#307817 - 03/03/2008 02:47 0000.2 Segfault/sigkill error
Waterman981
Loc: Salt Lake City, UT
So I'm driving home from Vegas tonight and right before getting to my hotel in southern Utah my empeg got this error. Removed/reinserted and it would come up again at the loading visuals point. I tried the force DC, but it had the same results. It just reboots over and over.
I still have a 4 hour drive ahead of me, so if anyone has any ideas I'd love to hear them. I have a laptop (vista) with me, a power adapter, and a crossover cable.
3.0A11 - Hijack v476
-Michael
#040103696 on a shelf
#307818 - 03/03/2008 03:01 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
When all else fails, the quick fix is usually:
boot and connect via serial, hit control^C to kill player.
Then do: player -i
wait a few seconds, hit Control^C to kill it again,
and then type exit and disconnect the serial.
You may lose EQ settings and other stuff, but this sledgehammer normally recovers from the worst.
#307819 - 03/03/2008 03:06 Re: 0000.2 Segfault/sigkill error [Re: mlord]
Waterman981
Then do: player -i
Any ideas without a serial cable?
-Michael
#307820 - 03/03/2008 03:26 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Oh.. your crossover cable must be ethernet then, not serial.
Sorry.
You can try the Kill/Restart Player option (or whatever I named it) from the Hijack menu -- it tries to be a bit more clever about things than the basic error handling is.
#307821 - 03/03/2008 03:47 Re: 0000.2 Segfault/sigkill error [Re: mlord]
Waterman981
Yeah, I should have specified crossover ethernet.
Using the Reboot Player option had the same result, as did trying different force AC/DC modes, and the restore DC/Car Visuals option.
I have seen an error similar to this a couple times, but have found no exact way to reproduce it: 0000.2 hda: err:irq ___ (I didn't get the whole thing).
-Michael
#307824 - 03/03/2008 08:14 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
If it's a dud track I've had some success with simply pressing next (right) very quickly while it's booting and can usually get it to skip the track before it crashes...
#307825 - 03/03/2008 13:47 Re: 0000.2 Segfault/sigkill error [Re: Shonky]
Waterman981
I've usually been able to do that too, but here it seems like it crashes before I am able to get to that point. Of course it's probably right there that it crashes. The last status message it gives is Loading Visuals, which I thought the restore visuals thing was for (to get around a bad track).
Edited by Waterman981 (03/03/2008 13:49)
-Michael
#307827 - 03/03/2008 14:02 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Waterman981
Shoot. Looks like I've been a slacker and missed the hijack I need. v477 does exactly what I need... just the next revision of what I have. Got that from a search for +bad +track. I was thinking Mark was referring to the restore visuals, which I see is altogether different.
Looks like I'll have no tunes until I get home. Well I'll listen to some movies playing off my laptop. Pity though I won't be able to pipe the audio over the aux in of the empeg.
-Michael
#307828 - 03/03/2008 14:05 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
You should be able to upgrade hijack over the ethernet cable, if your player is configured with a static IP address.
Just use an FTP client to transfer the Hijack zImage file into /proc/empeg_kernel, and then wait an extra 30 seconds after it completes before rebooting the player.
#307831 - 03/03/2008 14:29 Re: 0000.2 Segfault/sigkill error [Re: mlord]
Waterman981
Unfortunately I use DHCP at home and work, I'll have to change that when I get home as well to avoid situations like this again.
Well the nice thing is I'm getting a better idea of everything to bring for future road trips. crazy
Thanks for your help Mark!
-Michael
#307832 - 03/03/2008 14:55 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
This means there is a more general problem with the player's hard disk, or the player's connection to the hard disk.
The other suggestions in this thread seem to indicate that you have a bad track that you need to skip. Based on the above error message, I think you have a bigger problem than that.
#307850 - 03/03/2008 22:33 Re: 0000.2 Segfault/sigkill error [Re: tfabris]
Waterman981
I think you are right. I've reinstalled 3.0A11, and hijack v488. Tried Marks instructions above, and still can't get the player software to start up correctly.
Here's a boot log:
CCC¡V
     •µ…Ɂ‰½½ÑÍÑÉ…ÁÙŹÁɁÉÁÁÁÅÅÁف¡¡Õ½•µÁ•¹½µ¥5)ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 40103696) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004d80).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffd0
ide_data_test: wrote 0xffff read 0xffd0
ide_data_test: wrote 0xaaaa read 0xaad0
ide_data_test: wrote 0x5555 read 0x55d0
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hdb: IC25N060ATMR04-0, ATA DISK drive
hda: FUJITSU MHN2300AT, ATA DISK drive
hda: FUJITSU MHN2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: IC25N060ATMR04-0, 57231MB w/7884kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:70
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: Atlantic/South_Georgia
/bin/sh: /usr/local/bin/empire: Nhijack: removed menu entry: "Hard Disk Detection"
o such fihijack: removed menu entry: "Serial Port Assignment"
le or directory
/binkhttpd: listening on port 80
/sh: execkftpd: listening on port 21
: /usr/local/bin/empire: cannot execute: No such file or directory
  player.cpp        : 587:empeg-car 3.00-alpha11 2005/07/25.
Dead temp.sensor, status=0x00
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x40762000
show_message("0000.0 segfault err")
player(25): user memory violation at pc=0x0203f504, lr=0x00000c18 (bad address=0x4a67569c, code 2)
pc : [<0203f504>]    lr : [<00000c18>]
sp : bdfffba0  ip : cccccccd  fp : bdfffbc8
r10: 406c276c  r9 : 0000b8af  r8 : 406c2768
r7 : 00000000  r6 : 0220acd8  r5 : 00000000  r4 : 04f0f390
r3 : 4a675694  r2 : 0002e2bc  r1 : 0000160c  r0 : 4064e008
Flags: nzCv  IRQs on  FIQs on  Mode USER_32  Segment user
Control: C0F6117D  Table: C0F6117D  DAC: 00000015
Function entered at [<0203f498>] from [<02026138>]
 r10 = 00000001  r9 = 02210D20  r8 = 021B0DB4  r7 = 021B0DB4
 r6 = 0004C75C  r5 = 021B0DB4  r4 = 40676008
Function entered at [<020260f4>] from [<02026768>]
 r5 = 40676008  r4 = 00000000
Function entered at [<020266b0>] from [<0202986c>]
 r10 = 020DEA00  r8 = BDFFFCC0  r7 = 021B0DA4  r6 = 40676008
 r5 = 00000000  r4 = 00000000
Function entered at [<02029844>] from [<02028800>]
Function entered at [<0202878c>] from [<02006058>]
 r7 = 00000000  r6 = BDFFFCBC  r5 = 00000000  r4 = 02210D20
Function entered at [<02005f9c>] from [<020067c4>]
 r7 = BDFFFCBC  r6 = BDFFFCBC  r5 = 00000000  r4 = 02210D20
Function entered at [<02006750>] from [<0200673c>]
 r8 = 00000001  r7 = BDFFFCF8  r6 = 00000000  r5 = 00000000
 r4 = 02210EB4
Function entered at [<02006718>] from [<020ce108>]
Function entered at [<020ce0a8>] from [<020ce060>]
 r8 = 0000340E  r7 = 00000080  r6 = 021BE108  r5 = 02210EB4
 r4 = 00000000
Function entered at [<020ce014>] from [<020066e8>]
 r6 = 0000000E  r5 = BDFFFD4C  r4 = 02210D20
Function entered at [<020066d4>] from [<020dead4>]
Function entered at [<020dea9c>] from [<020dea8c>]
 r5 = 021D40FC  r4 = 02210D20
Function entered at [<020dea00>] from [<0211c970>]
 r5 = 02210D38  r4 = BDFFFE40
Function entered at [<0211c8a8>] from [<0215334c>]
 r4 = 00000000
Function entered at [<02151ac0>] from [<0211c6ec>]
 r8 = 021E8A5C  r7 = 021E8A48  r6 = 020DEA00  r5 = 00000005
 r4 = 00000001
Function entered at [<0211c63c>] from [<0215334c>]
Function entered at [<00000074>] from [<021d1a28>]
Function entered at [<e39ffff4>] from [<eb000a3f>]
Function entered at [<2a00fef4>] from [<2a00ff00>]
show_message("0000.0 sigkill err")
Unable to handle kernel paging request at virtual address 2a00fef8
memmap = C0F60000, pgd = c0f60000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00e53d8>]    lr : [<c0019950>]
sp : c0387f44  ip : c0387f00  fp : c0387f90
r10: 00000002  r9 : c0f980e0  r8 : 0000000c
r7 : 00000000  r6 : 2a00fef4  r5 : 2a00ff00  r4 : ea000030
r3 : 60000013  r2 : c0106284  r1 : 00000001  r0 : ea000020
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  Segment user
Process player (pid: 25, stackpage=c0387000)
Stack:
c0387f20:                                               c0019950 c00e53d8 60000013
c0387f40: ffffffff c0f980f8 c0f938a0 c0386000  c0387fb8 4a67569c c0011be0 00000c18
c0387f60: 4a67569c 00000002 c0387fb8 00000005  4a67569c 00000000 00000002 0000b8af
c0387f80: 406c276c c0387fb4 c0387f94 c0012134  c0011984 c010497c 00000000 0220acd8
c0387fa0: 00000000 406c2768 00000000 c0387fb8  c000a0c8 c001205c 4064e008 0000160c
c0387fc0: 0002e2bc 4a675694 04f0f390 00000000  0220acd8 00000000 406c2768 0000b8af
c0387fe0: 406c276c bdfffbc8 cccccccd bdfffba0  00000c18 0203f504 20000010 ffffffff
Backtrace:
Function entered at [<c0011978>] from [<c0012134>]
 r10 = 406C276C  r9 = 0000B8AF  r8 = 00000002  r7 = 00000000
 r6 = 4A67569C  r5 = 00000005  r4 = C0387FB8
Function entered at [<c0012050>] from [<c000a0c8>]
 r8 = 406C2768  r7 = 00000000  r6 = 0220ACD8  r5 = 00000000
 r4 = C010497C
Code: ebfcd0d9 e2440010 (e5961004) e1a035a1 e59f20cc
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting playTimezone: Atlantic/South_Georgia
er
Definitely some weird stuff there (IDE data test, memory violation)... Thoughts?
-Michael
#307859 - 04/03/2008 02:06 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Nothing wrong with the IDE data test -- it passed in the end, and that's the only thing that matters in that case.
#307876 - 04/03/2008 14:11 Re: 0000.2 Segfault/sigkill error [Re: mlord]
Waterman981
When I get home tonight I'll throw a different drive in there and see if I have the same problem.
-Michael
#307961 - 06/03/2008 05:32 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Waterman981
Well I finally got around to putting a different drive in there. It was already built, and even had music on there. Everything worked fine, so my guess is a hard drive failure. At least I only have 50GB of music to re-sync! wink And as long as I have it apart I'm going to fix that temp sensor. Thanks again everyone!
-Michael
#308142 - 13/03/2008 13:30 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Waterman981
Ok, so for the past week I have been running with a new primary hard drive (hda), and the same secondary drive(hdb).
With this config I would occasionally see a stat_timo error on hdb. (I did see this with my original config on both hda and hdb)
So last night I blew away hdb with DBAN, then ran SpinRite to check for disk errors. I built the old hdb as hda (single drive conf), then loaded the player software. I synced a bunch of music overnight for my drive in to work today.
With the single drive (again originally hdb when everything first failed) I started getting the same stat_timo messages. Now at work I'm getting "No hard disk found..."
So I guess it comes down to this, is there anything that could have caused both hard drives to fail simultaneously like that while I was driving (not at startup or shutdown)? Would the same thing happen again to new hard drives?
-Michael
#308145 - 13/03/2008 14:49 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Yes, and yes.
The NUMBER ONE CAUSE OF HARD DISK PROBLEMS in the Empeg
is the IDE HEADER ON THE MAINBOARD.
(sometimes I get weary of reminding people of this).
Most likely, one or more pins from the hard drive header (connector) on the mainboard has lifted from its inadequate factory solder job.
It bounces around, sometimes making contact, sometimes not. Heat can make a difference, as can simply lifting the empeg by its handle.
It needs to be inspected and resoldered down flat again, by somebody competent at soldering without destroying the motherboard pads/traces.
Edited by mlord (13/03/2008 14:51)
#308159 - 13/03/2008 20:20 Re: 0000.2 Segfault/sigkill error [Re: mlord]
Attack
Loc: Florida
Could this be caused by a bad cable?
Chad
#308160 - 13/03/2008 20:35 Re: 0000.2 Segfault/sigkill error [Re: Attack]
Waterman981
I've been wondering that as well. I've been using an extended cable from Eutronix for the last couple years. I'll inspect both the headers and cable under my magnifying lamp, but last week when I looked at the IDE header everything looked good. But that was with the system board still in the metalwork. I'll also give the original cable a try.
-Michael
#308175 - 14/03/2008 02:57 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Waterman981
Well Mark, I appreciate your reminding me to check the IDE header. I had visually looked it over last week, but missed one bad connection. I verified it with a continuity test on my multimeter tonight. I touched it and the one next to it up, and fingers crossed everything is perfect again.
Sometimes you just need to be told to look again, ya know.
Now comes the fun task of trying to remember what I had in my config.ini. smile
Thanks again! I know my empeg would have been dead long ago if it wasn't for the people here.
-Michael
#308184 - 14/03/2008 11:00 Re: 0000.2 Segfault/sigkill error [Re: Waterman981]
Yeah, it's the only thing that could make *two* drives flaky.
#324997 - 09/08/2009 10:20 Re: 0000.2 Segfault/sigkill error [Re: mlord]
Dava
Loc: Bucks UK
Hi All,
After many years of solid service my player now has the same issue, it reboots repeatedly with a segfault/sigkill error. I tried skipping forward during this boot loop but this does not change the error.
I connected via serial and upgraded hijack - same problem
I swapped the drive to that of my other empeg - no problem
I swapped IDE cables between players - the problem follows the drive itself
From this I presume that I have a drive problem, either physical or some corruption?
I connected via serial but cannot interrupt the player starting with either repeated or continual pressing of either CTRL-C or q.
I have another drive in a drawer at the office which I will try to config for the empeg and then I suppose connect both with the new one as master and copy all the FIDs across. Is this the best course of action?
Does anyone have any other ideas on how to fix this drive in another way, given the above?
Thanks in advance.
Boot Log:
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
empeg-car player (hardware revision 9, serial number 40103445) 16MB DRAM
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb90
show_message("Hijack v508 by Mark Lord")
empeg state support initialised 0089/88c1 (save to d0005080).
ide_data_test: wrote 0x0000 read 0x8080
ide_data_test: wrote 0xffff read 0x8080
ide_data_test: wrote 0xaaaa read 0x8080
ide_data_test: wrote 0x5555 read 0x8080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
hda: WDC WD800VE-00HDT0, ATA DISK drive
hda: WDC WD800VE-00HDT0, 76319MB w/8192kB Cache, CHS=9729/255/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0d:7
5
Partition check:
•W¯-ë×
      «—«ë«¹Ñ½±‘É½½Ñùrrþokay
Mounting proc
No secondary hard disk
Starting player
Timezone: Atlantic/Reykjavik
Using theme e with intro e
0 08 09 14 24
Volume=50
/drive0/var/ttsclock/tts/greetings.pcm /drive0/var/ttsclock/tts/afternoon.pcm /d
rive0/var/ttsclock/tts/todayis.pcm /drive0/var/ttsclock/tts/week0.pcm /drive0/va
r/ttsclock/tts/month8.pcm /drive0/var/ttsclock/tts/9th.pcm /drive0/var/ttsclock/
tts/ethetimeis.pcm /drive0/var/ttsclock/tts/xxpause.pcm /drive0/var/ttsclock/tts
/e12.pcm /drive0/var/ttsclock/tts/xxpause.pcm /drive0/var/ttsclock/tts/e20.pcm /
drive0/var/ttsclock/tts/e4.pcm /drive0/var/ttsclock/tts/xxpause.pcm /drive0/var/
ttsclock/tts/epm.pcm
cat: /drive0/var/ttsclock/tts/greetings.pcm: No such file or directory
cat: /drive0/var/ttsclock/tts/afternoon.pcm: No such file or directory
cat: /drive0/var/ttsclock/tts/todayis.pcm: No such file or directory
cat: /drive0/var/ttsclock/tts/week0.pcm: No such file or directory
cat: /drive0/var/ttsclock/tts/month8.pcm: No such file or directory
cat: /drive0/var/ttsclock/tts/9th.pcm: No such file or directory
  player.cpp        : 385:empeg-car 2.00 2003/04/01.
Vcb: 0x4086d000
show_message("0000.29 segfault err")
player(26): user memory violation at pc=0x02035784, lr=0x00000f70 (bad address=0
x021cf238, code 2)
pc : [<02035784>]    lr : [<00000f70>]
sp : be5ffbe4  ip : cccccccd  fp : be5ffc0c
r10: 02191f98  r9 : 00000001  r8 : 02191f94
r7 : 0000001d  r6 : 0218ce48  r5 : 000d01ac  r4 : 0868cd72
r3 : 021cf230  r2 : 00000004  r1 : 0000107a  r0 : 02177be8
Control: C0F7117D  Table: C0F7117D  DAC: 00000015
Function entered at [<02035718>] from [<020211e0>]
 r10 = BE5FFD2C  r9 = 00000000  r8 = 00000000  r7 = 02135800
 r6 = 02135800  r5 = 02135800  r4 = 02191EC8
Function entered at [<020211a8>] from [<0201fec4>]
 r5 = 02191EC8  r4 = 0000001D
Function entered at [<0201fe38>] from [<0201f31c>]
 r8 = 021357F4  r7 = 02191EC8  r6 = 02171C30  r5 = BE5FFC74
 r4 = 02191EC8
Function entered at [<0201f300>] from [<0201e588>]
 r5 = 0000001D  r4 = 00000000
Function entered at [<0201e4ec>] from [<02003f08>]
 r8 = 02191CF0  r7 = BE5FFD2C  r6 = 02191CF0  r5 = 00000000
 r4 = BE5FFD2C
Function entered at [<02003eec>] from [<02002c78>]
Function entered at [<02002aac>] from [<020037d0>]
 r10 = 02191D88  r9 = BE5FFD2C  r8 = BE5FFD30  r7 = BE5FFD2C
 r6 = 02191CF0  r5 = 00000000  r4 = BE5FFD2C
Function entered at [<02003574>] from [<020ad4f0>]
 r10 = 020AD438  r9 = 02191CF0  r8 = 0000280B  r7 = 00000080
 r6 = 0000000B  r5 = 02191CF0  r4 = BE5FFD64
Function entered at [<020ad438>] from [<020b4824>]
 r5 = 02191D08  r4 = BE5FFE40
Function entered at [<020b475c>] from [<020e9bbc>]
 r4 = 00000000
Function entered at [<020e8330>] from [<020b45a0>]
 r8 = 0215796C  r7 = 02157958  r6 = 020AD438  r5 = 00000007
 r4 = 00000001
Function entered at [<020b44f0>] from [<020e9bbc>]
Function entered at [<00000020>] from [<bffffc3c>]
Function entered at [<000efff6>] from [<000f0002>]
show_message("0000.29 sigkill err")
Unable to handle kernel paging request at virtual address 000efffa
memmap = C0F70000, pgd = c0f70000
*pgd = c0f7a801, *pmd = c0f7a801, *pte = 00000000, *ppte = 00000000
CPU: 0
pc : [<c00e6b70>]    lr : [<c0019950>]
sp : c05a5f44  ip : c05a5f00  fp : c05a5f90
r10: 00000002  r9 : c0fa10e0  r8 : 0000000c
r7 : 00000000  r6 : 000efff6  r5 : 000f0002  r4 : fffffffc
r3 : 60000013  r2 : c0106284  r1 : 00000001  r0 : ffffffec
Process player (pid: 26, stackpage=c05a5000)
Stack:
c05a5f20:                                               c0019950 c00e6b70 600000
13
c05a5f40: ffffffff c0fa10f8 c0fa02a0 c05a4000  c05a5fb8 021cf238 c0011be0 00000f
70
c05a5f60: 021cf238 00000002 c05a5fb8 00000007  021cf238 00000000 00000002 000000
01
c05a5f80: 02191f98 c05a5fb4 c05a5f94 c0012134  c0011984 c010497c 000d01ac 0218ce
48
c05a5fa0: 0000001d 02191f94 00000000 c05a5fb8  c000a0c8 c001205c 02177be8 000010
7a
c05a5fc0: 00000004 021cf230 0868cd72 000d01ac  0218ce48 0000001d 02191f94 000000
01
c05a5fe0: 02191f98 be5ffc0c cccccccd be5ffbe4  00000f70 02035784 20000010 ffffff
ff
Backtrace:
 r10 = 02191F98  r9 = 00000001  r8 = 00000002  r7 = 00000000
 r6 = 021CF238  r5 = 00000007  r4 = C05A5FB8
 r8 = 02191F94  r7 = 0000001D  r6 = 0218CE48  r5 = 000D01AC
 r4 = C010497C
Code: ebfccaf3 e2440010 (e5961004) e1a035a1 e59f20cc
Starting playTimezone: Atlantic/Reykjavik
er
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
