#324927 - 06/08/2009 17:03 connecting the amps up...
crazyplums
Loc: E.Sussex, UK
finally i've decided it's time for the empeg to stop hiding under the tv and for it to go in the car instead, in the past i've installed plenty of stereo's but, normally stuck with amp'd rear speakers and sub or, 4 head unit driven speakers and an amp'd sub. easy, however, it's been far too long since i've done anything other than plug in a head unit!
so, i have a toyota lucida (estima, previa etc), a big mpv basically. i want sound front and rear + sub. i've got a pair of amps to run the front and rear speakers and i can see how they connect to the car cage phono plugs, but, how do i connect the 10" sub which has it's own amp too? i'm guessing the aux cable but, i'm not sure if that's aux in or out!
before ice got technical i used to run a pair of 6x9's off a 2channel bridgable amp, the sub also ran from the bridgable terminals via a crossover thing but, i was told later that this was not advisable, so i'm a bit stuck.
i'm not into all the mid range and tweeters, spare batteries and all that so simple will do! 1pr 6-8" front door speakers, pair of 6x9 rears (i think) and a sub,
i know there's a simple answer but my head isn't playing ball lately!
appreciate a simple answer!
thanks.
Hugh
www.dragon-signs.com
#324930 - 06/08/2009 17:14 Re: connecting the amps up... [Re: crazyplums]
The aux line is aux input. I guess you'd need a crossover of some kind on the sled front outputs to attach your sub amp.
#324931 - 06/08/2009 17:22 Re: connecting the amps up... [Re: tman]
crazyplums
Loc: E.Sussex, UK
i guess you mean some kind of two way output, one line in, then it splits it so it has two lines, one goes to sub amp and the other to the speakers?
cheers,
Hugh
#324932 - 06/08/2009 17:37 Re: connecting the amps up... [Re: crazyplums]
crazyplums
Loc: E.Sussex, UK
just a thought... if anyone here owns an ICE shop (uk) and wants some nice new signage, i'm happy to barter against some car audio!!
worth a shot!
#324933 - 06/08/2009 17:47 Re: connecting the amps up... [Re: crazyplums]
Believe it or not, I actually made a FAQ entry for that one.
#324953 - 07/08/2009 06:07 Re: connecting the amps up... [Re: tfabris]
crazyplums
Loc: E.Sussex, UK
i should've guessed!! thank you Tony, i think for simplicity for now (and cost) i'll go with the y connector option.
cheers,
Hugh
