#302286 - 17/09/2007 07:49 Tuner strange issue
I wonder if this has happened to anybody else.
One day, my tuner started to behave as follows:
1. Frequency indicator staid where I had put it: 107.9 Mhz (Radio24, here in Rome)
2. The tuner, in spite of the above, started to change frequency, cycling throgh the entire freq range. I could guess that's what was happening by just listening to the several stations being tuned in sequence, separated by static.
3. The signal strength indicator would change according to the station being tuned. That also seemed to support the idea that the tuner was actuallying cycling.
4. Changing preset would change the frequency indicator accordingly, but that would not also change the frequency actually tuned.
Switching to Player and back to tuner would not work. Reboot would not work. Basically, tuner unusable.
Day after, tuner works again, but after 30 mins of usage it would go back to the strange behavior.
Today, tuner worked no problem for 1 hr during my commute to work.
Maybe the problem occurs when tuner overheats?
Has this happened to anybody else?
Any possible software issue?
Edited by taym (17/09/2007 13:35)
#314878 - 10/10/2008 17:12 Re: Tuner strange issue [Re: Taym]
I'm now making a house call in Rome to check up on Taym's tuners, and figured a group empeg meet photo was in order:
Description: Rome empeg meet, October 2008.
#314895 - 11/10/2008 15:58 Re: Tuner strange issue [Re: mlord]
dr_dos
Loc: Bendorf, Germany
Hi Mark,
you guys are in Italy right now? In case Germany is on your schedule you're more than welcome to come by our place and stay for a while.
-Peter
#314901 - 12/10/2008 04:46 Re: Tuner strange issue [Re: dr_dos]
Hi Peter!
Just Italia this time around. But your area is definitely on the list for next time around!
How's the little bambino doing ?
#315049 - 15/10/2008 06:28 Re: Tuner strange issue [Re: mlord]
dr_dos
Dorian's doing very well - as you can see...
#315054 - 15/10/2008 13:26 Re: Tuner strange issue [Re: dr_dos]
What a great photo!
#315246 - 19/10/2008 01:26 Re: Tuner strange issue [Re: mlord]
I did not realize how old this thread you digged out was, Mark. smile Time flies!
It was great having you both here! smile
Ad congratulations to you, dr_dos, for wonderful Dorian! smile
