#308908 - 07/04/2008 12:55 hdparm-8.6+ for the empeg (static binary)
Attached.
Note that is the very latest (prerelease) version of hdparm, and it may include functionality that the empeg kernel does not support -- such things will just fail with an error message.
hdparm.bin (217 downloads)
Description: hdparm-8.6+ binary for the empeg. Rename to hdparm, and put in /bin/ on the player. Static binary (no libs needed).
#308911 - 07/04/2008 13:24 Re: hdparm-8.6+ for the empeg (static binary) [Re: mlord]
Oh, and for the curious:
hdparm -t /dev/hda4
/dev/hda4:
 Timing buffered disk reads:   10 MB in  3.49 seconds =   2.87 MB/sec
That's our max read throughput for the empeg hard disk. Better than I'd imagined, actually.
Edited by mlord (07/04/2008 13:24)
#308912 - 07/04/2008 13:53 Re: hdparm-8.6+ for the empeg (static binary) [Re: mlord]
2.87 MB/sec [...] max read throughput for the empeg hard disk. Better than I'd imagined, actually.
It was a very long time ago that I measured the write throughput as 4MBytes/sec, so I can't remember how I did it, but it was probably something pretty extreme, e.g. mmap() in a foreground thread and msync() in one or more background threads. Does hdparm use read(), or mmap(), to obtain those numbers?
#308927 - 07/04/2008 23:20 Re: hdparm-8.6+ for the empeg (static binary) [Re: peter]
It's using read(2), so that it works on any device. No question that mmap() would be quicker, especially on slower hardware (such as the empeg).
And writes will be faster than reads, because both the kernel and the drive normally cache them.
