#326703 - 15/10/2009 16:08 Thank you Mark Lord
Just wanted to say thank you again for Hijack. Its web interface feature just saved me a FSCK.
I was synching via ethernet in the background when I accidentally hit the "connect" thingy on my VPN, having forgotten I was in the middle of a synch. Of course, emplode crashed because the network connection to the player had just gone poof.
Normally that would cause me to have to FSCK the drive later on. But I remembered that I could use the web interface commands to set the drive RO. I did that, the player responded, and I was able to synch again without problems. No having to dig out serial cables.
#326705 - 15/10/2009 17:04 Re: Thank you Mark Lord [Re: tfabris]
I moved this from Off Topic. I'm pretty sure it's On Topic.
#326710 - 15/10/2009 17:25 Re: Thank you Mark Lord [Re: wfaulk]
Heh. You're right. smile
#326734 - 16/10/2009 08:11 Re: Thank you Mark Lord [Re: tfabris]
I think that if Emplode vanishes during a sync, the player itself will remount the filesystems read-only after a certain delay. Might be quite a big delay, though.
#326735 - 16/10/2009 09:01 Re: Thank you Mark Lord [Re: peter]
It does, and it is.
