#316369 - 14/11/2008 14:00 rotary encoder problem
I've recently started having a problem with my rotary encoder thinking it's turning clockwise no matter what direction it's actually being turned in. It never seems to do anything on its own; it just misinterprets counterclockwise motion. Also, it usually only does this the first time I play with it after boot. Once it starts working correctly, it doesn't seem to happen again until a reboot, probably with a significant amount of time powered off. It also seems like lateral pressure on the knob has some effect on the issue, but I can't quite figure out what effect.
Is there likely to be any way to resolve this without replacing the encoder?
#316371 - 14/11/2008 14:14 Re: rotary encoder problem [Re: wfaulk]
Heh.. heading up this way again any time soon? smile
#316373 - 14/11/2008 15:27 Re: rotary encoder problem [Re: mlord]
Weren't there some changes for encoder interpretation in Mark's kernel?
#316374 - 14/11/2008 15:32 Re: rotary encoder problem [Re: Robotic]
Yes, there are some. But I suspect Bitt already has Hijack installed.
#316375 - 14/11/2008 15:35 Re: rotary encoder problem [Re: mlord]
Ah- just checking that my memory still serves. Thanks!
I'm sure that Bitt would allow nothing less than the latest and greatest version of Hijack on his trusty empeg. wink
#316376 - 14/11/2008 15:38 Re: rotary encoder problem [Re: wfaulk]
Your symptoms make it sound like you've got a loose solder joint somewhere in the display board, perhaps near the encoder itself. Perhaps an encoder replacement isn't needed.
It's a complete PITA to try to solder around the encoder, though, due to the lack of clearances involved. But I'd certainly try touching up solder joints in that area.
