I have turned down the carpc road and therefor want to part with my empeg.
It's a mk2a, the handle has been replaced since it broke. That was due to a missing screw on the connector that docks with the sled and the 2 connectors was stuck. That missing screw has been replaced too. It has also been fitted with the fan kit. Currently it is set to 20 degress C. The in-built temp sensor has also been reset. And the harddrive cable has also been replaced recently. The harddrives are about 5 years old but i'm not sure (you might want to replace them). As far i know everything is fully working.
There are not su much to say about the tuner, other that it's a pcats from patrick and it's working.
Also the player will come with a power adapter for in home use (not the org) and a rs232 cable along with a short cable that cam be used for in car testing if you cant reach the sleds connector.
The sled has only been used once (put in car and then taken out). I have only bent the taps that holds the sled as much needed to get it out.
The cd and manual are also there along with the org rio remote and a sony stalk.
The player will come with the auto eq files and a instruction on how to use that feature. As i remember the player is loaded with latest hijack and the latest development version of the player
The ini file on the player will be set to the buyers likeing
Current this is how it's set but a explain to some of the settings:
Gateway and netmask are the same as on your pc, the ip to any number you like, of course it can be set to dhcp
;@MENUEXEC Set_Date_Time /rdate -s 192.168.1.1 &>/dev/null gives an option in hijack to set the time and date of the players clock, the ip number can be any timeserver, mine was just the same as the gateway
fan_low=16
fan_high=21
this controls when the fan kicks in and stops, in my case it starts at 21 degress C and stops again when at 16
[Network]
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.11
DHCP=0
[synchronise]
seq_num=45
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[Options]
Name=Empeg
[controls]
stalk_side=right
[User Info]
Email="buyers e-mail here"
Phone="buyers phone number here"
Name="buyers name here"
[display]
play_count=1
visual_names=1
caching=1
[kenwood]
disabled=0
[menu]
quit=0
sort_playlist=1
[shuffle]
deduplicate=1
[sense]
muteaction=0
mute=-1
[power]
off_timeout=60000
[hush]
hushpercent=20
[volumecap]
enabled=0
[ramp]
disabled=0
[tuner]
region=europe
[aux]
source=
title=
artist=
[serial]
car_rate=115200 ; Set default rate when on DC to 115kbps
[hijack]
decimal_fidentry=1
temperature_correction=0 ;; default is -4
fan_control=1
fan_low=16
fan_high=21
The player will also be loaded with one album of mp3's so that you can test it right out of the box
some pictures:
[img]
http://tina-og-bo.dk/P1080893.JPG[/img]
[img]
http://tina-og-bo.dk/P1080894.JPG[/img]
[img]
http://tina-og-bo.dk/P1080895.JPG[/img]
[img]
http://tina-og-bo.dk/P1080899.JPG[/img]
The player can be shipped worldwide at buyers cost
An estimate for the us from denmark: 50-100$
to the UK: 20-30£
for the player itself i have an price of 500$ with all bits included, and i only sell it complete (no tuner or remote only)
Payment: Either bank transfer or a personal check, i dont have a paypal account. But the player will be boxed as soon deal is done and shipped as soon check or transfer is done, i can update buyer via sms if needed/wanted. (remember things might be a bit slow since there are time zone difference)
questions are of course welcome, best is to mail me directly at
[email protected] (remove NO SPAM), but i will of course keep an eye on any pm's
