Page 3 of 3 < 1 2 3
#371500 - 09/01/2019 23:02 Re: SSD upgrade woes... [Re: Major_Sarcasm]
djc
Loc: chicago
Hi all, it's time to bring this thread up one more time. I decided to bring a few Mk2a players back to life with 128GB SSDs, and I am experiencing similar timeout symptoms as those above. I am running in a single-drive configuration, and the errors occur in read-only playback mode (haven't tried uploading new music yet).
The errors generally follow this pattern:
hda: stat_timo: status=0xd0
show_message("0000.42 hda: err: stat_timo")
hda: drive not ready for command
ide0: reset timed-out, status=0xd0
end_request: I/O error, dev 03:04 (hda), sector 1080024
And a clean boot log is below. Any advice is appreciated. Thanks.
--Dan.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v524 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Dec 15 08:52:50 EST 2017
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 40103799) 16MB DRAM
Command line: mem=16m
Memory: 14992k/16M available (1000k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9cb88
Tuner: loopback=0, ID=-1
show_message("Hijack v524 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c00).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
hda: probing with STATUS(0x50) instead of ALTSTATUS(0xff)
hda: PA25-128, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x044a
ide_data_test: wrote 0xffff read 0x3fff
ide_data_test: wrote 0xaaaa read 0x044a
ide_data_test: wrote 0x5555 read 0x3fff
hda: PA25-128, 120832MB w/1kB Cache, CHS=15403/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:d7
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Com&#65533;Starting player
Timezone: EST
kftpd: listening on port 21
khttpd: listening on port 80
Dead temp.sensor, status=0x00
Prolux 4 empeg car - 2.1434 Jul  5 2004
empeg:/drive0/var# hdparm -I /dev/hda
/dev/hda:
ATA device, with non-removable media
        Model Number:       PA25-128
        Serial Number:      978052500008
        Firmware Revision:  20150807
Standards:
        Supported: 9 8 7 6 5
        Likely used: 9
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           15      15
        sectors/track   63      63
        CHS current addressable sectors:   15481935
        LBA    user addressable sectors:  247463936
        LBA48  user addressable sectors:  247463936
        device size with M = 1024*1024:      120832 MBytes
        device size with M = 1000*1000:      126701 MBytes (126 GB)
Capabilities:
        LBA, IORDY(can be disabled)
        Standby timer values: spec'd by Vendor, no device specific minimum
        R/W multiple sector transfer: Max = 1   Current = 1
        DMA: mdma0 mdma1 *mdma2 udma0 udma1 udma2 udma3 udma4 udma5 udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
           *    Power Management feature set
                Write cache
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    NOP cmd
           *    48-bit Address feature set
                Mandatory FLUSH_CACHE
                FLUSH_CACHE_EXT
Security:
        Master password revision code = 65534
                supported
        not     enabled
        not     locked
        not     frozen
        not     expired: security count
        not     supported: enhanced erase
        6min for SECURITY ERASE UNIT.
HW reset results:
        CBLID- above Vih
        Device num = 0
Checksum: correct
Edited by djc (09/01/2019 23:09)
#371501 - 10/01/2019 16:43 Re: SSD upgrade woes... [Re: Major_Sarcasm]
djc
Loc: chicago
Here's an example of a problem log from a different player with the same model drive (Kingspec PA25-128). Once the problems begin, the player will not recover until I reboot. After a restart, it will happily pick up where it left off and continue to play for a while (sometimes minutes, sometimes hours).
Thanks to Tony and anyone else who had a hand in creating and restoring the lost FAQ. It's greatly appreciated to have it back again as a troubeshooting resource.
--Dan.
e000 v1.04
Copying kernel...
empeg-car player (hardware revision 9, serial number 40104006) 16MB DRAM
empeg state support initialised 0089/88c1 (save to d0005500).
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:a6
Partition check:
Mounting proc
Timezone: EST
attempt to access beyond end of device
03:04: rw=0, want=1972874128, limit=117113850
dev 03:04 blksize=4096 blocknr=-580523293 sector=-349219048 size=4096 count=1
03:04: rw=0, want=2100117676, limit=117113850
dev 03:04 blksize=4096 blocknr=-1085583318 sector=-94731952 size=4096 count=1
03:04: rw=0, want=626265808, limit=117113850
dev 03:04 blksize=4096 blocknr=1767179187 sector=1252531608 size=4096 count=1
03:04: rw=0, want=1728074060, limit=117113850
dev 03:04 blksize=4096 blocknr=2042631250 sector=-838819184 size=4096 count=1
03:04: rw=0, want=1476157000, limit=117113850
dev 03:04 blksize=4096 blocknr=-1778444399 sector=-1342653304 size=4096 count=1
03:04: rw=0, want=208150996, limit=117113850
dev 03:04 blksize=4096 blocknr=-1558574988 sector=416301984 size=4096 count=1
03:04: rw=0, want=1019703664, limit=117113850
dev 03:04 blksize=4096 blocknr=-1892557733 sector=2039407320 size=4096 count=1
03:04: rw=0, want=1463961632, limit=117113850
dev 03:04 blksize=4096 blocknr=1439732231 sector=-1367044040 size=4096 count=1
03:04: rw=0, want=1730637140, limit=117113850
dev 03:04 blksize=4096 blocknr=1506401108 sector=-833693024 size=4096 count=1
03:04: rw=0, want=1355300268, limit=117113850
dev 03:04 blksize=4096 blocknr=1949437802 sector=-1584366768 size=4096 count=1
03:04: rw=0, want=492459404, limit=117113850
dev 03:04 blksize=4096 blocknr=1196856674 sector=984918800 size=4096 count=1
hda: irq_timo: status=0xd0
show_message("0000.51 hda: err: irq_timo")
show_message("0000.51 hda: err: stat_timo")
end_request: I/O error, dev 03:04 (hda), sector 50593832
end_request: I/O error, dev 03:04 (hda), sector 50593840
empeg:/empeg/bin# hdparm -I /dev/hda
/dev/hda:
        Serial Number:      978052500014
Standards:
        Likely used: 9
Configuration:
        Logical         max     current
        heads           15      15
        sectors/track   63      63
Capabilities:
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Write cache
           *    NOP cmd
                FLUSH_CACHE_EXT
Security:
                supported
        not     enabled
        not     locked
        not     frozen
HW reset results:
        CBLID- above Vih
        Device num = 0
Checksum: correct
empeg:/empeg/bin# fdisk -l /dev/hda
Disk /dev/hda: 255 heads, 63 sectors, 15403 cylinders
Units = cylinders of 16065 * 512 bytes
   Device Boot    Start       End    Blocks   Id  System
/dev/hda1             1         5     40131    5  Extended
/dev/hda2             6        10     40162+  83  Linux
/dev/hda3            11        13     24097+  10  OPUS
/dev/hda4            14     14593 117113850   83  Linux
/dev/hda5             1         3     24034+  83  Linux
/dev/hda6             4         5     16033+  82  Linux swap
#371502 - 10/01/2019 17:06 Re: SSD upgrade woes... [Re: djc]
Credit where due: The restoration of the lost FAQ was entirely Faolan's doing. We are very indebted to him.
#371515 - 14/01/2019 00:40 Re: SSD upgrade woes... [Re: Major_Sarcasm]
djc
Loc: chicago
One more data point. In addition to the Kingspec PA25-128 drives, which are exhibiting the problems above, I set up a couple of players with IDE/mSATA adaptors. Specifically, the Chenyang mSATA mini PCI-E SATA enclosure, with a Goldendisk mSATA 128GB mini SSD. That combo seems to work just fine in the player. I've got one that's been running for over 48 hours straight with no issues.
All of the Kingspec drives are byte-copies of a master disk created using the Chenyang/Goldendisk combo, copied using dd on a Mac.
Here's the relevant logs for the good drive, in case it helps shed light on any differences with the errors on the Kingspec drives. I'm especially confused by the "attempt to access beyond end of drive" errors on the Kingspec.
Thanks for any insight or suggestions,
--Dan.
e000 v1.04
Copying kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v515 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Wed Jul 20 09:24:02 EDT 2011
empeg-car player (hardware revision 9, serial number 40103926) 16MB DRAM
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
show_message("Hijack v515 by Mark Lord")
empeg state support initialised 0089/88c1 (save to d0004800).
ide_data_test: wrote 0x0000 read 0x0100
ide_data_test: wrote 0xffff read 0x0100
ide_data_test: wrote 0x0000 read 0x0004
ide_data_test: wrote 0x5555 read 0x0100
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffaa
ide_data_test: wrote 0x5555 read 0xff55
hda: YCdisk YCMSA-128MS, ATA DISK drive
ide_data_test: wrote 0xaaaa read 0xffea
ide_data_test: wrote 0x5555 read 0xffff
hda: YCdisk YCMSA-128MS, 114473MB w/0kB Cache, CHS=14593/255/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:56
Partition check:
Mounting proc
Timezone: Jamaica
hijack: removed menu entry: "Serial Port Assignment"
  player.cpp        : 385:empeg-car 2.01 2004/07/06.
Vcb: 0x40892000
/dev/hda:
        Model Number:       YCdisk YCMSA-128MS
        Serial Number:      YC0415171221128M0799
        Firmware Revision:  Q0407A
        Media Serial Num:   &#65533;
        Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5
Standards:
        Likely used: 9
Configuration:
        Logical         max     current
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:  234441648
        LBA48  user addressable sectors:  234441648
        device size with M = 1024*1024:      114473 MBytes
        device size with M = 1000*1000:      120034 MBytes (120 GB)
Capabilities:
        Standby timer values: spec'd by Standard, no device specific minimum
        Advanced power management level: disabled
        DMA: mdma0 *mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 udma6
Commands/features:
        Enabled Supported:
           *    SMART feature set
           *    Write cache
                Look-ahead
           *    Host Protected Area feature set
           *    NOP cmd
           *    DOWNLOAD_MICROCODE
                Advanced Power Management feature set
           *    SET_MAX security extension
           *    Device Configuration Overlay feature set
           *    Mandatory FLUSH_CACHE
           *    FLUSH_CACHE_EXT
           *    SMART error logging
           *    SMART self-test
           *    General Purpose Logging feature set
           *    WRITE_{DMA|MULTIPLE}_FUA_EXT
           *    64-bit World wide name
           *    SATA-I signaling speed (1.5Gb/s)
           *    SATA-II signaling speed (3.0Gb/s)
Security:
                supported
        not     enabled
        not     locked
        not     frozen
        2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 0000
        NAA             : 0
        IEEE OUI        : 0
        Unique ID       : 00
Integrity word not set (found 0x0000, expected 0x43a5)
Disk /dev/hda: 255 heads, 63 sectors, 14593 cylinders
#371516 - 14/01/2019 14:09 Re: SSD upgrade woes... [Re: Major_Sarcasm]
My rambling thoughts:
Note that your mSATA drive is a different size (capacity) than the PA25-128 drive.
And the PA25-128 might also be a different size (capacity) than your "master" drive. So doing a bit copy from, say, a larger master drive to a slightly smaller PA25-128 could result in the access errors you see. The PA25-128 simply does not have as many sectors as the software thinks it has.
In this case, the capacity of the erring /dev/hda4 appears to be 117113850 blocks, where a block is two sectors. 117113850 * 2 = 234227702 sectors for that specific partition. This of course matches what fdisk also reports (234227700), since the two numbers come from exactly the same place.
Most of the errors show "want" blocks that are believable but slightly too large for the partition, but a few of the later ones are quite obviously WAYYY out of range.
I suggest perhaps you should run filesystem checks on /dev/hda4 on the failing drive to see what it says. Something there really looks mucked up from the diskcopy, or ??
Another way things could get messed up is if the old kernel on the empeg somehow has decided to use CHS addressing rather than LBA. That could also confuse the situation. Unfortunately, that kernel doesn't appear to print any indicator of which type of addressing it is using. Except for drives larger than 128GB where it will print LBA48 in the log.
EDIT: I suppose we can rule out CHS addressing, because it reduces the addressable capacity by QUITE A LOT more that what we are seeing here. So that part is likely just fine.
Edited by mlord (14/01/2019 14:12)
#371520 - 14/01/2019 22:13 Re: SSD upgrade woes... [Re: mlord]
Are any of these issues similar to the ones I encountered when I upgraded to an SSD?
https://empegbbs.com/ubbthreads.php/ubb/showflat/Number/369021
#371973 - 15/05/2019 23:05 Re: SSD upgrade woes... [Re: Major_Sarcasm]
As a very late follow-up here, see this slightly newer thread, where I describe findings from using an identical counterfeit Kingspec drive:
https://empegbbs.com/ubbthreads.php/topics/371821/Replacement_SSD
#372257 - 09/09/2019 22:24 Re: SSD upgrade woes... [Re: Major_Sarcasm]
suomi35
Loc: Denver, CO
I recently ran out of room on a 64GB SSD and decided to upgrade to a 128GB CF configuration.
I got the 128GB CF setup using the builder_bigdisk_v21.upgrade, restored all fids and dynamic data partition from the 'old' 64GB SSD drive (using a USB<>PATA adapter and a linux box), and things were going seemingly well. Music played fine, reboots were fine, etc.
I tried to add a new album to the player this morning and ran into all kinds of issues during the sync (tried with emplode and jemplode). Namely, the timeout issue that others have mentioned sporadically. Mine is repeatedly giving this message:
"2a40.3 hda: err: stat_timo"
Player infos:
Model: mk2a
Player: v2.01
Hijack: v525
PATA/CF adapter: https://smile.amazon.com/gp/product/B07QW5NRMH/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
CF card: https://smile.amazon.com/gp/product/B07M5M5KYZ/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
(The CF card adapter is the only device on the IDE)
Has anyone else run into something similar and figured out a solution?
-Jason
#372259 - 09/09/2019 22:54 Re: SSD upgrade woes... [Re: suomi35]
Question: Have you tried, with that new 128gb CF, plain-formatting it (builder_bigdisk_v21.upgrade), and then see if you get errors when you sync an album to it, i.e., without copying fids or the dynamic partition first?
That way, you rule out any potential problems that may have been induced with the copy operation with the PATA adapter that you performed on the linux box.
If that works, then you could try doing the copying inside the player, with the instructions here (scroll to Step 7: Copying files (special circumstances only)).
#372260 - 09/09/2019 23:04 Re: SSD upgrade woes... [Re: Major_Sarcasm]
suomi35
Loc: Denver, CO
I have not tried that, but will. Thanks for the tip!!
-Jason
#372261 - 09/09/2019 23:33 Re: SSD upgrade woes... [Re: suomi35]
Also, I'd like to ask Mark Lord his opinion about the CF card itself. You linked this card:
The labeling and text on that card seem to indicate that it is something slightly different than an ordinary CF card. Instead of "CF card" on the label it says "CFF Card". And the accompanying text says things like "features UDMA 7 to deliver fast transfer speeds when used with your DSLR or CF enabled Camera" and "incredible read speeds over traditional CF cards".
I'm wondering if that means it's not following the same specification as a normal CF card, and might be a SATA drive under the hood, instead of a PATA drive. I don't know enough about it though. Mark, do you know?
#372265 - 10/09/2019 10:49 Re: SSD upgrade woes... [Re: Major_Sarcasm]
The card description (and Amazon reviews) look a bit iffy, yes. Kingston is being very cagey in the descriptions, but it sounds as if their firmware is doing "special things" for cameras, possibly at the expense of full compatibility.
Bummer. I suppose someday I should try and figure out those "status timeout" errors and introduce a workaround for them. Except I don't think I have anything on-hand that produces them.
#372267 - 10/09/2019 11:11 Re: SSD upgrade woes... [Re: mlord]
Okay, here's a rough guess. Give this Hijack kernel a try (attached).
hijack_v525+.zImage (511 downloads)
Description: Possible fix for stat_timeo
#372270 - 10/09/2019 15:03 Re: SSD upgrade woes... [Re: mlord]
suomi35
Loc: Denver, CO
You are great. I flashed builder_bigdisk_v21.upgrade and then immediately applied hijack_v525+.zImage before rebooting. Everything came back fine, no error messages, at least on the VFD wink
I loaded a few albums and changed a few config.ini items via emplode without issue, sync'ing several times.
Here is a boot log, for good measure...everything looks dandy to me:
e000 v1.04
Copying kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v525 ([email protected]) (gcc version 2.95.3 20010315 (release)) #7 Tue Sep 10 07:21:38 EDT 2019
c1000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 30102452) 16MB DRAM
Signature is 67706d65 'empg'
show_message("Hijack v525+ by Mark Lord")
empeg state support initialised 0089/88c1 (save to d0005c80).
ide_data_test: wrote 0x0000 read 0x3962
ide_data_test: wrote 0xffff read 0x0343
ide_data_test: wrote 0xaaaa read 0xe787
ide_data_test: wrote 0x5555 read 0x66c3
hda: CF Card, ATA DISK drive
hda: CF Card, 119280MB w/0kB Cache, CHS=15206/255/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:94
Partition check:
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To Comrting player
Timezone: Singapore
ktelnetd: listening on port 23
Gotta update that timezone hahaha
Next, I think I will attempt to load all of the fids/dyn_data via USB-PATA adapter/linux and see how that behaves.
I will reply back with results cool
-Jason
#372271 - 10/09/2019 16:08 Re: SSD upgrade woes... [Re: suomi35]
Good! Now we just need somebody with one of those non-Kingspec "Yansen" SSDs to give it a whirl. They were also failing with messages like that, I think -- gotta re-read the relevant thread.
Tony?
#372273 - 10/09/2019 16:38 Re: SSD upgrade woes... [Re: Major_Sarcasm]
suomi35
Loc: Denver, CO
I notice that there is a 'new' file structure within ~/fids...I think I missed that while doing drive-shuffling last week.
When I added music to the player after flashing (detailed in the above post) it wrote all tracks to /drive0/fids/_00000/
If I have a directory of fids backed on a server, should I now restore them to /drive0/fids/_00000/ or restore them alongside _00000 in /drive0/fids/ ?
If so, I wonder if that would screw up a backed up image of /dev/hda3 (dyn_data)...
-Jason
#372274 - 10/09/2019 16:41 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Restore them straight to /drive0/fids/ as they were before.
When done, login to the player and do this:
rwm ; fidsift.sh ; rom
#372275 - 10/09/2019 19:11 Re: SSD upgrade woes... [Re: mlord]
suomi35
Loc: Denver, CO
I am ecstatic!
1. Copied the fids/dyn data onto the CF via linux box
2. Put it back in the empeg
3. Restored dyn data
4. Ran fidsift.sh
5. Sync'd via Emplode
6. Loaded a new album via emplode and changed some config.ini bits
7. Rebooted a few times...zero issues(!)
8. Finally, flashed hijack v526 over v525+
It's flawless now.
Mark, you are a wonderful human. Massive thanks!
And thank you Tony, for all of the hints!
-Jason
#372280 - 11/09/2019 18:33 Re: SSD upgrade woes... [Re: Major_Sarcasm]
suomi35
Loc: Denver, CO
I spoke too soon smirk
I just deleted an album via Emplode and it got stuck on "Remounting disks..." during the sync.
The drive activity LED on the adapter is fully lit (no fluctuation).
Everything else has been perfect though...and I am still ecstatic wink
-Jason
#372281 - 11/09/2019 18:44 Re: SSD upgrade woes... [Re: Major_Sarcasm]
suomi35
Loc: Denver, CO
aaaand, strangely, I just did the same operation (deleted an album) and it worked fine...
-Jason
#372283 - 11/09/2019 19:55 Re: SSD upgrade woes... [Re: Major_Sarcasm]
suomi35
Loc: Denver, CO
I am loving the new setup...somehow the music sounds 'better' than before laugh
#372285 - 12/09/2019 10:21 Re: SSD upgrade woes... [Re: suomi35]
Writing (including the "remount" part) can take _ages_ on PATA SSDs and CF Cards. Some are quicker than others on the empeg, and some are not. It doesn't always seem to be strictly related to the rated speed of the card/SSD.
So.. when it gets "stuck", give it a good 20 minutes at least before "pulling the plug"!
#373417 - 01/08/2021 16:57 Re: SSD upgrade woes... [Re: mlord]
Has anyone here still got a Yansen drive on hand? It would be very useful to know if Hijack-v526 "fixed" the issues with them.
#373418 - 02/08/2021 10:06 Re: SSD upgrade woes... [Re: mlord]
elperepat
Loc: Qc, Canada
I do have one right here still brand new in box.
Yansen 128GB model PA25-128.
Edited by elperepat (02/08/2021 10:10)
Patrick
#373419 - 02/08/2021 11:34 Re: SSD upgrade woes... [Re: Major_Sarcasm]
That's the one, I believe. Would you be able to run the bigdisk_v21 builder on it and see if it succeeds?
http://rtr.ca/bigdisk/
Page 3 of 3 < 1 2 3
