Page 2 of 2 < 1 2
#335571 - 29/07/2010 00:51 Re: Care and feeding of granite counter tops [Re: hybrid8]
BTW, you can sand down a wooden cutting board to make it like new again.
Or not!
#335580 - 29/07/2010 01:58 Re: Care and feeding of granite counter tops [Re: gbeer]
Ok, that one needs a planer... And possibly needs to be shortened to remove that cracked piece off the end. I bet Mark can fix it.
How old is that thing? 60? 100 years? Or maybe it was just made to look like that last week. wink
#335582 - 29/07/2010 02:10 Re: Care and feeding of granite counter tops [Re: hybrid8]
Plastic is the best you can put them in the dishwasher and they don't damage knives. I can't see how a stone one wouldn't wreak a knife. Also if you can't get a granite counter top absorbs water and oil why wouldn't a cutting board do the same ?
I would not use wood just because I can't put it in the dishwasher. Ok I can and have but they don't last long when I do.
#335593 - 29/07/2010 03:56 Re: Care and feeding of granite counter tops [Re: tanstaafl.]
They tested different types of wood with really nasty bacteria (salmonella and e-coli) and the wooden cutting boards were safer.
I've seen similar research elsewhere, pointing to the same findings. I'm definitely a wood man.
If you get the right wooden board then the surface doesn't really degrade much at all. My main board that is used everyday, that is 5+ years old, looks hardly used yet. Plastic ones seem to quite quickly pick up long scars that hold liquids right near the surface.
#335606 - 29/07/2010 11:55 Re: Care and feeding of granite counter tops [Re: andy]
My wooden cutting board is 8 years old. Bought it at Ikea for a song. Ideally, like the example Glenn posted, you want to be cutting on the ends of the wood and the cutting board constructed of a ton of pieces attached together. I've never even sanded ours to refinish the surface yet.
#335652 - 30/07/2010 04:03 Re: Care and feeding of granite counter tops [Re: tanstaafl.]
sherry-quartz
Loc: Shenzhen,China
Well,that make sense.
granite can be hurt easier by knife.
Have you wash away stains ??
Try to use special detergent.It works.
Quartz Stone Export
Mol:86-13421399473
#335659 - 30/07/2010 13:05 Re: Care and feeding of granite counter tops [Re: sherry-quartz]
Happy Birthday tanstaafl.
Just letting it sit and, I assume, the moisture slowly evaporating, has greatly improved it. I would guess in another week all signs of the stain will have disappeared.
Page 2 of 2 < 1 2
