#32434 - 09/06/2001 01:13 beta 1.3 beta 6
buts
Loc: sydney australia
after upgrade the unit will not boot the screen displays thr message starting radio failed it then looks like it keeps trying to restart it
andrew butler
sn 08000176 6G amber
andrew butler
#32435 - 09/06/2001 23:06 Re: beta 1.3 beta 6 [Re: buts]
Your bug report seems to indicate that Beta6 is assuming there's a tuner module present in all cases, and failing if it's not there. If that's true: OOPS.
Since I'm beta-testing a prototype tuner module, I don't have an easy way of testing to reproduce it without a tuner plugged in. Anyone else?
(Note: Make sure you're not installing a Mk1 (Car1) upgrade file on a Mk2 (Rio Car) player!)
#32436 - 10/06/2001 02:33 Re: beta 1.3 beta 6 [Re: tfabris]
alex25
Loc: Switzerland
No problem at all. The 1.3 beta6 works great without the tuner module.
*sniff* I hope to have a tuner module soon!
#32437 - 10/06/2001 06:27 Re: beta 1.3 beta 6 [Re: tfabris]
jwickis
Loc: India
Works for me, doesn't hangup or stumble. I have notice in 1.03betaX the screen says loading tuner module in 1.03beta6 it says radio module.
BTW-Tony I have a hell uva time getting a report via hyperterm using ctrl-T when plugging the empeg in, no matter how fast I try to beat it to the punch I can never get into the diagnostic cycle. What's the trick?
#695 Mk2GRN& a mere 12Gig
"What, me be sorry"
Edited by jwickis on 10/06/01 02:33 PM.
#32438 - 10/06/2001 15:36 Re: beta 1.3 beta 6 [Re: buts]
Works fine for me, I've been using it all weekend (without a tuner). Are you sure you didn't download the Mk.1 version?
#32439 - 10/06/2001 16:27 Re: beta 1.3 beta 6 [Re: jwickis]
I don't know. Never had a problem.
Things to know:
- Must be a Mark2
- Must be hooked up in advance, hyperterm must be past its bootup screen and waiting (don't try to start hyperterm and boot the empeg at the same time)
- Hyperterm settings must be exactly right
- Need good cable
- Need zero IRQ conflicts with the serial port
Other than that, I don't know. Any tips, Hugo?
#32440 - 10/06/2001 16:42 Re: beta 1.3 beta 6 [Re: tfabris]
buts
re aplied the up grade all fine now ( used same upgrade file )
andrew butler
andrew butler
#32441 - 10/06/2001 18:35 Re: beta 1.3 beta 6 [Re: tfabris]
jwickis
Loc: India
- Must be a Mark2
- Need good cable
Yes to all requirements above my routine is start hypertrm,open .ht settings saved for empeg then plug-in empeg & hit ctrl-T as quickly as I can but it continues to show the usual bootup info, ? I have the developer version (1.03 beta 6) or should it be consumer version?
#695empeg-car Mk2GRN& a mere 12Gig
"buyers regrets,NO"
#32442 - 11/06/2001 01:11 Re: beta 1.3 beta 6 [Re: jwickis]
It's not consumer/developer dependent, it's in the boot block (ie, it's always there).
It'll skip the test if it thinks it's in car ("On DC power, quick boot" on the serial). Try holding down ctrl-T, then applying power?
#32443 - 11/06/2001 16:24 Re: beta 1.3 beta 6 [Re: altman]
jwickis
Loc: India
IT WORKED THE FIRST TIME, OK I'm fine now, I don't know how many times I tried to plug it in then see if I could beat the bootup, I've seen alot of ^T's scrolling along hypertrm.
Thanks Hugo!
empeg-car bootstrap v1.00 20000601 ([email protected])
or forever hold their peace...
0000 empeg-car board test version 0.04
0100 ram test starting
0110 testing ic 1 (0-3mb, low word)
0120 testing ic 2 (0-3mb, high word)
0130 testing ic 3 (4-7mb, low word)
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IBM-DARA-212000
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 48
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
"buyers regrets,NO"
#32444 - 11/06/2001 16:28 Re: beta 1.3 beta 6 [Re: jwickis]
Thanks, that's going into the FAQ.
#32445 - 11/06/2001 17:54 Re: beta 1.3 beta 6 [Re: jwickis]
jwickis
Loc: India
The temperature reading must be in Celcius, it read 48* the outside temp. was >85* and the empeg spent the day inside the car the whole time, it rather warm to the touch when I ran the diagnostic. So that comes out about right if you convert it, though I would've thought it would be warmer than the outside temp. Oh well at least it keeps it's cool even in a hot car.
"buyers regrets,NO"
#32446 - 11/06/2001 21:54 Re: beta 1.3 beta 6 [Re: jwickis]
See, it's not only an MP3 player, but an air conditioner as well.
#32447 - 12/06/2001 17:54 Re: beta 1.3 beta 6 [Re: tanstaafl.]
jwickis
Loc: India
LOL
Would that it actually was one, the car it's in most of the time doesn't have A/C at the moment, where do you turn the blower up it doesn't seem to be under 'settings'.
"buyers regrets,NO"
