#31890 - 01/06/2001 19:16 vw install question
hello
sorry this is somewhat unrelated
I am installing a new head unit in my 2001 vw golf to connect the EMPEG player I just bought to.
On the new head unit the radio does not come in it work the same with or without the antenna connected.
I am using an antenna adaptor that just converts the vw plug to the usa style one it has no electronics.
Does anyone know if this is the right adaptor ? I read on another website about an adaptor that you have to connect the power antenna wire to. The vw dealer had never heard on one like that.
thanks
matt
#31891 - 02/06/2001 01:47 Re: vw install question [Re: msaeger]
mtempsch
IIRC (I have a Polo '01 and I think it uses the same antenna) the
antenna is a powered one which needs (well, I use a JVC head for tapes
and radio, and it seems to get the stations around here well enough
without it) a special adapter that feeds power to the antenna.
Not that I listen very much to the radio... (think it was three
months ago, last time :-)
Also, beware of VW's habit of swithing pin 4 & 7 in the ISO connector
(constant and keyed +12V)
#31892 - 02/06/2001 05:54 Re: vw install question [Re: mtempsch]
thanks for the reply I read that somewhere but the vw dealer didn't know about it so I didn't know what to believe
maybe a stereo shop will know what it is
thanks
#31893 - 02/06/2001 07:44 Re: vw install question [Re: msaeger]
You do need an antenna power adaptor, this feeds power to the amp in the base of the antenna mast - I need the same in my 2000 new beetle. Should be about $10.
#31894 - 02/06/2001 08:45 Re: vw install question [Re: altman]
thanks again
I got found one a the stereo shop
I need to stop asking the people working in the store questions and just tell them what I need
now I just need the empeg to get here
#31895 - 02/06/2001 19:28 Re: vw install question [Re: msaeger]
does anyone know how to remove the center part where the head unit is (it looks like it comes out in a unit to me) it would be much easier to get everything in there with it out
it is tight in there !
#31896 - 03/06/2001 09:26 Re: vw install question [Re: msaeger]
thinfourth2
And the best part is you get to do it all again in a few months to fit the radio module
#31897 - 03/06/2001 09:44 Re: vw install question [Re: thinfourth2]
nope 2 head units that plus I am only getting a mark 1 it's the one that was posted in the for sale forum
#31898 - 03/06/2001 13:29 Re: vw install question [Re: msaeger]
xanatos
Loc: Denver, CO
I was having the same problem with my car, figuring out how to take everything off. However, Crutchfield has a GREAT master sheet that you can probably buy for your car. I couldn't find them on their site, so I called em and asked. It was 4.95 w S&H and it got to my house two days later.
That should help you a lot. And it really helps in not breaking something on your car :P
Later
Damien Heiser
RioCar / empeg 12GB Blue Mark 2a SN: 120001043
- Damien - Mk2a 24G Blue SN: 120001043
#31899 - 04/06/2001 08:56 Re: vw install question [Re: xanatos]
Let me add my usual two cents to this (since I say the same thing every time it comes up):
Those Crutchfield master sheets are works of ART. They will keep you from scratching, breaking, or damaging your car interior, because they show you exactly how to dismantle your dash and speaker locations. In the case of my Honda, it even showed me how to use a piece of cloth in a certain spot to prevent damage to the plastic as I was prying off the clock assembly.
If you are doing installation work, do not touch a single clip or screw until you have ordered these master sheets and have read them carefully.
#31900 - 04/06/2001 14:05 Re: vw install question [Re: tfabris]
I callled crutchfield they said the guide they have for the VW Golf basically only tells how to remove the stock radio and not how to disassemble the dash
I think I need the bentley manual
thanks
#31901 - 05/06/2001 04:27 Re: vw install question [Re: msaeger]
lax
Loc: Austin, TX, USA
Yes, the Bentley VW manual would help you disassemble the dash... however, this is not trivial and shouldn't be necessary.
I'm not sure how different the Golf console is, but I managed to install two HUs into my 2K Passat with minimal frustration. I installed my first HU into the top DIN slot, and a week later added the Empeg into the middle slot.
Things do get awful tight in the VW cage, but if you take your time and take full advantage of the few holes behind the HU area to stuff away as much wiring as possible, you should be able to finesse it all into place. Good luck...
______________
Empeg Mk. 2 #626, 18Gb blue | Kenwood KMD-X92. 2000 VW Passat wagon.
______________ Empeg Mk. 2 #626, 48Gb blue | Kenwood KMD-X92. 2000 VW Passat wagon.
#31902 - 06/06/2001 14:23 Re: vw install question [Re: msaeger]
I got the MK1 yay
now I have a wiring question
shoudn't there be a yellow wire ?
also does anyone have a wiring diagarm for the MK1 anymore I downloaded the manual from the empeg site but it looks like it's for the MK2 (is the wiring the same ?)
every other head unit I have installed has
constant power
ignition
ground
dimmer
remote turn on / power antenna
this only appears to have ignition, dimmer, and ground
(red, orange, and black wires)
thanks
#31903 - 07/06/2001 04:45 Re: vw install question [Re: msaeger]
Derek
Loc: NRW, Germany
The orange wire is the remote on for the amp and power antenna. The MK1 doesn't have a headlight sense (dimmer) input
(list 6284, Mk1 S/N 00299 4GB blue [for sale]. Mk2 S/N 080000094 6GB blue)
