#33914 - 04/07/2001 15:08 Migrated to W2K and my Encoding Setup Broke
p_mauro
I just migrated my system from W98 to W2K. Since then, my MP3 encoding setup broke. I am using EAC with LAME 388. To ensure that everything would be configured properly, I imported my option profile from my W98 setup. (See attached screen shot).
When I encode a track, LAME compresses it in seconds instead of minutes. The outcome is a small (1MB) mp3 file instead of my usual large files. When I observe the graph during compression, all of the frames fall into the 32 k/s/ range.
Does anyone know what might be going on here?
pete
#33915 - 05/07/2001 04:00 Re: Migrated to W2K and my Encoding Setup Broke [Re: p_mauro]
EngelenH
Loc: Belgium/Holland
I understand this is a novel idea for Windows users but have you tried making an encode using the lame encoder via command prompt. Just to see if that works ? Don't know about EAC but it might just be an incompatibility between that and the 3.88 beta ... Maybe some parameter that changed ?
Hans
Mk2 - Blue & Red - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#33916 - 09/07/2001 21:56 Re: Migrated to W2K and my Encoding Setup Broke [Re: EngelenH]
p_mauro
I just figured out a workaround for my own problem. I added a switch to the setting "-b 128". This forced the bit rate that EAC asks in a pull-down menu below. I guess this parameter wasn't gettign passed for soem reason.
pete
