/
Personally I'd go MisterHouse - but then that's because Larry invented Perl.
#296249 - 02/04/2007 13:01 Re: Whole house media [Re: LittleBlueThing]
Easy, if you're prepared to buy a crap house on 58 acres.
#296250 - 02/04/2007 13:03 Re: Whole house media [Re: JBjorgen]
Didn't know such things existed, thanks.
#296251 - 02/04/2007 13:07 Re: Whole house media [Re: LittleBlueThing]
Wow LBT, sounds like you've considered most of the same stuff in a lot of detail. My biggest issue is going to be interfacing to the SKY isn't it? I don't really want to pay them EVEN more money to get multi room, I'd rather use terrestrial with Sky purely for the premium stuff.
Client/server would be fine by me, I've seriously considered a Win Terminal Server environment before but that's the only thin client (apart from slim devices) I've ever used.
#296252 - 02/04/2007 13:11 Re: Whole house media [Re: tahir]
Projector vs plasma
I'm looking at projectors right now, purely because they'll disappear when necessary. Mighht be an issue with joists I'll talk to the architect (we're still at design stage)
Bungalow
Funy enough there'll only be 2 rooms upstairs, main bedroom and guest bedroom, all the others will be ground floor.
Who's Mister House?
#296253 - 02/04/2007 13:15 Re: Whole house media [Re: tahir]
Mmmmmmmm - I dream of 58 acres.
I rate land way higher than the buildings too, and have a short-medium term ambition to build in a large plot. The only problem is my three money sinks (four if you count SWMBO)
#296254 - 02/04/2007 13:19 Re: Whole house media [Re: frog51]
I spent years dreaming, tbh never thought I'd get there, building a house is sort of the cherry on top.
Good luck with your dream
#296255 - 02/04/2007 13:53 Re: Whole house media [Re: tahir]
I've been building it up slowly for a couple of years
Denise started it by moaning about the VCR and asking for a capture card!! We ran it under Windows for a week whilst we went on holiday. It crashed on day 2. We installed MythTV the next week - we now have about 2Tb of storage...
Sky SDTV is not a problem (for me with Myth) - basically s-video capture and an IR controller to change channel.
You will have a problem with HDTV.
Be aware that you can only watch one channel at once. However we haven't watched liveTV (or an advert) for about 2 years now and you can stream different shows on each screen without any problems.
I also run freesat capture of the OTA mpeg stream for some channels (not sky). I can't get freeview here (trees) but that's similar and easy too.
I run a huge (2.2m across) screen on standard def and it's great - has to be seen to be believed. The joist thing is pretty minor - I've got (well, will have) mine hidden behind the coving.
The main thing that's hard to hide is the projector - I wouldn't bother with motorising it unless you can afford several thousand pounds.
Oh, MisterHouse
I'm in Reading if you want to come see... but I guess if you have that much land you're not down south
It is *all* linux though - the only windows PC we allow in the house is the work laptop! It does mean that I am not subject to buying licenses to upgrade my PCs or paying extra to run diskless or ... but it can be daunting for newbies unless you know people who know linux - and that's getting less of a problem nowadays.
58 acres eh? Got a spare one for a friendly neighbour with similar tastes in hi-tec
#296256 - 02/04/2007 14:08 Re: Whole house media [Re: LittleBlueThing]
Heh. Having a neighbour with two exotic sports cars would likely drive up the property values too much for him!
#296257 - 02/04/2007 14:11 Re: Whole house media [Re: LittleBlueThing]
Plenty of acres, no chance of planning permission though (field for sale next door), ours is going to be a replacement consent, we'll have 6 months to demolish the existing once the new house is complete. We're in Essex so Reading's not too far away, might take you up on that offer, nobody I know in real life would have any idea what MythTV is. Don't mind learning a bit more Linux, it'd be handy at work too.
So what happens with HD then? Aren't there appropriate PCI cards?
#296258 - 02/04/2007 14:14 Re: Whole house media [Re: mlord]
Couldn't go up much more round here. We just got really lucky that the previous owners wouldn't split the plot, 58 acres is too small for farming, too big for equestrian or large garden. It ended up selling for much less than it could have with just 10 acres (well certainly no more). Exotic sports cars? No wonder he can't afford any land
#296259 - 02/04/2007 14:24 Re: Whole house media [Re: mlord]
hmm, so what would be the circumference around 58 acres?
hmm, how much is tarmac....
Yippee - every day is a track day!!!
#296260 - 02/04/2007 14:28 Re: Whole house media [Re: LittleBlueThing]
It's being planted (slowly) with trees. About 7000 of 'em so far. No room for a race track, wind turbine (if I can get consent) would be nice though.
I reckon circumference must be around 1.8 km
#296261 - 02/04/2007 14:41 Re: Whole house media [Re: tahir]
Just PM me
In a word : "no". (AFAIK)
Basically it's a copy protection thing. Sky (and others) won't let HD signals out over a non-protected interface (like firewire that you get in the US). There's a very low chance that the hardware (if we ever see it) will work with non-proprietary software in order to prevent thieves/customers like us from time-shifting
You can't use a PCI DVB-S (satellite card) in the UK to get Sky because Sky uses a type of encryption hardware (CAM) that isn't supported. I have heard of 'grey' setups that decode using dodgy subscription cards but I'm OK with SD so never investigated further.
Will it get cracked? Possibly - I'm not holding my breath.
(Hat's off to Sky's original system architects - they sure met the spec of an 'uncrackable' system)
PS FYI: just buying some relays/reed switches to allow invisible switching of my whirlpool and possibly the slimserver.
#296262 - 02/04/2007 15:09 Re: Whole house media [Re: LittleBlueThing]
Well, that would depend on how the land was laid out.
If it were a perfectly square plot, the circumference would be 6,358 feet (give or take a couple of inches). If the plot were circular, it would be about 5,635 feet around.
On the other hand, if it were laid out in a long, narrow rectangle (say 10 feet wide and very long), the circumference would be about 96 miles.
#296263 - 02/04/2007 16:36 Re: Whole house media [Re: LittleBlueThing]
g_attrill
Loc: Hants, UK
You can receive nearly all the free channels on satellite with any digital satellite receiver or PCI card. We have four receivers in the house, and one Sky subscription. Only C4 and C5 need a Sky receiver and viewing card, they will come out of an encryption contract in 2008 and will almost certainly broadcast free-to-air. BBC HD is free-to-air and I imagine will stay unencrypted if/when it is a permanent channel, so you could use any generic DVB-S2 PCI card. I hope that the other channels launch satellite HD channels soon, there is very little on BBC HD at the moment!
#296264 - 02/04/2007 18:54 Re: Whole house media [Re: g_attrill]
What software are you using to decode BBC HD? Got a sat card knocking about at work in a linux box and I fancy giving it a go.
#296265 - 02/04/2007 19:09 Re: Whole house media [Re: andym]
I'm not - that's kinda the point
Apparently you need a fast Athlon 64 type system to decode it.
keywords: BBC HD h.264 / AVC
http://en.wikipedia.org/wiki/BBC_HD
Try the mythtv-users archives too - 'BBC HD' ...
You can apparently transcode - not bothered yet...
#296266 - 02/04/2007 19:39 Re: Whole house media [Re: andym]
Here in Canada, CBC HD is 1080i (1920x1080 interlaced), the playback of which takes up about half of my Core2Duo-1.8Ghz processor -- essentially tying up one of the two cores.
Edited by mlord (02/04/2007 19:40)
#296267 - 02/04/2007 20:43 Re: Whole house media [Re: LittleBlueThing]
I was asking Gareth (hence the Re: g_atrill bit in the header of my post) as it seemed he had been decoding it.
#296268 - 03/04/2007 10:17 Re: Whole house media [Re: andym]
g_attrill
Loc: Hants, UK
I haven't tried it either, but when I looked into it DVBViewer was working ok with various combinations of codecs. I think there were a lot of problems and it generally isn't easy.
