#304254 - 21/11/2007 20:23 little rubber button springy thingy
lastdan
Loc: santa cruz,ca
Anyone know where I might begin to look for one of these?
http://farm3.static.flickr.com/2012/2053719080_71adad2ddb.jpg?v=0
(78k) (anyone know a proper name for it?)
it's the rubber pad that sits under a button that makes contact when pressed. ~11 x 10 mm
#304255 - 21/11/2007 20:31 Re: little rubber button springy thingy [Re: lastdan]
I'd suggest the automotive equivalent of buying a parts car.
#304256 - 21/11/2007 20:31 Re: little rubber button springy thingy [Re: lastdan]
Not sure you can buy those conductive rubber pads. If you have a bad button then carefully gluing some tin foil usually fixes it.
#304257 - 22/11/2007 00:29 Re: little rubber button springy thingy [Re: lastdan]
In the US, they tend to be known as chiclet keyboards, especially when referring to QWERTY-type keyboards.
What's wrong with yours that it needs replacing? I'm sure they're molded to spec, not an off-the-shelf part.
#304258 - 22/11/2007 01:58 Re: little rubber button springy thingy [Re: tman]
I haven't done it but have read about people using rear window defogger repair kits to fix those.
